Hi ,
I had done the user guide on https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.6.1/nrf/ug_matter_configuring.html#ug-matter-configuring , could you please tell how to test next step,Thanks!
I use 52840dongle + Ubuntu docker as OTBR,and program one /ncs/nrf/samples/matter/light_bulb on 52840DK . The 52840DK hulb node works when press button2 led2 will toggle.
On the OTBR side ,after typing
sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 \ --sysctl "net.ipv6.conf.all.disable_ipv6=0 net.ipv4.conf.all.forwarding=1 net.ipv6.conf.all.forwarding=1" \ --volume /dev/ttyACM0:/dev/radio openthread/otbr --radio-url spinel+hdlc+uart:///dev/radio
It will show lots of logs:
simon@ubuntu:~$ sudo docker run -it --rm --privileged --name otbr --network otbr -p 8080:80 \
[sudo] simon 的密码:
RADIO_URL: spinel+hdlc+uart:///dev/radio
TUN_INTERFACE_NAME: wpan0
BACKBONE_INTERFACE: eth0
NAT64_PREFIX: 64:ff9b::/96
AUTO_PREFIX_ROUTE: true
AUTO_PREFIX_SLAAC: true
+++ dirname /app/script/server
++ cd /app/script/..
++ [[ ! -n x ]]
++ echo 'Current platform is ubuntu'
++ with BORDER_ROUTING
++ local value
+++ printenv BORDER_ROUTING
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ with DHCPV6_PD
++ local value
+++ printenv DHCPV6_PD
++ value=
++ [[ -z '' ]]
++ [[ -f examples/platforms/ubuntu/default ]]
++ [[ '' == 1 ]]
++ local value
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ with NETWORK_MANAGER
++ local value
+++ printenv NETWORK_MANAGER
++ value=
++ [[ -z '' ]]
++ [[ '' == 1 ]]
++ STAGE_DIR=/app/stage
++ BUILD_DIR=/app/build
++ [[ -d /app/stage ]]
++ mkdir -v -p /app/stage
mkdir: created directory '/app/stage'
++ [[ -d /app/build ]]
++ mkdir -v -p /app/build
mkdir: created directory '/app/build'
++ export PATH=/app/stage/usr/bin:/app/stage/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
++ PATH=/app/stage/usr/bin:/app/stage/usr/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
+++ basename /app/script/server
++ TASKNAME=server
++ BEFORE_HOOK=examples/platforms/ubuntu/before_server
++ AFTER_HOOK=examples/platforms/ubuntu/after_server
++ [[ ! -f examples/platforms/ubuntu/before_server ]]
++ BEFORE_HOOK=/dev/null
++ [[ ! -f examples/platforms/ubuntu/after_server ]]
++ AFTER_HOOK=/dev/null
+ . script/_nat64
++ TAYGA_DEFAULT=/etc/default/tayga
++ TAYGA_CONF=/etc/tayga.conf
++ TAYGA_IPV4_ADDR=192.168.255.1
++ TAYGA_IPV6_ADDR=fdaa:bb:1::1
++ TAYGA_TUN_V6_ADDR=fdaa:bb:1::2
++ NAT44_SERVICE=/etc/init.d/otbr-nat44
++ WLAN_IFNAMES=eth0
+ . script/_dns64
++ BIND_CONF_OPTIONS=/etc/bind/named.conf.options
++ NAT64_PREFIX=64:ff9b::/96
++ DNS64_NAMESERVER_ADDR=127.0.0.1
+++ echo 64:ff9b::/96
+++ tr '"/"' '"/"'
++ DNS64_CONF='dns64 64:ff9b::/96 { clients { thread; }; recursive-only yes; };'
++ without NAT64
++ with NAT64
++ local value
+++ printenv NAT64
++ value=1
++ [[ -z 1 ]]
++ [[ 1 == 1 ]]
++ test ubuntu = ubuntu
++ '[' ubuntu = raspbian ']'
++ '[' ubuntu = beagleboneblack ']'
++ '[' ubuntu = ubuntu ']'
++ RESOLV_CONF_HEAD=/etc/resolvconf/resolv.conf.d/head
+ main
+ . /dev/null
+ sudo sysctl --system
* Applying /etc/sysctl.d/10-console-messages.conf ...
kernel.printk = 4 4 1 7
* Applying /etc/sysctl.d/10-ipv6-privacy.conf ...
net.ipv6.conf.all.use_tempaddr = 2
net.ipv6.conf.default.use_tempaddr = 2
* Applying /etc/sysctl.d/10-kernel-hardening.conf ...
kernel.kptr_restrict = 1
* Applying /etc/sysctl.d/10-link-restrictions.conf ...
fs.protected_hardlinks = 1
fs.protected_symlinks = 1
* Applying /etc/sysctl.d/10-magic-sysrq.conf ...
kernel.sysrq = 176
* Applying /etc/sysctl.d/10-network-security.conf ...
