uECC library for secure bootloader using Segger Studios
I'm finding problem to generate the library uECC.a to use in project secure_bootloader for nRF52833 (SDK17) using SEGGER.
I started from project   SDK_17\examples\dfu\secure_bootloader\pca10100_s140_ble.
I'm using Windows 10.
I followed the steps in
https://devzone.nordicsemi.com/nordic/short-range-guides/b/software-development-kit/posts/getting-started-with-nordics-secure-dfu-bootloader#h23sjziacp7vrw0scs2t3tua1ax0426
In particular:
  1. Install version 4.9-2015-q3-update of the GCC compiler toolchain for ARM. You can use ARM's Launchpad to find the toolchain for your operating system. DONE.
     I've downloaded the GNU Tool ARM version 9 2019 q4 because I saw is the version required by the build_all.bat file
    C:\Program Files (x86)\GNU Tools ARM Embedded\9 2019-q4-major
  2. Make sure that make is installed (see, for example, MinGW, GNU Make, or Xcode). I don't know wich is the simplest to use for me. Could you tell me how to use them? If I download GNUmake, do I need also MinGW? could you give me some recommendation?
  3. Clone the micro-ecc GitHub repository into <InstallFolder>\external\micro-ecc\micro-ecc. DONE
And I can't go on because of step 2....
Thank you in advance
