Hey all,
I've been learning/working on the 53 and have had some issues adding in the AMG8 example.
i've gotten the sensor to work flawlessly on an STM32 & nordic 52 but am unable to get it going on zephyr.
My log when running looks like this
*** Booting Zephyr OS build v2.6.0-rc1-ncs1 *** i2c1 SCL = 35 SDA = 34 device: 0x20000158, name: I2C_1 [00:00:00.263,336] [1;31m<err> os: ***** USAGE FAULT *****[0m [00:00:00.263,366] [1;31m<err> os: Illegal use of the EPSR[0m [00:00:00.263,366] [1;31m<err> os: r0/a1: 0x20000158 r1/a2: 0x00000038 r2/a3: 0x00000001[0m [00:00:00.263,366] [1;31m<err> os: r3/a4: 0x00000000 r12/ip: 0x0000000a r14/lr: 0x0000052b[0m [00:00:00.263,366] [1;31m<err> os: xpsr: 0x08000000[0m [00:00:00.263,366] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00000000[0m [00:00:00.263,397] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0[0m [00:00:00.263,397] [1;31m<err> os: Current thread: 0x20000320 (unknown)[0m [00:00:00.319,244] [1;31m<err> fatal_error: Resetting system[0m
* Copyright (c) 2017 PHYTEC Messtechnik GmbH
#include <zephyr.h>
#include <device.h>
#include <drivers/sensor.h>
#include <sys/printk.h>
////NOTE added
#include <devicetree.h>
#include <drivers/gpio.h>
#include <drivers/i2c.h>
#include <dt-bindings/i2c/i2c.h>
#include <nrfx_twim.h>
#include <sys/util.h>
#define Amg88xx_i2c DT_NODELABEL(i2c1)
static struct sensor_value temp_value[64];
#define READERBUFFER_SIZE 5
#define WRITERBUFFER_SIZE 6
uint8_t* readerBuffer = (uint8_t*)0x20000000;
uint8_t* writerBuffer = (uint8_t*)0x20000005;
//uint8_t readerBuffer[READERBUFFER_SIZE] __at__ 0x20000000;
//uint8_t writerBuffer[WRITERBUFFER_SIZE] __at__ 0x20000005;
#ifdef CONFIG_AMG88XX_TRIGGER
K_SEM_DEFINE(sem, 0, 1);
static void trigger_handler(const struct device *dev,
struct sensor_trigger *trigger)
ARG_UNUSED(dev);
ARG_UNUSED(trigger);
k_sem_give(&sem);
void print_buffer(void *ptr, size_t l)
struct sensor_value *tv = ptr;
int ln = 0;
printk("---|");
for (int i = 0; i < 8; i++) {
printk(" %02d ", i);
printk("\n");
printk("%03d|", ln);
for (int i = 0; i < l; i++) {
printk("%05d ", (tv[i].val1 * 100 + tv[i].val2 / 10000));
if (!((i + 1) % 8)) {
printk("\n");
ln++;
printk("\n");
uint32_t twim_conf_reg;
uint32_t twim_conf_reg1;
void main(void)
int ret;
//const struct device *dev = device_get_binding(DT_LABEL(DT_INST(0, AMG88XX)));
const struct device *dev =device_get_binding(DT_LABEL(Amg88xx_i2c));
if (dev == NULL) {
printk("Could not get AMG88XX device\n");
return;
// //// Configuring the READER channel
//NRF_TWIM1->RXD.PTR = READERBUFFER_SIZE;
//NRF_TWIM1->RXD.PTR = (uint32_t)&readerBuffer;
////// Configure the WRITER channel
//NRF_TWIM1->TXD.MAXCNT = WRITERBUFFER_SIZE;
//NRF_TWIM1->TXD.PTR = (uint32_t)&writerBuffer;
// twim_conf_reg = NRF_TWIM1->RXD.PTR;
// printk("i2c1 %x \n" ,twim_conf_reg);
