Maximizing Gazelle Data Throughput
I'm looking to maximize the throughput using Gazelle on the nRF51.
Assuming zero retransmissions, I believe the theoretical max should be (1/TimeslotPeriod)*PayloadSize which would be 35.5kBps (284kbps) for my current settings.
Setup:
  • One nRF51 Dongle as Device
  • One nRF51 Dongle as Host
  • SDK 8.1
  • Very Close Range (RSSI ~ -51dBm)
Radio Parameters:
  • Data Rate = 1Mbps
  • Timeslot period = 900uS
  • Sync Lifetime = 40 timeslots
  • Packet Size = 32 bytes
  • Timeslots per Channel (see below)
  • 15 channels randomly generated per FCC 15.427 requirements
  • Ch Selection Policy = USE_CURRENT
Transmit Code:
while(nrf_gzll_ok_to_add_packet_to_tx_fifo(PipeNum) && buf->getCount() > 0){
   TxCount = buf->getCount();
   PayloadLen_Tx = ( TxCount > NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH )?NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH:TxCount;
   buf->pop( NRF_TxBuf, PayloadLen_Tx); // Move the Tx bytes to byte array
   result = nrf_gzll_add_packet_to_tx_fifo( this->PipeNum, NRF_TxBuf, PayloadLen_Tx);
   if(result == false){
       TxErrCnt++;
       Tx_ErrCode = nrf_gzll_get_error_code();
       nrf_gzll_reset_error_code();
Results:
My throughput seems to be dependent on number of timeslots per channel. Here are my results:
  • 5 slots/ch -> 7.2 kBps (57.6 kbps)
  • 4 slots/ch -> 9.0 kBps (72.0 kbps)
  • 3 slots/ch -> 11.2 kBps (89.6 kbps) *bounces between 10.5 and 11.7 kBps
  • 2 slots/ch -> 11.7 kBps (93.6 kbps) *Looses Sync periodically
  • 1 slots/ch -> Not Stable
Is there anything I can do to improve throughput?
Thanks!
  • Hey guys, I have a similar setup (code below on device side), with the Gzll parameters printed out below: However, I'm only able to get a throughput of 41kpbs. What might I be missing here? Thanks!
        while(ImageTxIdx < ImageDataSize){
          if(nrf_gzll_ok_to_add_packet_to_tx_fifo(PIPE_NUMBER)) {
              for(uint8_t i=0;i<32;i++)
                data_payload[i] = ImageData[ImageTxIdx++];
              ret = nrf_gzll_add_packet_to_tx_fifo(PIPE_NUMBER, data_payload, 32);
              if(ret == false){
                TxErrCnt++;
                SEGGER_RTT_printf(0, "TxErrCnt:%d\n", TxErrCnt);
    //device
    nrf_gzll_get_datarate: 2
    nrf_gzll_get_timeslot_period: 600
    NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH: 32
    nrf_gzll_get_timeslots_per_channel: 2
    nrf_gzll_get_sync_lifetime: 30
    nrf_gzll_get_channel_table_size: 5
    nrf_gzll_get_tx_power: 1
    //host
              if(ret == false){
                TxErrCnt++;
    //device
    //host
