Hi.
I'm working on macOS Monterey 12.0 beta and trying to start nRF Connect for desktop (version 3.7.0). When i'm trying to start this application it's starting as blank screen. I have enabled "developer tools" and see some problem with electron framework. Is it know issue? Do you know how to deal with it?
ncaught Error: dlopen(/var/folders/3n/c99gwdqj7_96848wp6fgd_3h0000gn/T/.com.nordicsemi.nrfconnect.8BDAWd, 0x0001): Library not loaded: @rpath/libhighlevelnrfjprog.dylib
Referenced from: /private/var/folders/3n/c99gwdqj7_96848wp6fgd_3h0000gn/T/.com.nordicsemi.nrfconnect.8BDAWd
Reason: tried: 'nrfjprog/libhighlevelnrfjprog.dylib' (no such file), '/private/var/folders/3n/c99gwdqj7_96848wp6fgd_3h0000gn/T/libhighlevelnrfjprog.dylib' (no such file), '/private/var/folders/3n/c99gwdqj7_96848wp6fgd_3h0000gn/T/../../nrfjprog/libhighlevelnrfjprog.dylib' (no such file), 'nrfjprog/libhighlevelnrfjprog.dylib' (no such file), '/private/var/folders/3n/c99gwdqj7_96848wp6fgd_3h0000gn/T/libhighlevelnrfjprog.dylib' (no such file), '/private/var/folders/3n/c99gwdqj7_96848wp6fgd_3h0000gn/T/../../nrfjprog/libhighlevelnrfjprog.dylib' (no such file), '/Applications/nRF Connect.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Libraries/libhighlevelnrfjprog.dylib' (no such file), '/Applications/nRF Connect.app/Contents/Frameworks/nRF Connect Helper (Renderer).app/Contents/MacOS/../../../libhighlevelnrfjprog.dylib' (no such file), '/usr/lib/libhighlevelnrfjprog.dylib' (no such file)
at process.func (electron/js2c/asar.js:140)
at process.func [as dlopen] (electron/js2c/asar.js:140)
at Object.Module._extensions..node (internal/modules/cjs/loader.js:1016)
at Object.func (electron/js2c/asar.js:140)
at Object.func [as .node] (electron/js2c/asar.js:149)
at Module.load (internal/modules/cjs/loader.js:816)
at Module._load (internal/modules/cjs/loader.js:728)
at Module._load (electron/js2c/asar.js:717)
at Function.Module._load (electron/js2c/asar.js:717)
at Module.require (internal/modules/cjs/loader.js:853)
