Hi Nordic Team,
Can I upgrade the firmware between different softdevice? From s132 to s113
firmware 1: sd: s132_nrf52_7.0.1_softdevice.hex , bootloader: secure bootloader based on the sdk nRF5_SDK_17.0.0_9d13099, application: custom application 1 based on sdk17.0.0
firmware 2: sd: s132_nrf52_7.2.0_softdevice.hex , bootloader: secure bootloader based on the sdk nRF5_SDK_17.1.0_ddde560, application: custom application 1 based on sdk17.1.0
firmware 3 : sd: s113_nrf52_7.0.1_softdevice.hex, bootloader: secure bootloader based on the sdk nRF5_SDK_16.0.0_98a08e2, application: another custom application based on sdk16.0.0
I can upgrade the SD+BL+APP from firmware 1 to firmware 2 successfully, but when upgrade firmware 1 to firmware 3, it will raise an error, attached the picture.
I use this command to generate the zip package.
nrfutil.exe pkg generate --hw-version 52 --sd-req 0xCB,0xCC,0x0101 --sd-id 0xCC --softdevice s113_nrf52_7.0.1_softdevice.hex --bootloader-version 3 --bootloader s113_bootloader.hex --application-version 2 --application application_s113_release.hex --key-file private.pem DFU_stdToCustom_SD_BL_APP.zip
Any problem about the command?
I also try by the android app Toolbox, uploading part 1/2, when the process up to 100%, it raise an error: upload failed: DFU device disconneted.
Please help to analy this issue, we have some products with firmware 1, need to upgrade to firmware 3. Thank you very much.
Best wishes,
Susan
