Hello, in zephir/include/drivers/can.h, in can_set_bitrate there is an error - you define local struct can_timing timing, but timing.sjw member wasn't initialized nor later calculated. However, you pass that structure to can_set_timing which use that parameter (actually it has asserts checks for it and therefore sometime application just crash). My fix is below, but I believe that proper calculation of sjw should be implemented:
@@ -766,20 +766,21 @@ static inline int z_impl_can_set_timing(const struct device *dev,
* @retval 0 If successful.
* @retval -EINVAL bitrate cannot be reached.
* @retval -EIO General input / output error, failed to set bitrate.
static inline int can_set_bitrate(const struct device *dev,
uint32_t bitrate,
uint32_t bitrate_data)
struct can_timing timing;
+ timing.sjw = 1;
#ifdef CONFIG_CAN_FD_MODE
struct can_timing timing_data;
int ret;
ret = can_calc_timing(dev, &timing, bitrate, 875);
if (ret < 0) {
return -EINVAL;
