nRFConnect SDK Sample not working (periodic_adv _sync)
I have nRF52840 DK with nRFConnect SDK 1.6.99
Compiled and run on nRF52840 boards:
F:\_Develop\ConnectSDK\ncs\zephyr\samples\bluetooth\periodic_adv
F:\_Develop\ConnectSDK\ncs\zephyr\samples\bluetooth\periodic_sync
I found that in the periodic_adv,
   mfg_data[2]++;
is sent with the advertisements, but it is not received at periodic_sync:
The debug run printout:
[DEVICE] : 14:0F:D4:7E:DE:A5(random), AD evt type 5, Tx Pwr : 127, RSSI - 30 Test Periodic Advertising C:0 S:0 D:0 SR:0 E:1 Prim : LE 1M, Secn : LE 2M,
In the periodic_sync, function void scan_recv ()
    if (!per_adv_found && info->interval) {
        per_adv_found = true;
        per_sid = info->sid;
        bt_addr_le_copy(&per_addr, info->addr);
        k_sem_give(&sem_per_adv);
info->interval always 0.
And  callbacks     sync_cb,    recv_cb are never called.
Did I miss anything?
Also does bluez5.50 in the linux (btmon) support periodic advertisements? Or is there a way in the linux that can scan and capture such advertisements?
Thank you,
David Zhou