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
net.ipv4.tcp_syncookies = 1
* Applying /etc/sysctl.d/10-ptrace.conf ...
kernel.yama.ptrace_scope = 1
* Applying /etc/sysctl.d/10-zeropage.conf ...
vm.mmap_min_addr = 65536
* Applying /etc/sysctl.d/60-otbr-accept-ra.conf ...
net.ipv6.conf.eth0.accept_ra = 2
net.ipv6.conf.eth0.accept_ra_rt_info_max_plen = 64
* Applying /etc/sysctl.d/60-otbr-ip-forward.conf ...
net.ipv6.conf.all.forwarding = 1
net.ipv4.ip_forward = 1
* Applying /etc/sysctl.conf ...
+ nat64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ with DOCKER
+ local value
++ printenv DOCKER
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ service tayga start
* Starting userspace NAT64 tayga [ OK ]
+ dns64_start
+ with NAT64
+ local value
++ printenv NAT64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ with DNS64
+ local value
++ printenv DNS64
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
++ _detect_service_name
++ dpkg -L bind9
++ grep /etc/init.d/
++ cut -d/ -f4
+ service_name=bind9
+ have systemctl
+ command -v systemctl
+ command -v service
/usr/sbin/service
+ sudo service bind9 start
* Starting domain name service... bind9 [ OK ]
+ have systemctl
+ have service
+ sudo service rsyslog status
* rsyslogd is not running
+ sudo service rsyslog start
* Starting enhanced syslogd rsyslogd [ OK ]
+ sudo service dbus status
* dbus is not running
+ sudo service dbus start
* Starting system message bus dbus [ OK ]
+ sudo service mdns status
Usage: /etc/init.d/mDNS {start|stop|reload|restart}
+ sudo service mdns start
Starting Apple Darwin Multicast DNS / DNS Service Discovery daemon: mdnsd.
+ sudo service avahi-daemon status
Avahi mDNS/DNS-SD Daemon is not running
+ sudo service avahi-daemon start
* Starting Avahi mDNS/DNS-SD Daemon avahi-daemon [ OK ]
+ sudo service otbr-agent status
* otbr-agent is not running
+ sudo service otbr-agent start
* Starting thread border agent otbr-agent [ OK ]
+ without WEB_GUI
+ with WEB_GUI
+ local value
++ printenv WEB_GUI
+ value=1
+ [[ -z 1 ]]
+ [[ 1 == 1 ]]
+ sudo service otbr-web status
* otbr-web is not running
+ sudo service otbr-web start
* Starting thread web interface otbr-web [ OK ]
+ . /dev/null
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: New relevant interface eth0.IPv4 for mDNS.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: New relevant interface lo.IPv6 for mDNS.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: New relevant interface lo.IPv4 for mDNS.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: Network interface enumeration completed.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: Registering new address record for fd11:db8:1::2 on eth0.*.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: Registering new address record for 172.18.0.2 on eth0.IPv4.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: Registering new address record for ::1 on lo.*.
Sep 17 09:44:41 56b1fd377ebd avahi-daemon[187]: Registering new address record for 127.0.0.1 on lo.IPv4.
Sep 17 09:44:41 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Running 0.3.0-9c5aa1c
Sep 17 09:44:41 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Thread version: 1.2.0
Sep 17 09:44:41 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Thread interface: wpan0
Sep 17 09:44:41 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Backbone interface: eth0
Sep 17 09:44:41 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Radio URL: spinel+hdlc+uart:///dev/radio
Sep 17 09:44:41 56b1fd377ebd otbr-agent[215]: [INFO]-PLAT----: RCP reset: RESET_POWER_ON
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [NOTE]-PLAT----: RCP API Version: 4
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [INFO]-PLAT----: Backbone interface is configured to eth0 (7)
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Set state callback: OK
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Stop Thread Border Agent
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Stopped
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [INFO]-DPROXY--: stopped
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Initialize OpenThread Border Router Agent: OK
Sep 17 09:44:42 56b1fd377ebd otbr-web[243]: [INFO]-WEB-----: Running 0.3.0-9c5aa1c
Sep 17 09:44:42 56b1fd377ebd otbr-web[243]: [INFO]-WEB-----: Border router web started on wpan0
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Border router agent started.
