DFU Bootloader with S120 config
I started to make an app for a board with nRF51822 with softdevice S120 version 1.0.1. Now I would like to have the DFU implementation in it but I am stuck at the project configuration.
Still quite new and I don't know how to solve this problem.
With version 1.0.1 I had this memory configuration: image description
Now, as @hungbui explained in this answer and from his example, I got this memory set-up: image description
If I let it like this, I got like 200 errors, as all the files and implementations I have already does not fit in that memory size.
If I change the IROM1 size to 0x27000, it compiles without errors, but when I try to Download it on the board, I get the error message:
Erase Failed! Error: Flash Download failed - "Cortex-M0"
Any help would be much appreciated.
Thank you.
  • @ Gabriel: Seems that you are using pack. The example I provided is with the .zip SDK, not the pack type.
    You can download the .zip SDK here
    My example was based on SDK v8.0 and support S120 v2.0.0. You would need to port it to be compatible with S120 v1.0.0 or you can try to port your application to S120 v2.0.0. I would suggest you to do the latter one. You can follow the migration guide in the S120 v2.0.0 zip file. It should be straight forward.
    To have the bootloader to work, you need to flash the sofdevice first, after that flash the bootloader. And use the bootloader to update the application firmware.
  • @HungBui Finally I achieved to port the application to s120 V2.1.0 (which works great) and also managed to compile and run the bootloader you uploaded for s120. But now I have another problem. All the examples from SDK are for nRF51422 and I use a nRF51822. With the app I managed to make the proper changes and it works in my board but not the bootloaders. I have a 32MHz system clock in my board and for the soft device I use the default internal clock (NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_4000MS_CALIBRATION). Ports work good for the apps, but not for the bootloader. Both s120 and s130 bootloaders works in a dev board I have with 51422 but I am not able to port them to 51822. Any advice would be much appreciated. It is something in the bootloader related with ANT? Thank you...