// twim_conf_reg1= NRF_TWIM1->TXD.PTR;
// printk("i2c1 rxd %x txd %x \n" ,twim_conf_reg,twim_conf_reg1);
twim_conf_reg = NRF_TWIM1->PSEL.SCL;
twim_conf_reg1= NRF_TWIM1->PSEL.SDA;
printk("i2c1 SCL = %d SDA = %d \n" ,twim_conf_reg,twim_conf_reg1);
printk("device: %p, name: %s\n", dev, dev->name);
K_MSEC(300);
struct sensor_value attr = {
.val1 = 27,
.val2 = 0,
if (sensor_attr_set(dev, SENSOR_CHAN_AMBIENT_TEMP,
SENSOR_ATTR_UPPER_THRESH, &attr)) {
printk("Could not set threshold\n");
return;
struct sensor_trigger trig = {
.type = SENSOR_TRIG_THRESHOLD,
.chan = SENSOR_CHAN_AMBIENT_TEMP,
if (sensor_trigger_set(dev, &trig, trigger_handler)) {
printk("Could not set trigger\n");
return;
while (42) {
printk("Waiting for a threshold event\n");
k_sem_take(&sem, K_FOREVER);
ret = sensor_sample_fetch(dev);
if (ret) {
printk("Failed to fetch a sample, %d\n", ret);
return;
ret = sensor_channel_get(dev, SENSOR_CHAN_AMBIENT_TEMP,
(struct sensor_value *)temp_value);
if (ret) {
printk("Failed to get sensor values, %d\n", ret);
return;
printk("new sample:\n");
print_buffer(temp_value, ARRAY_SIZE(temp_value));
k_sleep(K_MSEC(1000));
checking the lines using a saleae logic analyzer have no activity on the bus.
setup:
i2c 1, < 0x9000 0x1000 >;
and
uart0 reg = < 0x8000 0x1000 >;
CMAKE:
cmake_minimum_required(VERSION 3.8.2)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(amg88xx)
FILE(GLOB app_sources src/*.c)
target_sources(app PRIVATE src/main.c)ZEPHYR DTS:
/dts-v1/;
#address-cells = < 0x1 >;
#size-cells = < 0x1 >;
model = "Nordic NRF5340 DK NRF5340 Application";
compatible = "nordic,nrf5340-dk-nrf5340-cpuapp";
chosen {
zephyr,entropy = &cryptocell;
zephyr,flash-controller = &flash_controller;
zephyr,console = &uart0;
zephyr,shell-uart = &uart0;
zephyr,uart-mcumgr = &uart0;
zephyr,bt-mon-uart = &uart0;
zephyr,bt-c2h-uart = &uart0;
zephyr,ipc_shm = &sram0_shared;
zephyr,sram = &sram0_image;
zephyr,flash = &flash0;
zephyr,code-partition = &slot0_partition;
zephyr,sram-secure-partition = &sram0_s;
zephyr,sram-non-secure-partition = &sram0_ns;
aliases {
led0 = &led0;
led1 = &led1;
led2 = &led2;
led3 = &led3;
pwm-led0 = &pwm_led0;
sw0 = &button0;
sw1 = &button1;
sw2 = &button2;
sw3 = &button3;
bootloader-led0 = &led0;
soc {
compatible = "nordic,nRF5340-CPUAPP-QKAA", "nordic,nRF5340-CPUAPP", "nordic,nRF53", "simple-bus";
interrupt-parent = < &nvic >;
ranges;
nvic: interrupt-controller@e000e100 {
compatible = "arm,v8m-nvic";
reg = < 0xe000e100 0xc00 >;
interrupt-controller;
#interrupt-cells = < 0x2 >;
arm,num-irq-priority-bits = < 0x3 >;
phandle = < 0x1 >;
systick: timer@e000e010 {
compatible = "arm,armv8m-systick";
reg = < 0xe000e010 0x10 >;
status = "disabled";
sram0: memory@20000000 {
compatible = "mmio-sram";
reg = < 0x20000000 0x80000 >;
sram1: memory@21000000 {
reg = < 0x21000000 0x10000 >;
peripheral@50000000 {
