NRF9160 current measurement
HI
     Now I  am measuring current on the nRF9160DK  according to  https://devzone.nordicsemi.com/nordic/cellular-iot-guides/b/hardware-design/posts/getting-started-with-current-measurements-on-the-nrf9160.
    When measuring current on the UDP sample in NCS, the uart log
         *** Booting Zephyr OS build v2.6.0-rc1-ncs1 ***
         UDP sample has started
         LTE cell changed: Cell ID: -1, Tracking area: -1
   I use NB card ,and on application serial_lte_modem I can connect net.
  On the UDP sanple i not found config to NB .what should I do?
 Can I measure current on the application serial_lte_modem? What do i do if i can?
  • I see that my response from yesterday did not go through.
    I've asked our expert on his opinion regarding the numbers that you provide. The response is that the spike frequency fits the refresh mode in PSM, which does look correct. However, the numbers are somewhat high. What equipment are you using to measure? Can you please check the results with multimeter connected to the current measurement header?
    What version of the nRF9160DK are you using?
    Thank you.
    Øyvind
