According to following function declaration:
/**@brief Function to resolve the host name into IPv4 and/or IPv6 addresses. * * @note The memory pointed to by @p pp_res must be freed using * nrf_freeaddrinfo when the address is no longer needed * or before calling nrf_getaddrinfo again. * * @param[in] p_node Host name to resolve. * @param[in] p_service Service to resolve. * @param[in] p_hints Any hints to be used for the resolution. * @param[out] pp_res Pointer to the linked list of resolved addresses if the procedure * was successful. * * @return 0 if the procedure succeeds, else, an errno indicating the reason for failure. */ int nrf_getaddrinfo(const char *p_node, const char *p_service, const struct nrf_addrinfo *p_hints, struct nrf_addrinfo **pp_res);
an error code should be returned, which indicates reason of failure. However when AF_INET6 is used as ai_family in hints argument of nrf_getaddrinfo(), value 273 is returned. This value does not map to any value from nrf_errno.h (e.g. nrfxlib/nrf_modem/include/nrf_errno.h).
I would expect to get a reason of failure, not a random value, which does not mean anything.
