MCUboot image in secondary slot is not valid
Hello, I currently have nrf9160 devices deployed running nrf connect sdk v1.3.0 that fails to reboot into the secondary image. It specifically happens when I try to send a update that was built with nrf connect version 1.4.2
From my old versions build directory built with sdk 1.3.0, I copied the contents from partitions_nrf9160dk_nrf9160.yml and made a pm_static.yml file inside my new versions project directory.
pm_static.yml
EMPTY_0:
  address: 0xc000
  placement:
    before:
    - mcuboot_pad
  region: flash_primary
app:
  address: 0x1c200
mcuboot:
  address: 0x0
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x10000
  placement:
    align:
      start: 0x8000
    before:
    - mcuboot_primary_app
mcuboot_primary:
  address: 0x10000
  orig_span: &id001
  - spm
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
mcuboot_primary_app:
  address: 0x10200
  orig_span: &id002
  - app
  - spm
  span: *id002
mcuboot_secondary:
  address: 0x88000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
otp:
  address: 0xff8108
  region: otp
spm:
  address: 0x10200
  inside:
  placement:
    before:
    - app
In my new versions (nrf connect v1.4.2) build directory partitions.yml was generated...
partitions.yml
EMPTY_0:
  address: 0xc000
  placement:
    before:
    - mcuboot_pad
app:
  address: 0x1c200
bsdlib_sram:
  address: 0x20010000
  placement:
    after:
    - spm_sram
    - start
  region: sram_primary
mcuboot:
  address: 0x0
  placement:
    before:
    - mcuboot_primary
mcuboot_pad:
  address: 0x10000
  placement:
    align:
      start: 0x8000
    before:
mcuboot_primary:
  address: 0x10000
  orig_span: &id001
  - spm
  - app
  - mcuboot_pad
  sharers: 0x1
  span: *id001
  address: 0x10200
  orig_span: &id002
  - app
  - spm
  span: *id002
mcuboot_secondary:
  address: 0x88000
  placement:
    after:
    - mcuboot_primary
    align:
      start: 0x1000
  share_size:
  - mcuboot_primary
otp:
  address: 0xff8108
  region: otp
spm:
  address: 0x10200
  inside:
  placement:
    before:
    - app
spm_sram:
  address: 0x20000000
  inside:
  - sram_secure
  placement:
    after:
    - start
sram_primary:
  address: 0x20020000
sram_secure:
  address: 0x20000000
  orig_span: &id003
  - spm_sram
  span: *id003
These are the logs I gathered...
*** Booting Zephyr OS build v2.3.0-rc1-ncs3  ***
[00:00:00.003,143] [<inf> mcuboot: Starting bootloader
[00:00:00.008,819] [<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
[00:00:00.018,066] [<inf> mcuboot: Boot source: none
[00:00:00.023,101] [<inf> mcuboot: Swap type: perm
[00:00:10.750,274] [<err> mcuboot: Image in the secondary slot is not valid!
[00:00:11.081,756] [<inf> mcuboot: Bootloader chainload address offset: 0x10000
[00:00:11.089,599] [<inf> mcuboot: Jumping to the first image slot
Flash regions		Domain		Permissions
00 02 0x00000 0x18000 	Secure		rwxl
03 31 0x18000 0x100000 	Non-Secure	rwxl
Non-secure callable region 0 placed in flash region 2 with size 32.
SRAM region		Domain		Permissions
00 07 0x00000 0x10000 	Secure		rwxl
08 31 0x10000 0x40000 	Non-Secure	rwxl
Peripheral		Domain		Status
00 NRF_P0               Non-Secure	OK
01 NRF_CLOCK            Non-Secure	OK
02 NRF_RTC0             Non-Secure	OK
03 NRF_RTC1             Non-Secure	OK
04 NRF_NVMC             Non-Secure	OK
05 NRF_UARTE1           Non-Secure	OK
06 NRF_UARTE2           Secure		SKIP
07 NRF_TWIM2            Non-Secure	OK
08 NRF_SPIM3            Non-Secure	OK
09 NRF_TIMER0           Non-Secure	OK
10 NRF_TIMER1           Non-Secure	OK
11 NRF_TIMER2           Non-Secure	OK
12 NRF_SAADC            Non-Secure	OK
13 NRF_PWM0             Non-Secure	OK
14 NRF_PWM1             Non-Secure	OK
15 NRF_PWM2             Non-Secure	OK
16 NRF_PWM3             Non-Secure	OK
17 NRF_WDT              Non-Secure	OK
18 NRF_IPC              Non-Secure	OK
19 NRF_VMC              Non-Secure	OK
20 NRF_FPU              Non-Secure	OK
21 NRF_EGU1             Non-Secure	OK
22 NRF_EGU2             Non-Secure	OK
23 NRF_DPPIC            Non-Secure	OK
24 NRF_GPIOTE1          Non-Secure	OK
25 NRF_REGULATORS       Non-Secure	OK
SPM: NS image at 0x1c200
SPM: NS MSP at 0x2002fcf8
SPM: NS reset vector at 0x21e25
SPM: prepare to jump to Non-Secure image.
It is failing at this line.
This is the new versions prj.conf
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_REBOOT=y
CONFIG_ASSERT=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_NETWORK_MODE_LTE_M=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
#key management
CONFIG_MODEM_KEY_MGMT=y
# BSD library
CONFIG_BSD_LIBRARY=y
CONFIG_BSD_LIBRARY_SYS_INIT=n
# DK
#CONFIG_DK_LIBRARY=y
# Generic cloud API
#CONFIG_CLOUD_API=y
# nRF Cloud
#CONFIG_NRF_CLOUD=y
# UART 1
CONFIG_SERIAL=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
#CONFIG_UART_1_NRF_UARTE=y
# FOTA
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
CONFIG_FLASH=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# MBED TLS
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_SHA1_C=y
# Heap and stacks
# Extended memory heap size needed for encoding nRF Cloud messages to JSON
CONFIG_HEAP_MEM_POOL_SIZE=8192
CONFIG_MAIN_STACK_SIZE=10240
#Disabel optimization
#CONFIG_NO_OPTIMIZATIONS=y
Any help is appreciated, Thanks.
