UART transmission seems to be working weirdly
I created a simple driver call for UART transmission and when I debug the program and put breakpoints at every transmission, it seems to work fine (I see the characters sent being printed to the serial console) but when I run the program without any breakpoints, all I see is "?" being printed to the console.
The receiver part works fine: as soon as I enter a character in serial, I see an IRQ handler getting fired where the value is read off RXD register.
// main.cpp
Uart uart;
int main()
    char s[] = "hello";
    uart.StartTx((uint8_t *) s, strlen(s));
// uart.cpp
bool Uart::getNrfEventStatus(nrf_uart_event_t reg) const
    return (bool) *(volatile uint32_t *)((uint8_t *)pUARTx + (uint32_t)reg);
void Uart::TxByte(uint8_t byte)
        setNrfEvent(NRF_UART_EVENT_TXDRDY, 0);
        pUARTx->TXD = byte;
void Uart::TxBlocking(uint8_t *buffer, size_t bytesToSend)
    for (uint8_t idx = 0; idx < bytesToSend; idx++)
        TxByte(buffer[idx]);    // NRF_UART_EVENT_TXDRDY is set right after writing to TXD
        bool volatile txdRdyEvnt = getNrfEventStatus(NRF_UART_EVENT_TXDRDY);
while (txdRdyEvnt);     // wait till NRF_UART_EVENT_TXDRDY is reset in IRQ handler
 void Uart::StartTx(uint8_t *buffer, size_t bytesToSend)
      setNrfEvent(NRF_UART_TASK_STARTTX, 1);   // trigger NRF_UART_TASK_STARTTX
      TxBlocking(buffer, bytesToSend);
      setNrfEvent(NRF_UART_TASK_STOPTX, 1);
void Uart::setNrfEvent(T reg, uint32_t value) // TODO - change fctn name
      *((volatile uint32_t *)((uint8_t *)pUARTx + (uint32_t)reg)) = value;
       #if __CORTEX_M == 0x04
       volatile uint32_t dummy = *( (volatile uint32_t *) ((uint8_t *)pUARTx + (uint32_t)reg) );
       (void)dummy;
Thanks for the help
  • Hi
    The first thing that comes to mind is that you might be using different baud rates in the application and terminal which would cause jibberish data. Alternatively, are there some problems with the ASCII conversion perhaps.
    Simon
  • Again, if baud rates were different, I probably wouldn't have seen the expected output with the breakpoints set. Same reasoning with ASCII conversion. Do you see any issues with the way I'm using the flags?
  • Hi
    Not that I can see, no. Are the characters that are printed actual question marks "?" or just jibberish (broken characters and such)? What baud rate are you trying to print on exactly? It could be that the device isn't able to print correctly when running "full speed"  at too high of a baud rate for instance and is only able to print one character successfully at a time (which is why the breakpoints succeed).
    Simon
  • it literally just prints "?". I am running at 115200. I am trying to narrow down the potential cause(s) here...
  • What pins are you using for UART transmissions? Is there a way to reproduce this on an nRF52 DK or do you only see it on a custom board?
    Simon
