what happened when I create a kernel timer (based on the 32k RTC) by nrf connect sdk on nrf 52840 dk?
static const struct k_timer my_timer;
static const struct k_work my_work;
void my_work_handler(struct k_work *work)
printk("timer is clock! /n");
void my_timer_handler(struct k_timer *dummy)
//k_work_submit(&my_work);
//printk("timer is clock! /n");
return;
void main(void)
int err = 0;
// K_WORK_DEFINE(my_work, my_work_handler);
k_timer_init(&my_timer, my_timer_handler, NULL);
/* start periodic timer that expires once every second */
k_timer_start(&my_timer, K_SECONDS(1), K_SECONDS(1));
when run the system, the fault information is:
*** Booting Zephyr OS build v2.6.0-rc1-ncs1 ***
[00:00:09.937,286] [1;31m<err> os: ***** USAGE FAULT *****[0m
[00:00:09.937,316] [1;31m<err> os: Illegal use of the EPSR[0m
[00:00:09.937,316] [1;31m<err> os: r0/a1: 0x0002c2a8 r1/a2: 0x200021d0 r2/a3: 0x200021d0[0m
[00:00:09.937,316] [1;31m<err> os: r3/a4: 0x00000000 r12/ip: 0x00033bf7 r14/lr: 0x00023983[0m
[00:00:09.937,316] [1;31m<err> os: xpsr: 0x60000021[0m
[00:00:09.937,347] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00000000[0m
[00:00:09.937,347] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0[0m
[00:00:09.937,347] [1;31m<err> os: Fault during interrupt handling
[0m
[00:00:09.937,347] [1;31m<err> os: Current thread: 0x200021d0 (unknown)[0m
[00:00:10.211,669] [1;31m<err> fatal_error: Resetting system[0m
thank you very much!
     The registers here give you an indication on what the state was when the fault occurred.
    Could you try to resolve the flash mapped addresses using "arm-none-eabi-addr2line"?
    arm-none-eabi-addr2line -e my_build_folder/zephyr/zephyr.elf 0x23983
    arm-none-eabi-addr2line -e my_build_folder/zephyr/zephyr.elf 0x2c2a8
    arm-none-eabi-addr2line -e my_build_folder/zephyr/zephyr.elf 0x33bf7
    Håkon