Sep 17 09:44:42 56b1fd377ebd otbr-agent[215]: [DEBG]-BBA-----: BackboneAgent: HandleBackboneRouterState: state=1, mBackboneRouterState=0
Sep 17 09:44:42 56b1fd377ebd named[87]: managed-keys-zone: Key 20326 for zone . acceptance timer complete: key now trusted
Sep 17 09:44:42 56b1fd377ebd avahi-daemon[187]: Server startup complete. Host name is 56b1fd377ebd.local. Local service cookie is 3056352893.
Sep 17 09:44:42 56b1fd377ebd rsyslogd: rsyslogd's groupid changed to 101
Sep 17 09:44:42 56b1fd377ebd rsyslogd: rsyslogd's userid changed to 101
Sep 17 09:44:42 56b1fd377ebd rsyslogd: [origin software="rsyslogd" swVersion="8.32.0" x-pid="120" x-info="http://www.rsyslog.com"] start
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Running 0.3.0-9c5aa1c
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Thread version: 1.2.0
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Thread interface: wpan0
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Backbone interface: eth0
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Radio URL: spinel+hdlc+uart:///dev/radio
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-PLAT----: RCP reset: RESET_POWER_ON
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [NOTE]-PLAT----: RCP API Version: 4
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-PLAT----: Backbone interface is configured to eth0 (7)
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Set state callback: OK
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Stop Thread Border Agent
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Stopped
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-DPROXY--: stopped
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Initialize OpenThread Border Router Agent: OK
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [INFO]-UTILS---: Border router agent started.
Sep 17 09:45:50 56b1fd377ebd otbr-agent[215]: [DEBG]-BBA-----: BackboneAgent: HandleBackboneRouterState: state=1, mBackboneRouterState=0
Sep 17 09:45:54 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Thread is down
Sep 17 09:45:54 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Stop Thread Border Agent
Sep 17 09:45:54 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Stopped
Sep 17 09:45:54 56b1fd377ebd otbr-agent[215]: [INFO]-DPROXY--: stopped
Sep 17 09:45:54 56b1fd377ebd otbr-agent[215]: [DEBG]-UTILS---: Signal io.openthread.BorderRouter.DeviceRole
Sep 17 09:45:54 56b1fd377ebd otbr-agent[215]: [DEBG]-DBUS----: { "io.openthread.BorderRouter", [ DeviceRole:{ "detached", }, ], [ ], }
Sep 17 09:45:54 56b1fd377ebd named[87]: listening on IPv6 interface wpan0, fdfd:3a5d:b921:ff9f:9c19:dd09:8ef6:7355#53
Sep 17 09:45:54 56b1fd377ebd named[87]: listening on IPv6 interface wpan0, fe80::106c:ca90:d7d:f68%4#53
Sep 17 09:45:56 56b1fd377ebd named[87]: listening on IPv6 interface wpan0, fdfd:3a5d:b921:ff9f:0:ff:fe00:fc00#53
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Thread is up
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Stop Thread Border Agent
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Stopped
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-DPROXY--: stopped
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Started
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Publish meshcop service OpenThread_BorderRouter._meshcop._udp.local.
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Add service: OpenThread_BorderRouter._meshcop._udp (ref: 0x55f1ee050140)
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish all hosts and services
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-DPROXY--: started
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Start Thread Border Agent: OK
Sep 17 09:45:56 56b1fd377ebd named[87]: listening on IPv6 interface wpan0, fdfd:3a5d:b921:ff9f:0:ff:fe00:3000#53
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [DEBG]-UTILS---: Signal io.openthread.BorderRouter.DeviceRole
Sep 17 09:45:56 56b1fd377ebd otbr-agent[215]: [DEBG]-DBUS----: { "io.openthread.BorderRouter", [ DeviceRole:{ "leader", }, ], [ ], }
Sep 17 09:45:56 56b1fd377ebd named[87]: listening on IPv6 interface wpan0, fd11:22::9aaf:d3f5:22a5:926b#53
Sep 17 09:45:57 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Received reply for service OpenThread_BorderRouter._meshcop._udp.
Sep 17 09:45:57 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Successfully registered service OpenThread_BorderRouter._meshcop._udp.
Sep 17 09:45:57 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish service 'OpenThread_BorderRouter._meshcop._udp.' result: 0
Sep 17 09:45:57 56b1fd377ebd otbr-agent[215]: [INFO]-AGENT---: Publish meshcop service OpenThread_BorderRouter._meshcop._udp.local.
