QSPI seems to still occupy its pins even if it is disabled.
I'am working on nrf52840 and base on a sample hci_spi. I use spi1 and tried several different pins, they all works fine.
but when i disable qspi and try to use the pins originally used by qspi, my spi1 failed.
.dts attached, test to use p0.19 as sck-pin.
2677.zephyr.dts
  • Would you be able to upload a simiplified sample that demonstrates your issue, such that I can investigate it on my side.
    Simon
  • i also tried some other samples, they all have the same symptom.
    it's just the p0.19 to p0.23 can't be controlled.
    I tested on nRF52840-DK board, i'm not sure if it's because of HW configuration.
    i simply use a sample in SDK, (ncs\1.6.1\nrf\sample\peripheral_uart) and add some simple GPIO control codes to test, as below:
    const struct device *gpio_devs;
    gpio_devs = device_get_binding("GPIO_0");
    gpio_pin_configure(gpio_devs, 19, GPIO_OUTPUT);
    if(xx)
    xx=0;
    else xx=1;
    if (xx)
    gpio_pin_set(gpio_devs,19,1);
    gpio_pin_set(gpio_devs,19,0);
    i put test code in the void ble_write_thread() so that when i tap Enter on uart terminal, the gpio level switches. it works on most other GPIOs but p0.19 to p0.23.
  • Problem solved, i review the schematic of  nRF52840-DK, and find the p0.19 is not connected to gpio header(p24) by default, it is connected to flash. so after i cut the solder bridge SB11 and short SB21, it works.
