How to config BLE to minimize time of building connection
Hi
I am a beginner of bluetooth
I want to build BLE connection between nrf52833 and nrf52810 as soon as possible (maybe in 100-200ms)
can I achieve that by config Advertising Interval,Scan Interval and Scan window or others configuration?
SDK: 17  BLE app uart example
Softdevice:
nrf52833 & S140
nrf52810 & S132
My current setting are
Advertising Interval:20 ms
Scan Interval & Scan window:40
Sometimes they build connection immediately but sometimes they spend 2-3 second,which longer a lot then I expect
Thanks for helping
    You can adjust the mentioned parameters for it to connect faster.
    2-3 second does seem a bit long. Have you made any modifications other than the advertising interval, scan interval and scan window? Are you around a lot of wireless devices when testing?
  • Hi Mttrinh,
    thanks for your reply
    I didn't modify any default setting except advertising interval, scan interval and scan window(maintain the original configuration from nrf_ble_uart example),and I test it in a quiet room with seldom wireless devices.
    I want to know that is it possible to make it  connect  fast every time(as sometimes it can do),for example if I set:
    advertising interval: 20ms
    scan interval: 40ms
    scan window: 40ms
    Because master can catch the advertising a least once time in its scan window, the time cost of connection will less then 120 ms(for 3 channel*40 ms) is it correct?Or I misunderstand how scan and advertisement work ?
    And, is it any others configuration can help it connect faster(maybe whitelist...)?
    Thanks you very much!
    Yes, that is correct.
    You can try adding pairing/bonding to the example, that should help with the connection speed. You will need to add the peer manager to the example in order to support pairing/bonding. You should take a look at another example on how it is done, for example ble_app_hrs.
