I am attempting to advertise two sets, one using coded PHY and one using 1M, currently using the master NCS branch (post v1.7.0-rc2 tag). This is on a custom board with an nRF52840.
When attempting to start advertising a 2nd advertising set via a 2nd call to bt_le_ext_adv_start with different args, I'm getting an assert from MPSL from inside its timer0 ISR (unhelpful log: <err> mpsl_init: MPSL ASSERT: 112, 2164 ).
Relevant code:
#define ADV_OPTIONS_COMMON BT_LE_ADV_OPT_CONNECTABLE \
| BT_LE_ADV_OPT_USE_NAME \
| BT_LE_ADV_OPT_EXT_ADV \
| BT_LE_ADV_OPT_USE_TX_POWER
int ble_adv_init(void) {
int err;
struct bt_le_ext_adv *adv_set_coded_PHY = NULL;
struct bt_le_ext_adv *adv_set_1M_PHY = NULL;
struct bt_le_adv_param adv_param_coded = {
.id = BT_ID_DEFAULT,
.sid = 0,
.secondary_max_skip = 0,
.options = ADV_OPTIONS_COMMON | BT_LE_ADV_OPT_CODED, // Advertise on long-range coded PHY
.interval_min = 0x20, // 20 ms (32 * 0.625)
.interval_max = 0x152, // 152.5 ms
.peer = NULL
struct bt_le_adv_param adv_param_1M = {
.sid = 1,
.options = ADV_OPTIONS_COMMON | BT_LE_ADV_OPT_NO_2M, // Advertise only on legacy 1M PHY
.peer = NULL
struct bt_le_ext_adv_cb adv_cb = {.sent = adv_sent};
err = bt_le_ext_adv_create(&adv_param_coded, &adv_cb, &adv_set_coded_PHY);
if (err) {
// TODO
return err;
err = bt_le_ext_adv_create(&adv_param_1M, &adv_cb, &adv_set_1M_PHY);
if (err) {
// TODO
return err;
err = bt_le_ext_adv_set_data(adv_set_coded_PHY, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
if (err) {
// TODO
return err;
err = bt_le_ext_adv_set_data(adv_set_1M_PHY, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
if (err) {
// TODO
return err;
struct bt_le_ext_adv_start_param adv_start_param = {
.timeout = 30000, // 5 minutes in 10 ms units
.num_events = 0
err = bt_le_ext_adv_start(adv_set_coded_PHY, &adv_start_param);
if (err) {
// TODO
return err;
err = bt_le_ext_adv_start(adv_set_1M_PHY, &adv_start_param); // Never returns, logs: <err> mpsl_init: MPSL ASSERT: 112, 2164
if (err) {
// TODO
return err;
return 0;
Relevant prj.conf settings:
## General BLE Properties
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_CTLR_PHY_CODED=y
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_SMP=y
CONFIG_BT_PRIVACY=y
CONFIG_BT_MAX_CONN=2
CONFIG_BT_MAX_PAIRED=3
CONFIG_BT_SIGNING=y
## BLE Advertising options
CONFIG_BT_EXT_ADV=y
CONFIG_BT_EXT_ADV_MAX_ADV_SET=2
Am I missing something?
