nRF Connect VS Code extension no connected devices
I recently installed the nRF Connect extension for VS Code on my Mac M1. I am unable to see my connected board as part of the nRF Connect extension.
Setup
  • nrfjprog version: 10.14.0 external
  • JLinkARM.dll version: 7.54c
  • M1 Macbook
Something odd I noticed is when I ran the nrfjprog command in the terminal I get:
nrfjprog --version --log
ERROR: [SeggerBackend] - The J-Link library does not support execution inside rosetta 2. Try executing with arch -arch arm64 nrfjprog...
ERROR: An internal error has occurred, please try again.
If I run with the suggested option then it completes successfully:
arch -arch arm64 nrfjprog -v
I am then also able to see the serial number of the debugger connected:
arch -arch arm64 nrfjprog --ids
683511319
Am I missing something in my VS Code setup? Is there a known issue with the VS Code extension on M1 mac?
  • Glad I found this post! I'm experiencing the same issue. -- Steve
  • I am having the same issue!
    "tools": {
    "jlink": null,
    "nrfjprog": null,
    "cmake": null,
    "west": null,
    "python": "3.8.9",
    "ninja": null,
    "gperf": "3.0.3",
    "dtc": null,
    "gnuarmemb": null,
    "gn": null
    "environment": {
    "westExe": "/opt/nordic/ncs/v1.7.0/toolchain/bin/west",
    "westEnv": {
    "ELECTRON_RUN_AS_NODE": "1",
    "GIT_EXEC_PATH": "/opt/nordic/ncs/v1.7.0/toolchain/Cellar/git/2.32.0_1/libexec/git-core",
    "HOME": "/Users/ndelafuente",
    "PATH": "/opt/nordic/ncs/v1.7.0/toolchain/bin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin",
    "ZEPHYR_BASE": "/opt/nordic/ncs/v1.7.0/zephyr",
    "GNUARMEMB_TOOLCHAIN_PATH": "/opt/nordic/ncs/v1.7.0/toolchain",
    "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
    "USER": "ndelafuente"
    "toolchainPath": "/opt/nordic/ncs/v1.7.0/toolchain",
    "toolchainBinPath": "/opt/nordic/ncs/v1.7.0/toolchain/bin",
    "toolchainVersion": "1.7.0"
  • I am on windows and experiencing a similar issue after switching to nrf connect extension.
    The "tools" in the json settings all show a null.
    Might help with debugging this issue
    After adding
    "terminal.integrated.inheritEnv": false
    to my vsc setting.json I get :
    "tools": {
    "jlink": null,
    "nrfjprog": null,
    "cmake": "3.21.3",
    "west": "0.11.1",
    "python": "3.10.0",
    "ninja": "1.10.2",
    "gperf": "3.1",
    "dtc": null,
    "gnuarmemb": null,
    "gn": null
    And connected devices show up but unable to flash since nrfjprog still isnt detected properly.
    Might be worth mentioning that the first flash with using the extension worked before changign vsc settings. Subsequent tries failed.
    EDIT:
    Reinstalling nrf connect and nrf terminal extensions in vsc fixed my issues on windows for now.
  • I was able to fix this issue on windows 10 by installing the nRF Command Line Tools.
    www.nordicsemi.com/.../Download
  • This is a different issue than the original poster and I have. Ours is caused by the fact that we are using MacBook M1 devices, and the toolchain has some components that do not work under the MacBook M1. We look forward to this being updated. -- Steve
