Thingy:91 unresponsive after flashing with J-Link
I'm having some troubles with the Thingy:91 because it became unresponsive after I flashed the device with the mqtt_sample firmware.
I built the mqtt_sample with segger embedded studio, then I flashed the merged.hex output file using an external programmer (J-Link EDU Mini) through segger embedded studio.
Now the device is completely dead: If I try to flash the asset tracker application with MCU Boot using USB cable it completes the flashing procedure but then nothing happens, no led flashing and no debug output on LTE Monitor.
Also I'm not able anymore to connect the J-Link with the target (neither with Segger J-Link tools or with Nordic tools).
If I try
nrfjprog -f nrf91 -r
i receive the following output:
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
Have I done something wrong? Which is the correct procedure to make the device work again?
Thank you very much,
Grein
    In what position is the SWD Select switch (SW2) set? Make sure that it is set to nRF91 when programming the nRF91, and to nRF52 when programming the nRF52, when using a JLink external debugger. The onboard nRF52840 is the device managing the connectivity with between the computer and Thingy:91 (running Connectivity Bridge application).
    Please reprogram, using JLink EDU mini, the nRF52 with the Connectivity Bridge while SW2=nRF52, then switch SW2 to nRF91 and program the asset tracker application.
    Øyvind
  • Hi Øyvind,
    thank you for the answer. When I flashed the device with the mqtt_simple sample the SWD switch was set to nRF91 (how it is supposed to be, right?).
    How can I reprogram the application with J-Link if it is not able to connect to target? If I run J-Link Commander application it reads VTref to 3V so I suppose it is able to see the target, but then if I type "connect" it fails to connect to target ("Connecting to target via SWD - Cannot connect to target") Same thing happens if I try to connect J-Link on Segger embedded studio.
    How should I do?
    Thank you,
    Grein
  • Hi Grein,
    What version of nrfjprog and JLink are you running? Please run nrfjprog --version and provide the output. Have you checked that there is noe issues with the SWD cable?
    Does every nrfjprog command return the same output from your initial post? Can you please provide the generated log.log file as it instructs?
    Thanks.
    Øyvind
  • Hi Øyvind,
    this is the output you asked:
    nrfjprog version: 10.14.0 external
    JLinkARM.dll version: 6.88a
    Yes, every nrfjprog command returns that output.
    No issue with the SWD cable, it worked well the first time I flashed the device with J-Link.
    Here is the log.log file:
    [2021-Sept-27 23:49:44] [ info] --------------------------------------------------------------------------------
    [2021-Sept-27 23:49:44] [ info] nrfjprog -f nrf91 -r --log C:\dev
    [2021-Sept-27 23:49:44] [ info] nrfjprog version 10.14.0 external
    [2021-Sept-27 23:49:44] [ info] Load library at C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2021-Sept-27 23:49:44] [ info] Library loaded, loading member functions.
    [2021-Sept-27 23:49:44] [ info] Member functions succesfully loaded.
    [2021-Sept-27 23:49:44] [debug] [ Client] - open
    [2021-Sept-27 23:49:44] [debug] [ Client] - start
    [2021-Sept-27 23:49:45] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence d92c4ade-2e36-4ee6-ae90-602893337cd5.
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2021-Sept-27 23:49:45] [debug] [  JLink] - Logger sink registered in JLink logger
    [2021-Sept-27 23:49:45] [debug] [  nRF91] - open
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - open_dll
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2021-Sept-27 23:49:45] [ info] [SeggerBackend] - Load library at C:\Program Files (x86)\SEGGER\JLink\JLinkARM.dll.
    [2021-Sept-27 23:49:45] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2021-Sept-27 23:49:45] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - dll_version
    [2021-Sept-27 23:49:45] [ info] [SeggerBackend] - Segger dll version 6.88.a loaded.
    [2021-Sept-27 23:49:45] [trace] [ Worker] - Command open executed for 6 milliseconds with result 0
    [2021-Sept-27 23:49:45] [trace] [ Client] - Command open executed for 39 milliseconds with result 0
    [2021-Sept-27 23:49:45] [debug] [ Client] - enum_emu_snr
    [2021-Sept-27 23:49:45] [trace] [ Client] - Command enum_emu_snr executed for 15 milliseconds with result 0
    [2021-Sept-27 23:49:45] [debug] [ Client] - connect_to_emu_with_snr
    [2021-Sept-27 23:49:45] [debug] [  nRF91] - enum_emu_snr
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - is_connected_to_emu
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - enum_emu_snr
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_get_num_emus
    [2021-Sept-27 23:49:45] [trace] [ Worker] - Command enum_emu_snr executed for 2 milliseconds with result 0
    [2021-Sept-27 23:49:45] [debug] [  nRF91] - connect_to_emu_with_snr
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - Segger logging enabled.