ranges = < 0x0 0x50000000 0x10000000 >;
flash_controller: flash-controller@39000 {
compatible = "nordic,nrf53-flash-controller";
reg = < 0x39000 0x1000 >;
label = "NRF_FLASH_DRV_NAME";
flash0: flash@0 {
compatible = "soc-nv-flash";
label = "NRF_FLASH";
erase-block-size = < 0x1000 >;
write-block-size = < 0x4 >;
reg = < 0x0 0x100000 >;
partitions {
boot_partition: partition@0 {
label = "mcuboot";
reg = < 0x0 0x10000 >;
slot0_partition: partition@10000 {
label = "image-0";
reg = < 0x10000 0x40000 >;
slot0_ns_partition: partition@50000 {
label = "image-0-nonsecure";
reg = < 0x50000 0x30000 >;
slot1_partition: partition@80000 {
label = "image-1";
reg = < 0x80000 0x40000 >;
slot1_ns_partition: partition@c0000 {
label = "image-1-nonsecure";
reg = < 0xc0000 0x30000 >;
scratch_partition: partition@f0000 {
label = "image-scratch";
reg = < 0xf0000 0xa000 >;
storage_partition: partition@fa000 {
label = "storage";
reg = < 0xfa000 0x6000 >;
adc: adc@e000 {
compatible = "nordic,nrf-saadc";
reg = < 0xe000 0x1000 >;
interrupts = < 0xe 0x1 >;
status = "okay";
label = "ADC_0";
#io-channel-cells = < 0x1 >;
phandle = < 0x6 >;
dppic: dppic@17000 {
compatible = "nordic,nrf-dppic";
reg = < 0x17000 0x1000 >;
status = "okay";
label = "DPPIC";
egu0: egu@1b000 {
compatible = "nordic,nrf-egu";
reg = < 0x1b000 0x1000 >;
interrupts = < 0x1b 0x1 >;
status = "okay";
egu1: egu@1c000 {
reg = < 0x1c000 0x1000 >;
interrupts = < 0x1c 0x1 >;
status = "okay";
egu2: egu@1d000 {
reg = < 0x1d000 0x1000 >;
interrupts = < 0x1d 0x1 >;
status = "okay";
egu3: egu@1e000 {
reg = < 0x1e000 0x1000 >;
interrupts = < 0x1e 0x1 >;
status = "okay";
egu4: egu@1f000 {
reg = < 0x1f000 0x1000 >;
interrupts = < 0x1f 0x1 >;
status = "okay";
egu5: egu@20000 {
reg = < 0x20000 0x1000 >;
interrupts = < 0x20 0x1 >;
status = "okay";
i2s0: i2s@28000 {
compatible = "nordic,nrf-i2s";
#size-cells = < 0x0 >;
reg = < 0x28000 0x1000 >;
interrupts = < 0x28 0x1 >;
label = "I2S_0";
ipc: ipc@2a000 {
compatible = "nordic,nrf-ipc";
reg = < 0x2a000 0x1000 >;
interrupts = < 0x2a 0x1 >;
status = "okay";
label = "IPC";
kmu: kmu@39000 {
compatible = "nordic,nrf-kmu";
interrupts = < 0x39 0x1 >;
status = "okay";
pdm0: pdm@26000 {
compatible = "nordic,nrf-pdm";
reg = < 0x26000 0x1000 >;
interrupts = < 0x26 0x1 >;
label = "PDM_0";
qdec0: qdec@33000 {
compatible = "nordic,nrf-qdec";
reg = < 0x33000 0x1000 >;
interrupts = < 0x33 0x1 >;
label = "QDEC_0";
qdec1: qdec@34000 {
reg = < 0x34000 0x1000 >;
interrupts = < 0x34 0x1 >;
label = "QDEC_1";
regulators: regulator@4000 {
compatible = "nordic,nrf-regulators";
reg = < 0x4000 0x1000 >;
status = "okay";
vmc: vmc@81000 {
compatible = "nordic,nrf-vmc";
reg = < 0x81000 0x1000 >;
status = "okay";
uart0: uart@8000 {
interrupts = < 0x8 0x1 >;
status = "okay";
label = "UART_0";
current-speed = < 0x1c200 >;
tx-pin = < 0x14 >;
