Trying to get data from pressure sensor via SPIS
Hello.
I'm trying to get data from a pressure sensor.
But it seems that BLE device is not properly got data from the sensor.
Here is a data sheet of the sensor. (Please see page 15 how I made a custom board for the sensor and how I wired.)
I'm developing with my custom boards.(Boss of nRF52832 and the sensor.)
My code is below.
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_spi.h"
#include "ble_advertising.h"
#include "ble_gap.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_spi_mngr.h"
#include "sdk_config.h"
#include "nrf_drv_spis.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#if defined (LEGACY_DEFINE)
#undef NRFX_DEFINE
#define NRFX_DEFINE LEGACY_DEFINE
#define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
//#define APP_BLE_OBSERVER_PRIO           1                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
//#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
//#define CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_1_25_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(12500, UNIT_1_25_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
//#define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_COMPANY_IDENTIFIER          0x004C                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
#define APP_SIGNAL_OUT                  0xc3                              /**< Proprietary SIGNAL OUT for Beacon. */
#define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO   18                                 /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS                    0x10001080                         /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
//NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
#define UPDATE_MS                       5000
#define BEACON_INTERVAL                 APP_TIMER_TICKS(UPDATE_MS)
APP_TIMER_DEF(m_beacon_timer_id);                                               // Timer ID
static volatile bool m_beacon_timer_flag = false;                               // Timer Flag
#define APP_SPIS_SCK_PIN 26
#define APP_SPIS_MOSI_PIN 29
#define APP_SPIS_MISO_PIN 30
#define APP_SPIS_CS_PIN 31
#define SPI_INSTANCE  0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
//#define TEST_STRING_RS                 0x1E, 0x00, 0x00
//static uint8_t       m_tx_buf_rs[] = TEST_STRING_RS;    /**< TX buffer. */
//static uint8_t       m_rx_buf_rs[sizeof(TEST_STRING_RS) + 1];    /**< RX buffer. */
//static const uint8_t m_length_rs = sizeof(m_tx_buf_rs);        /**< Transfer length. */
uint8_t       *m_rx_buf_rs;
//#define TEST_STRING_RD                 0xA6, 0x00, 0x00
//static uint8_t       m_tx_buf_rd[] = TEST_STRING_RD;           /**< TX buffer. */
//static uint8_t       m_rx_buf_rd[sizeof(TEST_STRING_RD) + 1];    /**< RX buffer. */
//static const uint8_t m_length_rd = sizeof(m_tx_buf_rd);        /**< Transfer length. */
//uint8_t       m_rx_buf_rd[];
uint8_t       *m_rx_buf_rd;
#define BLE_GAP_EVENT_LENGTH_DEFAULT        (3)  /**< Default event length, in 1.25 ms units. */
/**@brief Receive MPS used by IPSP. */
#define BLE_IPSP_RX_MPS                                    50
/**@brief Maximum number of receive buffers.
 * @details Maximum number of receive buffers to be used per IPSP channel.
 *          Each receive buffer is of size @ref BLE_IPSP_RX_BUFFER_SIZE.
 *          This configuration has implications on the number of SDUs that can
 *          be received while an SDU is being consumed by the application
 *          (6LoWPAN/IP Stack).
#define BLE_IPSP_RX_BUFFER_COUNT                           4
/**@brief Transmission MPS used by IPSP.
 * @note The actual MPS used is minimum of this value and the one requested by
 *       the peer during the channel setup. Here, the value used is
 *       (23 + 27 * 7).
#define BLE_IPSP_TX_MPS                                    212
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                       void *                    p_context)
    spi_xfer_done = true;
    NRF_LOG_INFO("Transfer completed.");
    if (m_rx_buf_rs[0] != 0)
        NRF_LOG_INFO(" Received:");
        NRF_LOG_HEXDUMP_INFO(m_rx_buf_rs, strlen((const char *)m_rx_buf_rs));
   if (m_rx_buf_rd[0] != 0)
        NRF_LOG_HEXDUMP_INFO(m_rx_buf_rd, strlen((const char *)m_rx_buf_rd));
// BLE FUNCTIONS
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = NULL,
        .len    = 0
//static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    APP_BEACON_UUID,     // 128 bit UUID value.
    APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    //uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    // If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
    // UICR instead of using the default values. The major and minor values obtained from the UICR
    // are encoded into advertising data in big endian order (MSB First).
    // To set the UICR used by this example to a desired value, write to the address 0x10001080
    // using the nrfjprog tool. The command to be used is as follows.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
    // For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
    // the following command should be used.
    // nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
    uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
    uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
    uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
    m_beacon_info[index++] = MSB_16(major_value);
    m_beacon_info[index++] = LSB_16(major_value);
    m_beacon_info[index++] = MSB_16(minor_value);
    m_beacon_info[index++] = LSB_16(minor_value);
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    //m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    //m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.interval        = CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;       // Never time out.
    //m_adv_params.duration        = 10;       // Never time out.
    m_adv_params.scan_req_notification = 1;   //VLS
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
 * @brief   Function for starting application timers.
 * @param   None.
 * @retval  None.
static void application_timers_start(void)
	ret_code_t err_code;
	// Start application timers.
	err_code = app_timer_start(m_beacon_timer_id, BEACON_INTERVAL, NULL);
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    //err_code = sd_ble_gap_adv_start(m_adv_handle, BLE_ADV_MODE_SLOW);
 * @brief   Function for stopping advertising.
