Triggering saadc with RTC2 compare channel - initially working and than stops
I am working on nrf52832, s132, SDK17, trying to trigger the saadc with the RTC2
This is my setup :
const nrf_drv_rtc_t rtc = NRF_DRV_RTC_INSTANCE(2);
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
    ret_code_t err_code;
    nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
    err_code = nrf_drv_rtc_init(&rtc, &config, rtc_handler);
	 err_code = nrf_drv_rtc_cc_set(&rtc,0,COMPARE_COUNTERTIME * 200,true);
    //Power on RTC instance
    nrf_drv_rtc_enable(&rtc);
    uint32_t rtc_compare_event_addr = nrf_drv_rtc_event_address_get(&rtc, NRF_RTC_EVENT_COMPARE_0);
    uint32_t rtc_clear_task_addr = nrf_drv_rtc_task_address_get(&rtc, NRF_RTC_TASK_CLEAR);
    uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
    err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, rtc_compare_event_addr, saadc_sample_event_addr);
    err_code = nrf_drv_ppi_channel_fork_assign(m_ppi_channel, rtc_clear_task_addr);
void saadc_init_NordicPlayground(void)
    nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    nrf_saadc_channel_config_t channel_0_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN4);
    channel_0_config.gain = NRF_SAADC_GAIN1_4;
    channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_1_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5);
    channel_1_config.gain = NRF_SAADC_GAIN1_4;
    channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_2_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6);
    channel_2_config.gain = NRF_SAADC_GAIN1_4;
    channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4;
    nrf_saadc_channel_config_t channel_3_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7);
    channel_3_config.gain = NRF_SAADC_GAIN1_4;
    channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_0_config);
    err_code = nrf_drv_saadc_channel_init(1, &channel_1_config);
    err_code = nrf_drv_saadc_channel_init(2, &channel_2_config);
    err_code = nrf_drv_saadc_channel_init(3, &channel_3_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0],SAADC_SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1],SAADC_SAMPLES_IN_BUFFER);
void adc_ppi_init(void)
	saadc_sampling_event_init();
	saadc_init_NordicPlayground();
what I am trying to do is to periodically trigger a series of samples and than stop them until the next cycle, I have done this successfully on the nRF51 by retiming the CC compare channel on the interrupt, I set the compare channel again a few times each time the interrupt is called and than stops, the entire series of samples takes a few milliseconds. after 1sec passes I start the process again. it is important for me to time exactly my samples, I can not have them just run continuously.
This is my original code for the nRF51,on which I tried to base my solution for the nRF52, note that I was using the CC2 for RTC1
void RTC1_IRQHandler(void)
   // Clear all events (also unexpected ones)
	 NRF_RTC1->EVENTS_COMPARE[0] = 0;
	 NRF_RTC1->EVENTS_COMPARE[1] = 0;
	if (NRF_RTC1->EVENTS_COMPARE[2] != 0)
				rtc1_c2_counter++;
				NRF_RTC1->EVENTS_COMPARE[2] = 0;
				if (rtc1_c2_counter >= ADC_BUFFER_SIZE)
					rtc1_c2_counter = 0;
					NRF_RTC1->CC[2] = add_rtc_offset(0x20*10);
    NRF_RTC1->EVENTS_COMPARE[3] = 0;
    NRF_RTC1->EVENTS_TICK       = 0;
    NRF_RTC1->EVENTS_OVRFLW     = 0;
    // Check for expired timers
    timer_timeouts_check();
I started the sequence so :
uint32_t add_rtc_offset(uint32_t offset)
		uint32_t rtc_current;
		uint32_t rtc_updated;
		rtc_current = NRF_RTC1->COUNTER;
		if ((rtc_current + offset) > RTC1_MAX)
			rtc_updated = offset - (RTC1_MAX - rtc_current) ;
			rtc_updated = rtc_current + offset;
		return(rtc_updated);
NRF_RTC1->CC[chan] = add_rtc_offset(0x20*offset);
It worked fine on my nRF51822 with s130, but it does not work for me on the nRF52, because once I stop updating the CC it stops working and the next trigger never works again.
I followed a suggestion on the forum and tried to do reconfigure the entire compare channel on the interrupt like so :
(note the I am using RTC2, compare channel 0)
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
	if (rtc2_c0_counter >= ADC_BUFFER_SIZE)
		rtc2_c0_counter = 0;
		rtc2_c0_counter++;
	NRF_RTC2->EVENTS_COMPARE[0] = 0;
	NRF_RTC2->EVENTS_COMPARE[1] = 0;
	NRF_RTC2->EVENTS_COMPARE[2] = 0;
	NRF_RTC2->EVENTS_COMPARE[3] = 0;
    NRF_RTC2->EVENTS_TICK       = 0;
    NRF_RTC2->EVENTS_OVRFLW     = 0;
and this is how I triggered it :
That also worked for one sequence only and the following attempts to re-trigger failed.
Any suggestions?
Thanks in advance!
Ron
    Looks like you are forgetting to clear the RTC counter from the driver callback?
    Please try to clear it like this:
        uint32_t err_code;
        if (int_type == NRF_DRV_RTC_INT_COMPARE0)
            nrf_gpio_pin_toggle(COMPARE_EVENT_OUTPUT);
            nrf_drv_rtc_counter_clear(&rtc);
            err_code = nrf_drv_rtc_cc_set(&rtc,0 ,COMPARE_COUNTERTIME * 200,true);
    Vidar
  • Hi Vidar,
    Thanks for your help,
    If I clear it, do I still need to do the following? :
    Anyway I implemented the following code
    				rtc2_c0_counter++;
    It still does not work beyond the first series of samples, as long as I am resetting the the CC -
    it is working, but after I stop it on the ADC_BUFFER_SIZE sample, it never starts again, clearing the RTC does not seems to fix it.
    Any ideas?
    Thanks!
    The driver is responsible for clearing of these events. So no, you shouldn't clear them in the application callback.
    You have to explicitly re-enable the event by calling nrf_drv_rtc_cc_set() after you have gotten a compare event if you want the compare event to trigger again. This is because the driver's IRQ handler is disables it.
    I understand regarding the rest,
    regrading the retriggering, what if I want it to stop after 4 samples for example, and than start the cycle again in the future, say after 1 sec?
    Thanks again
    Can you set the CC register to trigger the interrupt again in 1 second then?