rx-pin = < 0x16 >;
rts-pin = < 0x13 >;
cts-pin = < 0x15 >;
uart1: arduino_serial: uart@9000 {
reg = < 0x9000 0x1000 >;
interrupts = < 0x9 0x1 >;
label = "UART_1";
tx-pin = < 0x21 >;
rx-pin = < 0x20 >;
uart2: uart@b000 {
reg = < 0xb000 0x1000 >;
interrupts = < 0xb 0x1 >;
label = "UART_2";
uart3: uart@c000 {
reg = < 0xc000 0x1000 >;
interrupts = < 0xc 0x1 >;
label = "UART_3";
i2c0: i2c@8000 {
clock-frequency = < 0x186a0 >;
label = "I2C_0";
i2c1: arduino_i2c: i2c@9000 {
status = "okay";
label = "I2C_1";
sda-pin = < 0x22 >;
scl-pin = < 0x23 >;
amg88xx@68 {
compatible = "panasonic,amg88xx";
reg = < 0x68 >;
label = "AMG88XX";
int-gpios = < &arduino_header 0xc 0x11 >;
status = "okay";
i2c2: i2c@b000 {
label = "I2C_2";
i2c3: i2c@c000 {
label = "I2C_3";
spi0: spi@8000 {
label = "SPI_0";
spi1: spi@9000 {
label = "SPI_1";
spi2: spi@b000 {
label = "SPI_2";
spi3: spi@c000 {
label = "SPI_3";
spi4: arduino_spi: spi@a000 {
reg = < 0xa000 0x1000 >;
interrupts = < 0xa 0x1 >;
label = "SPI_4";
sck-pin = < 0x2f >;
miso-pin = < 0x2e >;
mosi-pin = < 0x2d >;
cs-gpios = < &arduino_header 0x10 0x1 >;
pwm0: pwm@21000 {
compatible = "nordic,nrf-pwm";
reg = < 0x21000 0x1000 >;
interrupts = < 0x21 0x1 >;
status = "okay";
label = "PWM_0";
#pwm-cells = < 0x1 >;
ch0-pin = < 0x1c >;
phandle = < 0x4 >;
pwm1: pwm@22000 {
reg = < 0x22000 0x1000 >;
interrupts = < 0x22 0x1 >;
label = "PWM_1";
pwm2: pwm@23000 {
reg = < 0x23000 0x1000 >;
interrupts = < 0x23 0x1 >;
label = "PWM_2";
pwm3: pwm@24000 {
reg = < 0x24000 0x1000 >;
interrupts = < 0x24 0x1 >;
label = "PWM_3";
gpio0: gpio@842500 {
compatible = "nordic,nrf-gpio";
gpio-controller;
reg = < 0x842500 0x300 >;
#gpio-cells = < 0x2 >;
label = "GPIO_0";
status = "okay";
port = < 0x0 >;
phandle = < 0x3 >;
gpio1: gpio@842800 {
gpio-controller;
reg = < 0x842800 0x300 >;
ngpios = < 0x10 >;
label = "GPIO_1";
status = "okay";
port = < 0x1 >;
phandle = < 0x5 >;
qspi: qspi@2b000 {
compatible = "nordic,nrf-qspi";
reg = < 0x2b000 0x1000 >;
interrupts = < 0x2b 0x1 >;
status = "okay";
label = "QSPI";
sck-pin = < 0x11 >;
io-pins = < 0xd >, < 0xe >, < 0xf >, < 0x10 >;
csn-pins = < 0x12 >;
mx25r64: mx25r6435f@0 {
compatible = "nordic,qspi-nor";
reg = < 0x0 >;
writeoc = "pp4io";
readoc = "read4io";
sck-frequency = < 0x7a1200 >;
label = "MX25R64";
jedec-id = [ C2 28 17 ];
sfdp-bfp = [ E5 20 F1 FF FF FF FF 03 44 EB 08 6B 08 3B 04 BB EE FF FF FF FF FF 00 FF FF FF 00 FF 0C 20 0F 52 10 D8 00 FF 23 72 F5 00 82 ED 04 CC 44 83 68 44 30 B0 30 B0 F7 C4 D5 5C 00 BE 29 FF F0 D0 FF FF ];
size = < 0x4000000 >;
has-dpd;
t-enter-dpd = < 0x2710 >;
t-exit-dpd = < 0x88b8 >;
rtc0: rtc@14000 {
compatible = "nordic,nrf-rtc";
reg = < 0x14000 0x1000 >;
cc-num = < 0x4 >;
interrupts = < 0x14 0x1 >;
status = "okay";
clock-frequency = < 0x8000 >;
prescaler = < 0x1 >;
label = "RTC_0";
rtc1: rtc@15000 {
reg = < 0x15000 0x1000 >;
