I have this project where I have managed to build and flash my code onto the controller. I copied the example code from blinky (that didn't work) to my main.c and then I changed some pins, still didn't work. So what I tried was that I searched up and came across nrf_bpio_cfg_output and nrf_gpio_pin_set/clear in order to set and clear my pins. The problem still persists, I don't know if has something to do with setting the wrong output pin or something, I really don't know. Even tried multiple pins.
I want the output to be on pin 7, or pin name P0.03. On my nRF51802 chip mounted on a custom board.
I'm using "nRF51 SDK v10.0.0" and gcc compiler, therefore without IDE.
main.c:
/* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved. * * The information contained herein is property of Nordic Semiconductor ASA. * Terms and conditions of usage are described in detail in NORDIC * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT. * * Licensees are granted free, non-transferable use of the information. NO * WARRANTY of ANY KIND is provided. This heading must NOT be removed from * the file. * */ /** @file * * @defgroup blinky_example_main main.c * @{ * @ingroup blinky_example * @brief Blinky Example Application main file. * */ #define BUZZPIN 25 #define LEDPIN 3 #include <stdbool.h> #include <stdint.h> #include "nrf_delay.h" #include "nrf_gpio.h" // #include "boards/boards.h" // const uint8_t leds_list[LEDS_NUMBER] = LEDS_LIST; /** * @brief Function for application main entry. */ int main(void) { /* // Configure LED-pins as outputs. LEDS_CONFIGURE(LEDS_MASK); // Toggle LEDs. while (true) { for (int i = 0; i < LEDS_NUMBER; i++) { LEDS_INVERT(1 << leds_list[i]); nrf_delay_ms(500); } }*/ nrf_gpio_cfg_output(LEDPIN); while (1) { nrf_gpio_pin_set(LEDPIN); // turn it on nrf_delay_ms(500); nrf_gpio_pin_clear(LEDPIN); // turn it off nrf_delay_ms(500); } } /** @} */
