No response to AT
I got up to this stage while trying to evaluate the module...
https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_nrf91_dk_gsg%2FUG%2Fnrf91_DK_gsg%2Fintro.html
There is no response to AT+CFUN=4 (or even AT). I successfully updated the modem and application FW to the latest prior to this. I have tried switching the board on/off, etc. without success.
  • I believe I have the right application now:
    Parsing HEX file: D:\DriveOne1\OneDrive - LED Roadway Lighting Ltd\Designs\IntCellCntrl\Nordic\img_app_bl\nrf9160dk_asset_tracker_ltem_2021-06-25_7a076c22.hex
    Still no response to AT commands. Here is what I see in the Terminal window...
    *** Booting Zephyr OS build v2.6.0-rc1-ncs1  ***
    [00:02:30.838,287]
    [1;31m<err> at_cmd: Failed to open AT socket (err:-117)
    [0m
    [00:02:30.845,336]
    [0m<inf> at_host: UART check failed: 1. Dropping buffer and retrying.
    [0m
    [00:02:30.863,647]
    [0m<inf> asset_tracker: Asset tracker started
    [0m
    [00:02:30.869,750]
    [0m<inf> watchdog: Watchdog timeout installed. Timeout: 60000
    [0m
    [00:02:30.877,258]
    [0m<inf> watchdog: Watchdog started
    [0m
    [00:02:30.882,751]
    [1;31m<err> at_cmd: Failed to send AT command (err:9)
    [0m
    [00:02:30.889,648]
    [1;31m<err> nrf_cloud_transport: Failed to obtain IMEI, error: -9
    [0m
    [00:02:30.897,460]
    [1;31m<err> asset_tracker: Cloud backend could not be initialized, error: -9
    [0m
    [00:02:30.906,372]
    [1;31m<err> asset_tracker: LTE link disconnect
    [0m
    [00:02:30.912,689]
    [0m
    [00:02:30.919,525]
    [1;31m<err> asset_tracker: lte_lc_power_off failed: -9
    [0m
    [00:02:30.926,422]
    [1;31m<err> asset_tracker: Shutdown modem
    [0m
    I: Starting bootloader
    I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
    I: Boot source: none
    I: Swap type: none
    I: Bootloader chainload address offset: 0x10000
    I: Jumping to the first image slot
    Flash regions
    Domain
    Permissions
    00 03 0x00000 0x20000
    Secure
    rwxl
    04 31 0x20000 0x100000
    Non-Secure
    rwxl
    Non-secure callable region 0 placed in flash region 2 with size 32.
    SRAM region
    Domain
    Permissions
    00 07 0x00000 0x10000
    Secure
    rwxl
    08 31 0x10000 0x40000
    Non-Secure
    rwxl
    Peripheral
    Domain
    Status
    00 NRF_P0               Non-Secure
    OK
    01 NRF_CLOCK            Non-Secure
    OK
    02 NRF_RTC0             Non-Secure
    OK
    03 NRF_RTC1             Non-Secure
    OK
    04 NRF_NVMC             Non-Secure
    OK
    05 NRF_UARTE1           Non-Secure
    OK
    06 NRF_UARTE2           Secure
    SKIP
    07 NRF_TWIM2            Non-Secure
    OK
    08 NRF_SPIM3            Non-Secure
    OK
    09 NRF_TIMER0           Non-Secure
    OK
    10 NRF_TIMER1           Non-Secure
    OK
    11 NRF_TIMER2           Non-Secure
    OK
    12 NRF_SAADC            Non-Secure
    OK
    13 NRF_PWM0             Non-Secure
    OK
    14 NRF_PWM1             Non-Secure
    OK
    15 NRF_PWM2             Non-Secure
    OK
    16 NRF_PWM3             Non-Secure
    OK
    17 NRF_WDT              Non-Secure
    OK
    18 NRF_IPC              Non-Secure
    OK
    19 NRF_VMC              Non-Secure
    OK
    20 NRF_FPU              Non-Secure
    OK
    21 NRF_EGU1             Non-Secure
    OK
    22 NRF_EGU2             Non-Secure
    OK
    23 NRF_DPPIC            Non-Secure
    OK
    24 NRF_REGULATORS       Non-Secure
    OK
    25 NRF_PDM              Non-Secure
    OK
    26 NRF_I2S              Non-Secure
    OK
    27 NRF_GPIOTE1          Non-Secure
    OK
    SPM: NS image at 0x20200
    SPM: NS MSP at 0x200257a8
    SPM: NS reset vector at 0x2a0cd
    SPM: prepare to jump to Non-Secure image.
    I: Swap type: none
    Flash regions
    Domain
    Permissions
    Secure
    rwxl
    Non-Secure
    rwxl
    SRAM region
    Domain
    Permissions
    Secure
    rwxl
    Non-Secure
    rwxl
    Peripheral
    Domain
    Status
    OK
    OK
    OK
    OK
    OK
    OK
    SKIP
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    OK
    AT+CFUN=4
  • It looks like it is not able to start the modem.
    How did you program the modem? What file did you use?
    Could you try to program the modem again?
  • I programmed the modem using the procedure in the Getting Started guide (mfw_nrf9160_1.3.0.zip). I note there is an extra _ character in this file versus what the guide says.
    In any case, I tried programming it again. It said it verified successfully, but still no response to AT commands.
  • Do you still get the same errors in the log?