cc-num = < 0x4 >;
interrupts = < 0x15 0x1 >;
status = "okay";
label = "RTC_1";
clock: clock@5000 {
compatible = "nordic,nrf-clock";
reg = < 0x5000 0x1000 >;
interrupts = < 0x5 0x1 >;
status = "okay";
label = "CLOCK";
power: power@5000 {
compatible = "nordic,nrf-power";
status = "okay";
wdt: wdt0: watchdog@18000 {
compatible = "nordic,nrf-watchdog";
reg = < 0x18000 0x1000 >;
interrupts = < 0x18 0x1 >;
status = "okay";
label = "WDT";
wdt1: watchdog@19000 {
reg = < 0x19000 0x1000 >;
interrupts = < 0x19 0x1 >;
label = "WDT_1";
timer0: timer@f000 {
compatible = "nordic,nrf-timer";
status = "okay";
reg = < 0xf000 0x1000 >;
cc-num = < 0x6 >;
interrupts = < 0xf 0x1 >;
prescaler = < 0x0 >;
label = "TIMER_0";
timer1: timer@10000 {
status = "okay";
reg = < 0x10000 0x1000 >;
cc-num = < 0x6 >;
interrupts = < 0x10 0x1 >;
label = "TIMER_1";
timer2: timer@11000 {
status = "okay";
reg = < 0x11000 0x1000 >;
cc-num = < 0x6 >;
interrupts = < 0x11 0x1 >;
label = "TIMER_2";
usbd: usbd@36000 {
compatible = "nordic,nrf-usbd";
reg = < 0x36000 0x1000 >;
interrupts = < 0x36 0x1 >;
num-bidir-endpoints = < 0x1 >;
num-in-endpoints = < 0x7 >;
num-out-endpoints = < 0x7 >;
num-isoin-endpoints = < 0x1 >;
num-isoout-endpoints = < 0x1 >;
status = "okay";
label = "USBD";
cryptocell: crypto@50844000 {
compatible = "nordic,nrf-cc312";
reg = < 0x50844000 0x1000 >;
label = "CRYPTOCELL";
status = "okay";
cryptocell312: crypto@50845000 {
compatible = "arm,cryptocell-312";
reg = < 0x50845000 0x1000 >;
interrupts = < 0x44 0x1 >;
label = "CRYPTOCELL312";
gpiote: gpiote@5000d000 {
compatible = "nordic,nrf-gpiote";
reg = < 0x5000d000 0x1000 >;
interrupts = < 0xd 0x5 >;
status = "okay";
label = "GPIOTE_0";
spu: spu@50003000 {
compatible = "nordic,nrf-spu";
reg = < 0x50003000 0x1000 >;
interrupts = < 0x3 0x1 >;
status = "okay";
ficr: ficr@ff0000 {
compatible = "nordic,nrf-ficr";
reg = < 0xff0000 0x1000 >;
status = "okay";
uicr: uicr@ff8000 {
compatible = "nordic,nrf-uicr";
reg = < 0xff8000 0x1000 >;
status = "okay";
cpus {
cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-m33f";
reg = < 0x0 >;
swo-ref-frequency = < 0x3d09000 >;
mpu: mpu@e000ed90 {
compatible = "arm,armv8m-mpu";
reg = < 0xe000ed90 0x40 >;
arm,num-mpu-regions = < 0x8 >;
leds {
compatible = "gpio-leds";
led0: led_0 {
gpios = < &gpio0 0x1c 0x1 >;
label = "Green LED 0";
led1: led_1 {
gpios = < &gpio0 0x1d 0x1 >;
label = "Green LED 1";
led2: led_2 {
gpios = < &gpio0 0x1e 0x1 >;
label = "Green LED 2";
led3: led_3 {
gpios = < &gpio0 0x1f 0x1 >;
label = "Green LED 3";
pwmleds {
compatible = "pwm-leds";
pwm_led0: pwm_led_0 {
pwms = < &pwm0 0x1c >;
buttons {
compatible = "gpio-keys";
button0: button_0 {
gpios = < &gpio0 0x17 0x11 >;
label = "Push button 1";
button1: button_1 {
gpios = < &gpio0 0x18 0x11 >;
label = "Push button 2";
button2: button_2 {
