subscribing in Assert tracker v2
I'm trying to send messages from the cloud (AWS-IoT ) to the device, so I modified the device so that it subscribes to a new topic and when I send messages from could, it seems that the device doesn't listen frequently to the cloud. sometimes it receives a message, sometimes not. and when I sent multi messages very fast, the device receive all messages after a random delay.
I tried to check the code if there is any configuration I can use to force the device to listen to Cloud always. but without luck. This behavior is in Active and Passive mode as well.
My question is: How can the device receive messages instantly from the cloud without delay.
Thanks in advance.
  • Hello Didrik,
    What is the best way to disable PSM in the prj.conf ?
    Thanks
  • When using the asset_tracker_v2, you can set CONFIG_MODEM_AUTO_REQUEST_POWER_SAVING_FEATURES=n.
    That should stop the application from requesting PSM.
  • Hey Didrik, I disabled PSM and tried again but it seems that it is the same, no difference. After 300 sec no data was sent to the server-side, even it shows in the logs that data is sent successfully but no data is received by server-side. I attached here the trace file and the log file as well, hoping that you can figure out what the problem is.
    Thanks in advance.
    [00:00:00.223,754] <wrn> cloud_codec: set alarm ---> 1
    [00:00:00.257,659] <dbg> cloud_module.state_set: State: STATE_LTE_DISCONNECTED
    [00:00:00.267,822] <dbg> cloud_module.sub_state_set: Sub state: SUB_STATE_CLOUD_DISCONNECTED
    [00:00:00.287,780] <wrn> data_module: Device configuration loaded from flash
    [00:00:00.298,461] <wrn> data_module: active_mode = 0
    [00:00:00.306,518] <wrn> data_module: active_wait_timeout = 300
    [00:00:00.315,399] <wrn> data_module: movement_resolution = 60
    [00:00:00.327,087] <wrn> data_module: movement_timeout = 1000
    [00:00:00.335,968] <wrn> data_module: gps_timeout = 60
    [00:00:00.344,024] <wrn> data_module: accelerometer_threshold = 5.000000
    [00:00:00.359,924] <wrn> app_module: the certificates are found
    [00:00:00.367,462] <inf> event_manager: APP_EVT_START
    [00:00:00.373,535] <dbg> gps_module.state_set: State: STATE_INIT
    [00:00:00.354,766] <dbg> sensor_module.state_set: State: STATE_INIT
    [00:00:00.524,230] <inf> event_manager: DATA_EVT_CONFIG_INIT
    [00:00:00.530,975] <dbg> gps_module.state_set: State transition STATE_INIT --> STATE_RUNNING
    [00:00:00.542,541] <inf> app_module: Device mode: Passive
    [00:00:00.548,675] <inf> app_module: Start movement timeout: 1000 seconds interval
    [00:00:00.557,098] <inf> app_module: 60 seconds until movement can trigger a new data sample/publication
    [00:00:00.567,932] <dbg> sensor_module.state_set: State transition STATE_INIT --> STATE_RUNNING
    [00:00:00.697,998] <inf> event_manager: MODEM_EVT_LTE_CONNECTING
    [00:00:01.783,447] <inf> event_manager: MODEM_EVT_LTE_DISCONNECTED
    [00:00:01.801,055] <inf> event_manager: MODEM_EVT_LTE_CELL_UPDATE
    [00:00:02.493,225] <inf> event_manager: MODEM_EVT_LTE_CONNECTED
    [00:00:02.500,549] <inf> event_manager: MODEM_EVT_LTE_PSM_UPDATE
    [00:00:02.507,995] <dbg> cloud_module.state_set: State transition STATE_LTE_DISCONNECTED --> STATE_LTE_CONNECTED
    [00:00:02.519,165] <dbg> cloud_module.connect_cloud: Connecting to cloud
    [00:00:02.526,763] <wrn> cloud_module: Cloud connection establishment in progress
