ble button function
When i intially burn the code on dk, my dk should be in system off mode ie all functionality should be off. Then i want to press a button for 5 seconds with which the device blinks an led pattern. and if uptil  not 5 seconds button not pressed then nothing occurs and device remains in sleep mode
  • I am unable to create a timer setting for  button press which detects that 5 seconds when done the device will start advertising. in example u shared in that 5 seconds thing is not there. pls assist at earliest
    Yes, the example here only shows the powerdown and wake-on-button-press GPIOTE PORT event, you will have to add this along with the app_timer to your BLE example if not already present. Keep in mind that I recommended this approach when I thought you just wanted to blink some LEDs - not knowing that you wanted to do advertising following the 5 second press. In this case I would instead recommend that you begin with one of the BLE examples, and then merge this functionality into it.
    I see from your other ticket that you are using the bsp module instead of the app_timer and app_buttons, which means you likely already are working out of an SDK example. Which example is this?
    If you wish to use the bsp module you can change the BSP_LONG_PUSH_TIMEOUT_MS in bsp_config to 5000 ms, and then use the bsp_event_to_button_action_assign function to assign an event to the button's long push, and then have your bsp_event_handler in main.c begin advertising when it receives this event.
    Try this, and let me know if you are able to start advertising following a 5 second button press.
    Keep in mind that all 'long button presses' then will be 5 seconds long.
    Karl
    Karl i am using nrf sdk 17.1.0 examples/ble_peripherals/template nrf dk nrf52832. and s132.
    I want a that when i flash the code my device should be in system off mode,
    Then when i press  a button for 5 secs then it should start advertising. and if not pressed for 5 secs it should remian in sleep mode.  i have used the BSP_LONG_PUSH_TIMEOUT_MS in bsp_config to 5000 ms but it is not working. pls assist am attaching the code as
    #include <stdbool.h>
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "sensorsim.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "bsp.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define DEVICE_NAME "Nordic_Template" /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
    #define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
    #define SLAVE_LATENCY 0 /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND 1 /**< Perform bonding. */
    #define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
    #define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
    #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define BT0_LONG_PUSH BSP_EVENT_KEY_0
    static bool startup= true; /**< flag for startup mode. */
    NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
    /* YOUR_JOB: Declare all services structure your application is using
    * BLE_XYZ_DEF(m_xyz);
    // YOUR_JOB: Use UUIDs for service(s) used in your application.
    static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    //static void advertising_start(bool erase_bonds);
    /**@brief Callback function for asserts in the SoftDevice.
    * how your product is supposed to react in case of Assert.
    * @param[in] line_num Line number of the failing ASSERT call.
    * @param[in] file_name File name of the failing ASSERT call.
    static void advertising_start()
    ret_code_t ret;
    ret = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    APP_ERROR_CHECK(ret);
    /**@brief Function for the Timer initialization.
    * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
    // Initialize timer module.
    // Create timers.
    /* YOUR_JOB: Create any timers to be used by the application.
    Below is an example of how to create a timer.
    For every new timer needed, increase the value of the macro APP_TIMER_MAX_TIMERS by
    one.
    ret_code_t err_code;
    err_code = app_timer_create(&m_app_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
    APP_ERROR_CHECK(err_code); */
    * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
    * device including the device name, appearance, and the preferred connection parameters.
    ble_gap_conn_params_t gap_conn_params;
    (const uint8_t *)DEVICE_NAME,
    strlen(DEVICE_NAME));
    /* YOUR_JOB: Use an appearance value matching the application's use case.
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_);
    gap_conn_params.slave_latency = SLAVE_LATENCY;
    gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    * application about an error.
    * @param[in] nrf_error Error code containing information about what went wrong.
    APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the YYY Service events.
    * YOUR_JOB implement a service handler function depending on the event the service you are using can generate
    * @details This function will be called for all YY Service events which are passed to
    * the application.
    * @param[in] p_yy_service YY Service structure.
    * @param[in] p_evt Event received from the YY Service.
    static void on_yys_evt(ble_yy_service_t * p_yy_service,
    ble_yy_service_evt_t * p_evt)
    switch (p_evt->evt_type)
    case BLE_YY_NAME_EVT_WRITE:
    APPL_LOG("[APPL]: charact written with value %s. ", p_evt->params.char_xx.value.p_str);
    // No implementation needed.
    /* YOUR_JOB: Add code to initialize the services used by the application.
    ble_xxs_init_t xxs_init;
    ble_yys_init_t yys_init;
    // Initialize XXX Service.
    memset(&xxs_init, 0, sizeof(xxs_init));
    xxs_init.evt_handler = NULL;
    xxs_init.is_xxx_notify_supported = true;
    xxs_init.ble_xx_initial_value.level = 100;
    err_code = ble_bas_init(&m_xxs, &xxs_init);
    // Initialize YYY Service.
    memset(&yys_init, 0, sizeof(yys_init));
    yys_init.evt_handler = on_yys_evt;
    yys_init.ble_yy_initial_value.counter = 0;
    err_code = ble_yy_service_init(&yys_init, &yy_init);
    /**@brief Function for handling the Connection Parameters Module.
