UART transmission seems to be working weirdly
I created a simple driver call for UART transmission and when I debug the program and put breakpoints at every transmission, it seems to work fine (I see the characters sent being printed to the serial console) but when I run the program without any breakpoints, all I see is "?" being printed to the console.
The receiver part works fine: as soon as I enter a character in serial, I see an IRQ handler getting fired where the value is read off RXD register.
// main.cpp
Uart uart;
int main()
    char s[] = "hello";
    uart.StartTx((uint8_t *) s, strlen(s));
// uart.cpp
bool Uart::getNrfEventStatus(nrf_uart_event_t reg) const
    return (bool) *(volatile uint32_t *)((uint8_t *)pUARTx + (uint32_t)reg);
void Uart::TxByte(uint8_t byte)
        setNrfEvent(NRF_UART_EVENT_TXDRDY, 0);
        pUARTx->TXD = byte;
void Uart::TxBlocking(uint8_t *buffer, size_t bytesToSend)
    for (uint8_t idx = 0; idx < bytesToSend; idx++)
        TxByte(buffer[idx]);    // NRF_UART_EVENT_TXDRDY is set right after writing to TXD
        bool volatile txdRdyEvnt = getNrfEventStatus(NRF_UART_EVENT_TXDRDY);
while (txdRdyEvnt);     // wait till NRF_UART_EVENT_TXDRDY is reset in IRQ handler
 void Uart::StartTx(uint8_t *buffer, size_t bytesToSend)
      setNrfEvent(NRF_UART_TASK_STARTTX, 1);   // trigger NRF_UART_TASK_STARTTX
      TxBlocking(buffer, bytesToSend);
      setNrfEvent(NRF_UART_TASK_STOPTX, 1);
void Uart::setNrfEvent(T reg, uint32_t value) // TODO - change fctn name
      *((volatile uint32_t *)((uint8_t *)pUARTx + (uint32_t)reg)) = value;
       #if __CORTEX_M == 0x04
       volatile uint32_t dummy = *( (volatile uint32_t *) ((uint8_t *)pUARTx + (uint32_t)reg) );
       (void)dummy;
Thanks for the help
  • Well, the issue certainly was with the flags.
    - First issue: `while (txdRdyEvnt); `isn't taking into account the updated value.
    - Second: the following flow and disabling TxdRdy interrupt flag did the trick!
            while (getNrfEventStatus(NRF_UART_EVENT_TXDRDY) == 0);
