ble app uart
Hi:
I use nrf52832 to connect to the sensor module through uart. When the sensor device is turned off, I can repeat the pairing and unpairing of the Ble module through the nRF Connect app. But after the Ble module pairing is completed and the sensor is turned on, when I cancel the Ble pairing and want to re-pair, I cannot scan the Ble device and cannot pair. How can I solve it
  • I modified the code according to your suggestion, but the problem still exists. Can you check the modified part for me?
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        bool       is_indication_enabled;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Allow or reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
                advertising_start();
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Could you confirm for me that you have defined PEER_MANAGER_ENABLED 1 in your sdk_config.h file? Every driver or module that is not enabled in the sdk_config will be excluded from compilation.
    Karl
  • Sorry, I didn't express it clearly. After modifying sdk_config.h according to your suggestion, the program can work, but the device still cannot be re-paired. Can you help me confirm the modified part of the main.c file?
  • Aha, now I understand - I was under the impression that you were still talking about the sdk_config issue.
    I do not immediately see anything wrong with this event handler, no.
    Could you place a breakpoint in the PM_EVT_CONN_CONFIG_REQ  section, to confirm that you receive this event when a new connection is made?
    Are you able to pair, but not re-pair?
    Which error are you getting when you attempt to re-pair?
    What does you log say when this happens?
    Karl
  • Hi Karl:
    The following is the message I received from debug Treminal. It seems to be caused by APP_UART_COMMUNICATION_ERROR in main.c
