Hi, I am not sure how to measure the signal strength of the communication within the mesh network (ie. communication between provisioned nodes), in order to verify a change in signal strength.
Thanks in advance
You can call mesh_opt_core_tx_power_set() in the runtime for setting the TX power, and the configuration will be stored in the flash, and check by mesh_opt_core_tx_power_get().
It should be able to see the change by using the nRF Sniffer to verify this in a development setting.
I am not sure which bearer is used for communication between provisioned devices.
I think it's the ADV bearer because you wrote that you get it for the GATT bearer.
Amanda