Sep 17 09:45:57 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Update service OpenThread_BorderRouter._meshcop._udp
Sep 17 09:45:57 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish service 'OpenThread_BorderRouter._meshcop._udp' result: 0
Sep 17 09:45:57 56b1fd377ebd otbr-agent[215]: [DEBG]-BBA-----: BackboneAgent: HandleBackboneRouterState: state=2, mBackboneRouterState=1
Sep 17 09:45:57 56b1fd377ebd otbr-agent[215]: [NOTE]-BBA-----: BackboneAgent: Backbone Router becomes Primary!
Sep 17 09:45:57 56b1fd377ebd named[87]: listening on IPv6 interface wpan0, fdfd:3a5d:b921:ff9f:0:ff:fe00:fc10#53
Sep 17 09:45:57 56b1fd377ebd named[87]: listening on IPv6 interface wpan0, fdfd:3a5d:b921:ff9f:0:ff:fe00:fc38#53
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for fd11:db8:1::2 on eth0.
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for 172.18.0.2 on eth0.
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for 127.0.0.1 on lo.
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Host name conflict, retrying with 56b1fd377ebd-2
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Registering new address record for fd11:db8:1::2 on eth0.*.
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Registering new address record for 172.18.0.2 on eth0.IPv4.
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Registering new address record for ::1 on lo.*.
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Registering new address record for 127.0.0.1 on lo.IPv4.
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for ::1 on lo.
Sep 17 09:45:57 56b1fd377ebd avahi-daemon[187]: Host name conflict, retrying with 56b1fd377ebd-3
Sep 17 09:45:58 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for fd11:db8:1::2 on eth0.
Sep 17 09:45:58 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for ::1 on lo.
Sep 17 09:45:58 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for 127.0.0.1 on lo.
Sep 17 09:45:58 56b1fd377ebd avahi-daemon[187]: Host name conflict, retrying with 56b1fd377ebd-4
Sep 17 09:45:58 56b1fd377ebd avahi-daemon[187]: Registering new address record for fd11:db8:1::2 on eth0.*.
Sep 17 09:45:58 56b1fd377ebd avahi-daemon[187]: Registering new address record for 172.18.0.2 on eth0.IPv4.
Sep 17 09:45:58 56b1fd377ebd avahi-daemon[187]: Registering new address record for ::1 on lo.*.
Sep 17 09:45:58 56b1fd377ebd avahi-daemon[187]: Registering new address record for 127.0.0.1 on lo.IPv4.
Sep 17 09:45:58 56b1fd377ebd named[87]: listening on IPv6 interface wpan0, fdfd:3a5d:b921:ff9f:0:ff:fe00:fc11#53
Sep 17 09:46:00 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for 172.18.0.2 on eth0.
Sep 17 09:46:00 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for ::1 on lo.
Sep 17 09:46:00 56b1fd377ebd avahi-daemon[187]: Withdrawing address record for 127.0.0.1 on lo.
Sep 17 09:46:00 56b1fd377ebd avahi-daemon[187]: Host name conflict, retrying with 56b1fd377ebd-5
Sep 17 09:46:00 56b1fd377ebd avahi-daemon[187]: Registering new address record for fd11:db8:1::2 on eth0.*.
Sep 17 09:46:00 56b1fd377ebd avahi-daemon[187]: Registering new address record for 172.18.0.2 on eth0.IPv4.
Sep 17 09:46:00 56b1fd377ebd avahi-daemon[187]: Registering new address record for ::1 on lo.*.
Sep 17 09:46:00 56b1fd377ebd avahi-daemon[187]: Registering new address record for 127.0.0.1 on lo.IPv4.
Sep 17 09:46:01 56b1fd377ebd avahi-daemon[187]: Server startup complete. Host name is 56b1fd377ebd-5.local. Local service cookie is 3056352893.
Sep 17 09:46:01 56b1fd377ebd mDNSResponder: mDNSCoreReceiveResponse: Received from 172.18.0.2:5353 22 2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.1.0.0.0.8.b.d.0.1.1.d.f.ip6.arpa. PTR 56b1fd377ebd-5.local.
Sep 17 09:46:01 56b1fd377ebd mDNSResponder: mDNSCoreReceiveResponse: Unexpected conflict discarding 20 2.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.1.0.0.0.8.B.D.0.1.1.D.F.ip6.arpa. PTR 56b1fd377ebd.local.
Sep 17 09:46:01 56b1fd377ebd mDNSResponder: mDNSCoreReceiveResponse: Received from 172.18.0.2:5353 22 2.0.18.172.in-addr.arpa. PTR 56b1fd377ebd-5.local.