    [00:00:02.535,369] <wrn> cloud_module: New connection attempt in 32 seconds if not successful
    [00:00:02.545,104] <dbg> aws_iot_integration.aws_iot_event_handler: AWS_IOT_EVT_CONNECTING
    [00:00:02.554,229] <dbg> cloud_module.cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTING
    [00:00:02.563,415] <inf> event_manager: CLOUD_EVT_CONNECTING
    [00:00:06.347,198] <dbg> aws_iot_integration.aws_iot_event_handler: AWS_IOT_EVT_CONNECTED
    [00:00:06.545,806] <dbg> aws_iot_integration.aws_iot_event_handler: AWS_IOT_EVT_READY
    [00:00:06.570,129] <dbg> cloud_module.cloud_wrap_event_handler: CLOUD_WRAP_EVT_CONNECTED
    [00:00:06.606,109] <inf> event_manager: CLOUD_EVT_CONNECTED
    [00:00:06.613,922] <dbg> cloud_module.sub_state_set: Sub state transition SUB_STATE_CLOUD_DISCONNECTED --> SUB_STATE_CLOUD_CONNECTED
    [00:00:06.855,651] <inf> event_manager: DATA_EVT_DATE_TIME_OBTAINED
    [00:00:06.863,189] <inf> event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, GNSS, MOD_STAT)
    [00:00:06.904,235] <inf> event_manager: GPS_EVT_ACTIVE
    [00:00:06.910,369] <dbg> gps_module.sub_state_set: Sub state transition SUB_STATE_IDLE --> SUB_STATE_SEARCH
    [00:00:06.921,173] <dbg> gps_module.gps_event_handler: GPS_EVT_SEARCH_STARTED
    [00:00:06.929,229] <dbg> gps_module.gps_event_handler: GPS_EVT_AGPS_DATA_NEEDED
    [00:00:06.937,500] <inf> event_manager: GPS_EVT_AGPS_NEEDED
    [00:00:06.944,427] <dbg> sensor_module.environmental_data_get: No external sensors, submitting dummy sensor data
    [00:00:06.958,984] <inf> event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED
    [00:00:06.968,475] <inf> agps: SUPL is initialized
    [00:00:07.064,544] <inf> event_manager: MODEM_EVT_MODEM_STATIC_DATA_READY
    [00:00:07.147,796] <inf> agps: Starting SUPL session
    [00:00:07.216,156] <inf> event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY
    [00:00:07.245,758] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_modem_dynamic_buffer: Entry: 1 of 2 in dynamic modem buffer filled
    [00:00:07.558,776] <inf> event_manager: MODEM_EVT_BATTERY_DATA_READY
    [00:00:07.587,951] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_bat_buffer: Entry: 1 of 2 in battery buffer filled
    [00:00:07.892,944] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_BLOCKED
    [00:00:09.315,582] <inf> agps: SUPL session finished successfully
    [00:00:22.259,094] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_UNBLOCKED
    [00:00:35.329,620] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_BLOCKED
    [00:01:00.567,718] <inf> event_manager: APP_EVT_ACTIVITY_DETECTION_ENABLE
    [00:01:21.968,444] <inf> event_manager: DATA_EVT_DATA_READY
    [00:01:22.073,333] <inf> event_manager: DATA_EVT_DATA_SEND
    [00:01:22.080,322] <dbg> cloud_codec.cloud_codec_encode_batch_data: No data to encode, JSON string empty...
    [00:01:22.184,082] <wrn> cloud_module:  Data sent, data pointer: 0x200201e0
    [00:01:22.192,199] <inf> event_manager: CLOUD_EVT_DATA_ACK
    [00:01:41.464,813] <dbg> gps_module.gps_event_handler: GPS_EVT_SEARCH_TIMEOUT
    [00:01:41.472,900] <inf> event_manager: GPS_EVT_TIMEOUT
    [00:01:41.479,156] <inf> event_manager: GPS_EVT_INACTIVE
    [00:01:41.485,473] <dbg> gps_module.sub_state_set: Sub state transition SUB_STATE_SEARCH --> SUB_STATE_IDLE
    [00:01:41.496,337] <inf> event_manager: DATA_EVT_DATA_READY
    [00:01:41.503,387] <dbg> cloud_codec.cloud_codec_encode_data: No data to encode, JSON string empty...
