App Timer not run with PWM driver simultaneously
I use NRF52832 with SDK 17.0.2.
I run app timer and pwm driver independently ok.
I merged App timer with PWM Driver. But only PWM run, I can't make app timer app run. If I comment PWM driver so app timer run.
This my code
APP_TIMER_DEF(m_repeated_timer_id);
/**@brief Timeout handler for the repeated timer.
static void repeated_timer_handler(void * p_context)
    nrf_gpio_pin_toggle(LED_2);
/**@brief Function starting the internal LFCLK oscillator.
 * @details This is needed by RTC1 which is used by the Application Timer
 *          (When SoftDevice is enabled the LFCLK is always running and this is not needed).
static void lfclk_request(void)
    ret_code_t err_code = nrf_drv_clock_init();
static void create_timers()
    ret_code_t err_code;
    // Create timers
    err_code = app_timer_create(&m_repeated_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                repeated_timer_handler);
		lfclk_request();
    pwm_init(LED_1, LED_3);
		nrf_gpio_cfg_output(LED_2);
		APP_ERROR_CHECK(app_timer_init());
		create_timers();
		int err_code = app_timer_start(m_repeated_timer_id, APP_TIMER_TICKS(200), NULL);
    for (;;)
        // Wait for an event.
        __WFE();
        // Clear the event register.
        __SEV();
        __WFE();
        NRF_LOG_FLUSH();
and my PWM Init
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
// This is for tracking PWM instances being used, so we can unintialize only
// the relevant ones when switching from one demo to another.
#define USED_PWM(idx) (1UL << idx)
static uint8_t m_used = 0;
static uint16_t const              m_pwm_top  = 255;
static uint16_t const              m_pwm_step = 1;
static nrf_pwm_values_individual_t channel;
int count = 0;
static nrf_pwm_sequence_t const    m_pwm_seq =
    .values.p_individual = &channel,
    .length              = NRF_PWM_VALUES_LENGTH(channel),
    .repeats             = 0,
    .end_delay           = 0
static void pwm_handler(nrf_drv_pwm_evt_type_t event_type)
	if (event_type == NRF_DRV_PWM_EVT_FINISHED)
				static bool down = false;
				int value = channel.channel_0;
        if (down)
            value -= m_pwm_step;
            if (value == 0)
                down = false;
            value += m_pwm_step;
            if (value >= m_pwm_top)
                down = true;
        channel.channel_0 = value;
				channel.channel_1 = value;
				nrf_delay_ms(10);
void pwm_init(int pin1, int pin2)
    nrf_drv_pwm_config_t const config0 =
        .output_pins =
            pin1 | NRF_DRV_PWM_PIN_INVERTED, // channel 0
            pin2 | NRF_DRV_PWM_PIN_INVERTED, // channel 1
        .irq_priority = _PRIO_APP_LOWEST,
        .base_clock   = NRF_PWM_CLK_1MHz,
        .count_mode   = NRF_PWM_MODE_UP,
        .top_value    = m_pwm_top,
        .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
        .step_mode    = NRF_PWM_STEP_AUTO
    APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, pwm_handler));
    channel.channel_0 = 0;
    channel.channel_1 = 0;
    (void)nrf_drv_pwm_simple_playback(&m_pwm0, &m_pwm_seq, 1,
                                      NRFX_PWM_FLAG_LOOP);
Please show me why and how to fix.
Thank you