    * @details This function will be called for all events in the Connection Parameters Module which
    * are passed to the application.
    * @note All this function does is to disconnect. This could have been done by simply
    * setting the disconnect_on_fail config parameter, but instead we use the event
    * handler mechanism to demonstrate its use.
    * @param[in] p_evt Event received from the Connection Parameters Module.
    /**@brief Function for handling a Connection Parameters error.
    cp_init.p_conn_params = NULL;
    cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
    cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
    cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
    cp_init.disconnect_on_fail = false;
    cp_init.evt_handler = on_conn_params_evt;
    cp_init.error_handler = conn_params_error_handler;
    /**@brief Function for starting timers.
    static void application_timers_start(void)
    /* YOUR_JOB: Start your timers. below is an example of how to start a timer.
    err_code = app_timer_start(m_app_timer_id, TIMER_INTERVAL, NULL);
    // Prepare wakeup buttons.
    * @param[in] ble_adv_evt Advertising event.
    switch (ble_adv_evt)
    case BLE_ADV_EVT_FAST:
    NRF_LOG_INFO("Fast advertising.");
    case BLE_ADV_EVT_IDLE:
    sleep_mode_enter();
    * @param[in] p_ble_evt Bluetooth stack event.
    * @param[in] p_context Unused.
    ret_code_t err_code = NRF_SUCCESS;
    NRF_LOG_INFO("Disconnected.");
    case BLE_GAP_EVT_CONNECTED:
    NRF_LOG_INFO("Connected.");
    ble_gap_phys_t const phys =
    .rx_phys = BLE_GAP_PHY_AUTO,
    .tx_phys = BLE_GAP_PHY_AUTO,
    } break;
    case BLE_GATTC_EVT_TIMEOUT:
    case BLE_GATTS_EVT_TIMEOUT:
    uint32_t ram_start = 0;
    // Enable BLE stack.
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
    static void advertising_init()
    ble_advertising_init_t init;
    init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance = true;
    init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids = m_adv_uuids;
    init.config.ble_adv_fast_enabled = true;
    init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
    * @param[in] event Event generated when button is pressed.
    static void bsp_event_handler(bsp_event_t event)
    switch (event)
    case BT0_LONG_PUSH:
    if(startup)
    { // first time advertising mode
    //Initialising functions for BLE
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    advertising_start();
    else{
    NRF_LOG_INFO("Data logging Mode.");
    case BSP_EVENT_SLEEP:
    sleep_mode_enter();
    break; // BSP_EVENT_SLEEP
    case BSP_EVENT_DISCONNECT:
    break; // BSP_EVENT_DISCONNECT
    case BSP_EVENT_WHITELIST_OFF:
    break; // BSP_EVENT_KEY_0
    * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
    static void buttons_leds_init()
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_LONG_PUSH, BT0_LONG_PUSH);
    static void log_init(void)
    nrf_pwr_mgmt_run();
    /**@brief Function for application main entry.
    log_init(); // no need for final project
    timers_init();
    buttons_leds_init();
    power_management_init();
    ble_stack_init();
    // Initialize.
    // advertising_start(erase_bonds);
    // Enter main loop.
    for (;;)
    idle_state_handle();
    Please always use the Insert -> Code option when sharing code here in DevZone.
    When you have implemented the check for the 5 seconds button press the device should always go into S
    Thank you for specifying.
    This is one way you could go about implementing this:
    In the timers_init you should create and start a 5 second timer that will call sleep_mode_enter when it expires.
    You should then have the 5 second button long push stop this timer, and start the advertising. The button_led_init should therefore happen before the timers_init, so that the button press always leads the sleep timer.
    You will also need to check whether the extracted startup event in the button_leds_init was the 5 second button, and if so you need to call the bsp_button_event_handler manually with the extracted startup event. You should also consider what the correct handling for if the button is released before 5 seconds has passed, but then immediately pressed again. Should this restart the sleep timer, for example?
    Also, what is the timer_timeout_handler function?
    Please try this, and let me know if you achieve the desired functionality.
    Karl
  • Hi Karl,
    I have nrf53832 dev kit sft devc s132 and sdk 17.1.0
    i have a code where initially the system is off
    then i press button 1 on dev kit for 5 secs then the led 1 glows.
    also, if multiply by 2 in this value 65534*100 i can press button for 10 secs and then the led 1 glows and works as desired.BOTH SENSOR - system off.rar
    My issue is that from where this 65534 value is comming which sets button press to be 5 secs. Like my issue is that now i want tht i should press button for say 3 secs then what will i use?
