Hello
nrf_drv_twi_rx and nrf_drv_twi_tx are non blocking calls?
in the SDK example, I see a while loop is used in the read call for instance which basically is blocking the caller function unless the m_xfer_done flag is set from within an interrupt. Is this how the driver call is typically used...to avoid invoking it before the current read is done?
uint32_t SENSOR::read()
m_xfer_done = false;
ret_code_t err_code = nrf_drv_twi_rx(&m_twi, MCP9808_ADDR, _buffer, 2);
while(!m_xfer_done);
return err_code;
- When I run SystemView while running the app, I see the interrupt is triggered every 11us, and it doesn't even mention the name of the ISR invoked leaving me confused, since SENSOR::read() call is invoked every 3s in my app.
void SENSOR::mainThread()
ret_code_t err_code;
err_code = nrf_drv_twi_tx(&m_twi, ADDR, ®, size, false);
while (!m_xfer_done);
while(true)
read();
vTaskDelay(pdMS_TO_TICKS(3000));