 * @param   None.
 * @retval  None.
static void advertising_stop(void)
	err_code = sd_ble_gap_adv_stop(m_adv_handle);
    case BLE_GAP_EVT_SCAN_REQ_REPORT:
      NRF_LOG_INFO("RSSI %d",p_ble_evt->evt.gap_evt.params.scan_req_report.rssi);
      // No implementation needed.
    //ble_conn_cfg_t* conn_cfg;
    //ble_gap_cfg_t* gap_cfg_t;
    ble_cfg_t    ble_cfg;
    uint32_t     ram_start = 0;
    err_code = nrf_sdh_ble_app_ram_start_get(&ram_start);
    //err_code = nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
    //APP_ERROR_CHECK(err_code);
    memset(&ble_cfg, 0, sizeof(ble_cfg));
    // Configure total number of connections.
    ble_cfg.conn_cfg.conn_cfg_tag                     = APP_BLE_CONN_CFG_TAG;
    ble_cfg.conn_cfg.params.gap_conn_cfg.conn_count   = BLE_GAP_CONN_COUNT_DEFAULT * 2;
    ble_cfg.conn_cfg.params.gap_conn_cfg.event_length = BLE_GAP_EVENT_LENGTH_DEFAULT * 10;
    err_code = sd_ble_cfg_set(BLE_CONN_CFG_GAP, &ble_cfg, ram_start);
    /*memset(&ble_cfg, 0, sizeof(ble_cfg));
    ble_cfg.gatts_cfg.attr_tab_size.attr_tab_size = 256;
    err_code = sd_ble_cfg_set(BLE_GATTS_CFG_ATTR_TAB_SIZE, &ble_cfg, ram_start);
    APP_ERROR_CHECK(err_code);*/
    // Enable BLE stack.
/**@brief Function for initializing the GATT module.
/*static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing LEDs. */
static void leds_init(void)
    ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
/**@brief Function for initializing timers. */
static void timers_init(void)
        nrf_pwr_mgmt_run();
static void update_beacon_data(void)
    static uint8_t       m_tx_buf_rs[] = {0x1E, 0x00, 0x00};
    m_rx_buf_rs = (uint8_t *)malloc(sizeof(m_tx_buf_rs));    /**< RX buffer. */
    free(m_rx_buf_rs);
    static uint8_t m_length_rs = sizeof(m_tx_buf_rs);        /**< Transfer length. */
    static uint8_t       m_tx_buf_rd[] = {0xA6, 0x00, 0x00};           /**< TX buffer. */
    m_rx_buf_rd = (uint8_t *)malloc(sizeof(m_tx_buf_rd));    /**< RX buffer. */
    free(m_rx_buf_rd);
    static uint8_t m_length_rd = sizeof(m_tx_buf_rd);        /**< Transfer length. */
    // beacon update
    advertising_stop();
    nrf_gpio_cfg_output(APP_SPIS_CS_PIN);
    nrf_gpio_pin_set(APP_SPIS_CS_PIN);
    memset(m_rx_buf_rs, 0, m_length_rs);
    memset(m_rx_buf_rd, 0, m_length_rd);
    spi_xfer_done = false;
    err_code = nrf_drv_spi_transfer(&spi, m_tx_buf_rs, m_length_rs, m_rx_buf_rs, m_length_rs);
    nrf_delay_ms(5);
    err_code = nrf_drv_spi_transfer(&spi, m_tx_buf_rd, m_length_rd, m_rx_buf_rd, m_length_rd);
    //nrf_delay_ms(10);
    nrf_delay_ms(5);
    m_beacon_info[18] = m_rx_buf_rd[2];
    m_beacon_info[19] = m_rx_buf_rd[3];
    //m_beacon_info[18] = m_beacon_info[18] + 1;
    //m_beacon_info[19] = m_beacon_info[19] + 1;
    advertising_init();
    advertising_start();
 * @brief Function for application main entry.
    // Initialize.
    //NRF_POWER->TASKS_CONSTLAT = 1;
    log_init();
    timers_init();
    leds_init();
    power_management_init();
    ble_stack_init();
    advertising_init();
    NRF_LOG_INIT(NULL);
    // Start execution.
    NRF_LOG_INFO("Beacon started.");
    //application_timers_start();
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
    spi_config.ss_pin   = APP_SPIS_CS_PIN;
    spi_config.miso_pin = APP_SPIS_MISO_PIN;
    spi_config.mosi_pin = APP_SPIS_MOSI_PIN;
    spi_config.sck_pin  = APP_SPIS_SCK_PIN;
    spi_config.frequency= NRF_DRV_SPI_FREQ_4M;
    err_code = nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL);
    //memset(m_rx_buf, 0, m_length);
    //spi_xfer_done = false;
    //APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
    /*while (!spis_xfer_done)
        __WFE();
    //APP_ERROR_CHECK(nrf_drv_spis_init(&spis_2, &spis_config, spis_event_handler2));
    // Enter main loop.
    for (;; )
        idle_state_handle();
        update_beacon_data();
I 'm developing with SDK 17.0.2. and combined BLE beacon sample and spis sample.
Also, I referred this QA.
Does anyone have ideas to solve this problem?
Kindly Regards,
Shigeto