gpios = < &gpio0 0x8 0x11 >;
label = "Push button 3";
button3: button_3 {
gpios = < &gpio0 0x9 0x11 >;
label = "Push button 4";
arduino_header: connector {
compatible = "arduino-header-r3";
gpio-map-mask = < 0xffffffff 0xffffffc0 >;
gpio-map-pass-thru = < 0x0 0x3f >;
gpio-map = < 0x0 0x0 &gpio0 0x4 0x0 >, < 0x1 0x0 &gpio0 0x5 0x0 >, < 0x2 0x0 &gpio0 0x6 0x0 >, < 0x3 0x0 &gpio0 0x7 0x0 >, < 0x4 0x0 &gpio0 0x19 0x0 >, < 0x5 0x0 &gpio0 0x1a 0x0 >, < 0x6 0x0 &gpio1 0x0 0x0 >, < 0x7 0x0 &gpio1 0x1 0x0 >, < 0x8 0x0 &gpio1 0x4 0x0 >, < 0x9 0x0 &gpio1 0x5 0x0 >, < 0xa 0x0 &gpio1 0x6 0x0 >, < 0xb 0x0 &gpio1 0x7 0x0 >, < 0xc 0x0 &gpio1 0x8 0x0 >, < 0xd 0x0 &gpio1 0x9 0x0 >, < 0xe 0x0 &gpio1 0xa 0x0 >, < 0xf 0x0 &gpio1 0xb 0x0 >, < 0x10 0x0 &gpio1 0xc 0x0 >, < 0x11 0x0 &gpio1 0xd 0x0 >, < 0x12 0x0 &gpio1 0xe 0x0 >, < 0x13 0x0 &gpio1 0xf 0x0 >, < 0x14 0x0 &gpio1 0x2 0x0 >, < 0x15 0x0 &gpio1 0x3 0x0 >;
phandle = < 0x2 >;
arduino_adc: analog-connector {
compatible = "arduino,uno-adc";
io-channel-map = < 0x0 &adc 0x0 >, < 0x1 &adc 0x1 >, < 0x2 &adc 0x2 >, < 0x3 &adc 0x3 >, < 0x4 &adc 0x4 >, < 0x5 &adc 0x5 >;
reserved-memory {
ranges;
sram0_image: image@20000000 {
reg = < 0x20000000 0x70000 >;
sram0_s: image_s@20000000 {
reg = < 0x20000000 0x40000 >;
sram0_ns: image_ns@20040000 {
reg = < 0x20040000 0x30000 >;
sram0_shared: memory@20070000 {
reg = < 0x20070000 0x10000 >;
CPUAPP.YAML
identifier: nrf5340dk_nrf5340_cpuapp name: NRF5340-DK-NRF5340-application-MCU type: mcu arch: arm toolchain: - gnuarmemb - xtools - zephyr ram: 448 flash: 1024 supported: - gpio - i2c - pwm - watchdog - usb_cdc - usb_device
OVERLAY:
// SEGGER Embedded Studio auto generated
* Copyright (c) 2019 Phytec Messtechnik GmbH
&i2c1{
status = "okay";
amg88xx@68 {
reg = <0x68>;
label = "AMG88XX";
/* Pin D6 from Arduino Connector */
int-gpios = <&arduino_header 12 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>;
status = "okay";
CPUAPP DTS:
* Copyright (c) 2020 Nordic Semiconductor ASA
/dts-v1/;
#include <nordic/nrf5340_cpuapp_qkaa.dtsi>
#include "nrf5340_cpuapp_common.dts"
chosen {
&usbd {
status = "okay";
&pwm0 {
status = "okay";
label = "PWM_0";
ch0-pin = < 0x1c >;
phandle = < 0x4 >;
&i2c1 {
status = "okay";
sda-pin = <34>;
scl-pin = <35>;
everything else should be disabled, i've made sure in the makefile all the proper files were added from the example amg88 folder/ overwritten in mine.
for ease sake i used the hello world example to modify.
the interrupts for the sensor and the twi are default so 60 and 90 so that shouldnt be an issue.
i've tried
-different pins,
-disabling anything thats using < 0x9000 0x1000 >
- double checking the parameters in the dts.
- checked the setup code and when it attempts to pulse the clock line it doesnt do anything (checked this on multiple sets of pins)
any help is appreciated.
5050.hello_world.rar