    [00:07:35.488,983] <inf> event_manager: UI_EVT_BUTTON_ALARM_DATA_READY
    [00:07:35.496,520] <inf> event_manager: UI_EVT_BUTTON_DATA_READY
    [00:07:35.503,662] <inf> event_manager: APP_EVT_DATA_GET_ALL
    [00:07:35.510,498] <inf> app_module: Device mode: Passive
    [00:07:35.516,693] <inf> app_module: Start movement timeout: 1000 seconds interval
    [00:07:35.525,207] <inf> app_module: 60 seconds until movement can trigger a new data sample/publication
    [00:07:35.535,888] <inf> event_manager: APP_EVT_DATA_GET - Requested data types (MOD_DYN, BAT, ENV, GNSS)
    [00:07:35.546,752] <wrn> cloud_codec: set alarm ---> 1
    [00:07:35.556,518] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_ui_buffer: Entry: 1 of 2 in UI buffer filled
    [00:07:35.570,800] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_ui_buffer: Entry: 2 of 2 in UI buffer filled
    [00:07:35.606,475] <inf> event_manager: DATA_EVT_UI_DATA_READY
    [00:07:35.613,403] <inf> event_manager: DATA_EVT_UI_DATA_READY
    [00:07:35.620,330] <inf> event_manager: GPS_EVT_ACTIVE
    [00:07:35.643,585] <dbg> gps_module.sub_state_set: Sub state transition SUB_STATE_IDLE --> SUB_STATE_SEARCH
    [00:07:35.654,571] <dbg> sensor_module.environmental_data_get: No external sensors, submitting dummy sensor data
    [00:07:35.665,771] <inf> event_manager: SENSOR_EVT_ENVIRONMENTAL_NOT_SUPPORTED
    [00:07:35.690,826] <inf> event_manager: DATA_EVT_UI_DATA_SEND
    [00:07:35.707,885] <inf> event_manager: UI_EVT_BUTTON_ALARM_DATA_READY
    [00:07:35.699,401] <dbg> cloud_module.ui_data_send: UI sent, data pointer: 0x2001fbf8
    [00:07:35.716,247] <inf> event_manager: CLOUD_EVT_DATA_ACK
    [00:07:35.723,052] <wrn> cloud_codec: set alarm ---> 1
    [00:07:35.729,187] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_ui_buffer: Entry: 0 of 2 in UI buffer filled
    [00:07:35.830,505] <inf> event_manager: DATA_EVT_UI_DATA_READY
    [00:07:35.852,386] <inf> event_manager: DATA_EVT_UI_DATA_SEND
    [00:07:35.863,189] <dbg> cloud_module.ui_data_send: UI sent, data pointer: 0x2001fc40
    [00:07:35.875,549] <inf> event_manager: CLOUD_EVT_DATA_ACK
    [00:07:36.300,201] <inf> event_manager: MODEM_EVT_MODEM_DYNAMIC_DATA_READY
    [00:07:36.308,563] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_modem_dynamic_buffer: Entry: 2 of 2 in dynamic modem buffer filled
    [00:07:36.407,684] <inf> event_manager: UI_EVT_BUTTON_ALARM_DATA_READY
    [00:07:36.425,537] <wrn> cloud_codec: set alarm ---> 0
    [00:07:36.469,940] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_ui_buffer: Entry: 1 of 2 in UI buffer filled
    [00:07:36.487,152] <inf> event_manager: DATA_EVT_UI_DATA_READY
    [00:07:36.508,880] <inf> event_manager: DATA_EVT_UI_DATA_SEND
    [00:07:36.517,120] <dbg> cloud_module.ui_data_send: UI sent, data pointer: 0x2001fc00
    [00:07:36.528,594] <inf> event_manager: CLOUD_EVT_DATA_ACK
    [00:07:36.579,010] <inf> event_manager: MODEM_EVT_BATTERY_DATA_READY
    [00:07:36.586,791] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_bat_buffer: Entry: 2 of 2 in battery buffer filled
    [00:07:36.639,862] <inf> event_manager: UI_EVT_BUTTON_ALARM_DATA_READY
