Stop ble_app_uart connection with ble_app_uart_c
I am using: \examples\ble_peripheral\ble_app_uart  and  \examples\ble_central\ble_app_uart_c  .
In Nordic infocenter it says: The application scans peripheral devices and connects to a device that advertises with the NUS UUID in its advertisement report.
The questions are:
1- Is this type of connection similar to a pairing where a key exchange occurs and connection is encrypted between peripheral and central?
2- How can I modify \examples\ble_peripheral\ble_app_uart code to drop the connection and reconnect periodically (for power saving) .
    1. Pairing is a procedure that's performed after a connection is established to secure the connection. But pairing is not supported by the NUS example which means the link will always be unencrypted. The SDK examples that support BLE security include the Peer Manager module.
    2. You can use the low-power Timer library to trigger periodic events to start connectable advertising and/or terminate a connection.
    Softdevice function to terminate a connection:
                err_code = sd_ble_gap_disconnect(conn_handle,
    Required change in advertising_init() to prevent the advertising module from automatically re-starting connectable advertising on disconnect:
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        /* Don't restart advertising on discoonect */
        init.config.ble_adv_on_disconnect_disabled = true;
  • Thanks Vidar. Is there any example that implements peer manager modules?
    if NUS does not work with encryption and peer manager, how do I trans/receive data after encryption implementation? Which SDK modules I can use to communicate data between my two devices after connection encryption?
  • Most of the BLE examples do. Easiest way to tell if an example supports pairing or bonding is to check if it calls peer_manager_init() in main().
    But what is your requirement for this, is it to be able to encrypt the connection? In that case, it will be easier to add the NUS service to another example such as ble_app_hrs that already support pairing than it will be to add the peer manager to the NUS example. This is because there will be fewer  source files, include paths and sdk_config settings to add.
  • Ok, thanks. I am using ble_app_hrs for peripheral and ble_app_hrs_c for central device.
    In these codes seems there are SEC_PARAM_MIN_KEY_SIZE and SEC_PARAM_MAX_KEY_SIZE for encryption key size, but how can I set/update encryption key itself?
  • The encryption key will be added through the pairing procedure which initiated by the GAP central when it calls pm_conn_secure().
