analyze reboot reason
Hello
in order to analyze reboot reson (HW \ SW) I use the following:
in case of kernel crash I usually get coldstack print, in this case I can analyze and understand the issue, this case is OK
in other cases I just get reset device, without any print to console
in this case I read RESETREAS register and anylize.
in case I get "DOG", ok reason is clear, but usually I get "SREQ", what does it mean?
btw, I could not find an analysis implmentation for nrf9160, so I wrote the following procedure, please varify I am not missing more options
static void log_resetreason(u32_t rr)
/* Reset reason */
LOG_INF("Reset reasons:");
if (0 == rr)
LOG_INF("- NONE");
if (0 != (rr & NRF_POWER_RESETREAS_RESETPIN_MASK))
LOG_INF("- RESETPIN");
if (0 != (rr & NRF_POWER_RESETREAS_DOG_MASK ))
LOG_INF("- DOG");
if (0 != (rr & NRF_POWER_RESETREAS_SREQ_MASK ))
LOG_INF("- SREQ");
if (0 != (rr & NRF_POWER_RESETREAS_LOCKUP_MASK ))
LOG_INF("- LOCKUP");
if (0 != (rr & NRF_POWER_RESETREAS_OFF_MASK ))
LOG_INF("- OFF");
if (0 != (rr & NRF_POWER_RESETREAS_DIF_MASK ))
LOG_INF("- DIF");
u32_t rr = nrf_power_resetreas_get(NRF_POWER);
log_resetreason(rr);
    That is a soft reset, usually via firmware triggered reset (NVIC_SystemReset()):
    https://infocenter.nordicsemi.com/topic/ps_nrf9160/power.html?cp=2_0_0_4_2_0_0_13#register.RESETREAS
     The default behavior when you get an assertion or a fault in zephyr is to print the failure on serial and then do a soft-reset. Do you get a printed failure message or similar before it rebooted?
    Håkon
  • no, I do not get a print .
    as I said, on some cases I do get failure and then kernel error prints , followed by resset. that's easy to analyze, I can always read crash prints, look at the map file , find the code in the relevant address and fix the issue
    the problem is that some of the time I just get a reset without any warning.
    one option: HW releted reset, may be due to the power cunsumption peaks of the modem
    second option: some SW related reset
    si I would like to know how can I best use the RESETREAS and any other means I have to analyze reset cause and source
    thank you
     This will show the reset value of RESETREAS, which is "none" in your implementation as it is now.
     To catch this, you need to debug the actual failure, and not the reset cause. The fault itself might cause the serial print to fail.
    Try adding blocking assertions (for debug reasons), by setting CONFIG_RESET_ON_FATAL_ERROR=n (do this for secure region as well) and see if you can catch the fault.
    Håkon