Sep 17 09:46:01 56b1fd377ebd mDNSResponder: mDNSCoreReceiveResponse: Unexpected conflict discarding 20 2.0.18.172.in-addr.arpa. PTR 56b1fd377ebd.local.
Sep 17 09:46:08 56b1fd377ebd avahi-daemon[187]: Registering new address record for fd7c:1caf:6935:0:42:acff:fe12:2 on eth0.*.
Sep 17 09:46:08 56b1fd377ebd named[87]: listening on IPv6 interface eth0, fd7c:1caf:6935:0:42:acff:fe12:2#53
Sep 17 09:46:49 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Advertise SRP service updates: host=126F81E0F11D3A2F.default.service.arpa.
Sep 17 09:46:49 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish SRP host: 126F81E0F11D3A2F.default.service.arpa.
Sep 17 09:46:49 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Publish new host 126F81E0F11D3A2F
Sep 17 09:46:49 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Add new host 126F81E0F11D3A2F
Sep 17 09:46:49 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish SRP service: 000000014A77CBB3-0000000000BC5C01._chip._tcp.default.service.arpa.
Sep 17 09:46:49 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Add service: 000000014A77CBB3-0000000000BC5C01._chip._tcp (ref: 0x55f1ee052d40)
Sep 17 09:46:50 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Received reply for service 000000014A77CBB3-0000000000BC5C01._chip._tcp.
Sep 17 09:46:50 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Successfully registered service 000000014A77CBB3-0000000000BC5C01._chip._tcp.
Sep 17 09:46:50 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish service '000000014A77CBB3-0000000000BC5C01._chip._tcp.' result: 0
Sep 17 09:46:50 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Received reply for host 126F81E0F11D3A2F
Sep 17 09:46:50 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Successfully registered host 126F81E0F11D3A2F
Sep 17 09:46:50 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish host '126F81E0F11D3A2F' result: 0
Sep 17 09:46:51 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Advertise SRP service updates: host=126F81E0F11D3A2F.default.service.arpa.
Sep 17 09:46:51 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish SRP host: 126F81E0F11D3A2F.default.service.arpa.
Sep 17 09:46:51 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Update existing host 126F81E0F11D3A2F
Sep 17 09:46:51 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish host '126F81E0F11D3A2F' result: 0
Sep 17 09:46:51 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish SRP service: 000000014A77CBB3-0000000000BC5C01._chip._tcp.default.service.arpa.
Sep 17 09:46:51 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Update service 000000014A77CBB3-0000000000BC5C01._chip._tcp
Sep 17 09:46:51 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish service '000000014A77CBB3-0000000000BC5C01._chip._tcp' result: 0
Sep 17 09:46:54 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Advertise SRP service updates: host=126F81E0F11D3A2F.default.service.arpa.
Sep 17 09:46:54 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish SRP host: 126F81E0F11D3A2F.default.service.arpa.
Sep 17 09:46:54 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Update existing host 126F81E0F11D3A2F
Sep 17 09:46:54 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish host '126F81E0F11D3A2F' result: 0
Sep 17 09:46:54 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish SRP service: 000000014A77CBB3-0000000000BC5C01._chip._tcp.default.service.arpa.
Sep 17 09:46:54 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Update service 000000014A77CBB3-0000000000BC5C01._chip._tcp
Sep 17 09:46:54 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish service '000000014A77CBB3-0000000000BC5C01._chip._tcp' result: 0
Sep 17 09:47:00 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Advertise SRP service updates: host=126F81E0F11D3A2F.default.service.arpa.
Sep 17 09:47:00 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish SRP host: 126F81E0F11D3A2F.default.service.arpa.
Sep 17 09:47:00 56b1fd377ebd otbr-agent[215]: [INFO]-MDNS----: Update existing host 126F81E0F11D3A2F
Sep 17 09:47:00 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Handle publish host '126F81E0F11D3A2F' result: 0
Sep 17 09:47:00 56b1fd377ebd otbr-agent[215]: [INFO]-ADPROXY-: Publish SRP service: 000000014A77CBB3-0000000000BC5C01._chip._tcp.default.service.arpa.
so it means works? And http://localhost:8080/ also can show the OTBR website content , and Form Thread Networks also success.
Check state:
simon@ubuntu:~/Nordic/ncs/ncs/nrf/samples/matter/light_bulb$ sudo docker exec -it otbr sh -c "sudo service otbr-agent status" * otbr-agent is running simon@ubuntu:~/Nordic/ncs/ncs/nrf/samples/matter/light_bulb$ sudo docker exec -it otbr sh -c "sudo ot-ctl state" leader Done