    [2021-Sept-27 23:49:45] [trace] [  JLink] - Firmware: J-Link EDU Mini V1 compiled Aug 10 2021 11:19:22
    [2021-Sept-27 23:49:45] [trace] [  JLink] - Decompressing FW timestamp took 124 us
    [2021-Sept-27 23:49:45] [trace] [  JLink] - Hardware: V1.00
    [2021-Sept-27 23:49:45] [trace] [  JLink] - S/N: 801034441
    [2021-Sept-27 23:49:45] [trace] [  JLink] - OEM: SEGGER
    [2021-Sept-27 23:49:45] [trace] [  JLink] - Feature(s): FlashBP, GDB
    [2021-Sept-27 23:49:45] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2021-Sept-27 23:49:45] [trace] [  JLink] - WEBSRV Starting webserver
    [2021-Sept-27 23:49:45] [trace] [  JLink] - WEBSRV Failed to put socket into listener state (port 19080)
    [2021-Sept-27 23:49:45] [trace] [  JLink] - WEBSRV Webserver running on local port 19081
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 20.704ms returns "O.K."
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_HasError()
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_Lock()
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.151ms returns 0
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.003ms returns 0x01
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.003ms returns 0x00
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.004ms returns 0x00
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.016ms returns 0
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.502ms returns 0x00
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.083ms
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_GetSN()
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.006ms returns 801034441
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - read_debug_port_idr
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - read_debug_port_register
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - coresight_configure
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 100.161ms returns 0
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.961ms returns -1
    [2021-Sept-27 23:49:45] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.980ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 1.069ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 1.339ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 1.270ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 1.301ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 1.298ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 1.001ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 1.377ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.972ms returns -1
    [2021-Sept-27 23:49:45] [trace] [ Client] - Command connect_to_emu_with_snr executed for 188 milliseconds with result -102
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.987ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.888ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.947ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.921ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.745ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.660ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.637ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.800ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.766ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.692ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.694ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.622ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.592ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.736ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.610ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.732ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.670ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.578ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.681ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.563ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.036ms
    [2021-Sept-27 23:49:45] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 186 milliseconds with result -102
    [2021-Sept-27 23:49:45] [debug] [  nRF91] - close
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - is_connected_to_device
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_IsOpen()
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.010ms returns 0x01
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_IsConnected()
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.007ms returns FALSE
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.007ms returns 0x01
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - close
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - disconnect_from_emu
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.557ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.567ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.657ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.627ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.518ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.524ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.527ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.526ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.535ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.514ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.587ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.673ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.669ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.534ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.737ms returns -1
    [2021-Sept-27 23:49:45] [trace] [ Client] - Command close executed for 110 milliseconds with result 0
    [2021-Sept-27 23:49:45] [debug] [ Client] - terminate
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.501ms returns -1
    [2021-Sept-27 23:49:45] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.519ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.665ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.573ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.704ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.672ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.583ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.629ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.686ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.547ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.533ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.580ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.747ms returns -1
    [2021-Sept-27 23:49:45] [trace] [  JLink] - - 0.014ms
    [2021-Sept-27 23:49:45] [trace] [  JLink] - JLINK_Close()
    [2021-Sept-27 23:49:45] [debug] [SeggerBackend] - Segger Backend closed.
    [2021-Sept-27 23:49:45] [debug] [  nRF91] - nRF family DLL closed
    [2021-Sept-27 23:49:45] [trace] [ Worker] - Command close executed for 110 milliseconds with result 0
    [2021-Sept-27 23:49:45] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2021-Sept-27 23:49:45] [trace] [ Worker] - Executed 5 commands for 304 milliseconds
    [2021-Sept-27 23:49:45] [debug] [ Client] - Worker process exited with code: 0
    [2021-Sept-27 23:49:45] [debug] [ Client] - Child process terminated with result 0
    [2021-Sept-27 23:49:45] [trace] [ Client] - Executed 5 commands for 352 milliseconds
    Thank you,
    Grein
  • Hey Grein,
    Thanks for sharing. Can you please try to update your JLink drivers? 6.88a is fairly old, and you should have been prompted to install a newer version.
    Øyvind