    [00:07:36.647,430] <wrn> cloud_codec: set alarm ---> 1
    [00:07:36.653,625] <dbg> cloud_codec_ringbuffer.cloud_codec_populate_ui_buffer: Entry: 2 of 2 in UI buffer filled
    [00:07:36.665,008] <inf> event_manager: DATA_EVT_UI_DATA_READY
    [00:07:36.684,600] <inf> event_manager: DATA_EVT_UI_DATA_SEND
    [00:07:36.700,531] <dbg> cloud_module.ui_data_send: UI sent, data pointer: 0x2001fc00
    [00:07:36.709,320] <inf> event_manager: CLOUD_EVT_DATA_ACK
    [00:08:05.594,970] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_UNBLOCKED
    [00:08:10.650,787] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_BLOCKED
    [00:08:29.078,704] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_UNBLOCKED
    [00:08:34.143,585] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_BLOCKED
    [00:08:35.535,797] <inf> event_manager: APP_EVT_ACTIVITY_DETECTION_ENABLE
    [00:08:50.678,161] <inf> event_manager: DATA_EVT_DATA_READY
    [00:08:50.711,395] <inf> event_manager: DATA_EVT_DATA_SEND
    [00:08:50.718,383] <dbg> cloud_codec.cloud_codec_encode_batch_data: No data to encode, JSON string empty...
    [00:08:50.733,062] <wrn> cloud_module:  Data sent, data pointer: 0x2001fd80
    [00:08:50.741,271] <inf> event_manager: CLOUD_EVT_DATA_ACK
    [00:08:52.627,044] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_UNBLOCKED
    [00:08:56.790,222] <dbg> gps_module.gps_event_handler: GPS_EVT_OPERATION_BLOCKED
    [00:09:26.429,962] <dbg> gps_module.gps_event_handler: GPS_EVT_SEARCH_TIMEOUT
    [00:09:26.438,018] <inf> event_manager: GPS_EVT_TIMEOUT
    [00:09:26.444,305] <inf> event_manager: GPS_EVT_INACTIVE
    [00:09:26.450,592] <dbg> gps_module.sub_state_set: Sub state transition SUB_STATE_SEARCH --> SUB_STATE_IDLE
    [00:09:26.461,761] <inf> event_manager: DATA_EVT_DATA_READY
    [00:09:26.468,780] <dbg> cloud_codec.cloud_codec_encode_data: No data to encode, JSON string empty...
    trace-2021-10-11T19-45-20.101Z.rar
  • There were some problems with the trace, so I was not able to take a proper look at the IP packets.
    However, I couldn't see anything that looked wrong in your trace. And in both the trace and the log it looks like the communication with the cloud continued as it should?
    Also, when you take a modem trace, it is nice if you restart the device after starting capturing the trace, so that we can see the startup sequence as well.
  • Hey Didrik, thanks for your reply. I did some experiments with two different network operators. I disabled PSM and changed Mqtt_keep alive to 400sec.
    In the first operator ( KPN in NL ) the server doesn't receive any data after 300 sec even device shows that data is sent successfully.
    The second operator ( T-Mobile in NL): the device gets a timeout after 320sec and then it tries to establish the connection again with the server and every 320sec it gets event Timeout and re-initializes connection with server-side.
    Here below are the trace files per operator, hopefully, that you can find the problem.
    KPN
    trace-2021-10-13T21-39-09.599Z KPN.rar
    T Mobile
    trace-2021-10-13T21-20-33.087Z TMobile.rar
    thanks in advance!
