subscribing in Assert tracker v2
I'm trying to send messages from the cloud (AWS-IoT ) to the device, so I modified the device so that it subscribes to a new topic and when I send messages from could, it seems that the device doesn't listen frequently to the cloud. sometimes it receives a message, sometimes not. and when I sent multi messages very fast, the device receive all messages after a random delay.
I tried to check the code if there is any configuration I can use to force the device to listen to Cloud always. but without luck. This behavior is in Active and Passive mode as well.
My question is: How can the device receive messages instantly from the cloud without delay.
Thanks in advance.
  • The KPN trace looks better this time, but it doesn't look like it captured the device waking up. The trace ended only  a minute after the SUPL session completed. And the SUPL session ended just a couple of seconds after the last packet sent to the cloud. The whole trace lasts for only a bit less than 2 minutes.
    The T Mobile trace on the other hand looks like have captured the issue. But, it looks like the device is still requesting PSM, even though the application doesn't request it. This is probably because the modem has the PSM settings stored. The easiest way to tell the modem not to use PSM is to flash the at_cmd sample, send AT+CPSMS=0 followed by AT+CFUN=0.
  • Hi, have you been able to capture traces without PSM yet?
  • Hey Didrik, sorry for my late message. I was actually struggling with GPS timeout that sometimes tracker keeps searching for GPS fix for more than one hour and GPS timeout is already adjusted on 60 sec but that is for another issue. For now, I've tested the devices with/without PSM and I've noticed that without PSM the connection with the server still opens but the device sends an update message per 26 min instead of 60 min since the settings are adjusted to 3600 sec. Here below are the traces files
    trace-2021-10-24T07-58-11.071Z without psm.rar
    trace-2021-10-24T14-09-26.958Z with psm.rar
  • Here is what the modem team said:
    With given information I am not able to comment anything very meaningful. TLS connection is established and UE sends 708 bytes to server. This is acked by the server, but nothing more really. Seems that server is not responding or data is lost somewhere in the path.
    After twenty minutes there are weird TCP transmission to unseen segments. I think the log is not complete and some parts are missing. TCP segment from UE to server jumps from 185 to 3018 which is not possible.
    At this point, I feel like the ticket has gone on long enough that it is time to take a tep back and try to get an overview of where we are. Could you try to sum up the problem you are seeing?
    What are you trying to do, and what is happening?
    What application FW are you suing, which SDK version is it based on, and what modem FW version are you using?
  • Hey Didrik,
    You are right this issue took a long time. here is the summarize of the problem when CONFIG_MQTT_KEEPALIVE is set for more than 300 sec then the server ( AWS IoT ) doesn't receive any message from the device, even though the device log shows that message is sent successfully.
    we tried with T-mobile and KPN in NL and both are almost the same except in the T-mobile network the device lost connection after 300 sec when CONFIG_MQTT_KEEPALIVE > 300 sec. but in the KPN network the device doesn't show any error. In both networks, the server doesn't receive anything after 300 sec
    our project is based on Low power consumption so we need to set CONFIG_MQTT_KEEPALIVE  to a max of AWS limit and that is 1200 sec. but it doesn't work when it is initialized for more than 300 sec.
    we use
    SDK = nrf 1.6.1,
    modem version 1.3.0
    Mqtt server: AWS Iot mqtt
    LTE-M network: KPN and T-mobile in NL
    app: asset_tracker_v2
