ble app uart
Hi:
I use nrf52832 to connect to the sensor module through uart. When the sensor device is turned off, I can repeat the pairing and unpairing of the Ble module through the nRF Connect app. But after the Ble module pairing is completed and the sensor is turned on, when I cancel the Ble pairing and want to re-pair, I cannot scan the Ble device and cannot pair. How can I solve it
  • Sorry, the wrong code should be in the red box below
  • Hello again,
    Could you show me the entire error message, preferably as a text string instead of a screenshot?
    At the very end of the error message it tells you which line that failed the APP_ERROR_CHECK. Please also show me the code section (entire function) that triggered this APP_ERROR_CHECK. Please also use the Insert -> Code option when sharing code here on DevZone - this drastically increases it's readability.
    Karl
  • Hi Karl:
    Do you want these messages?
    <info> app_timer: RTC: initialized.
    <info> app: Debug logging for UART over RTT started.
    <info> app: Connected
    <info> app: Data len is set to 0xF4(244)
    <info> app: Disconnected
    <error> app: ERROR 13313 [Unknown error code] at C:\Users\user\Desktop\nordic\nRF5SDK1702d674dde\nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_uart\main.c:617
    PC at: 0x0003230B
    <error> app: End of error report
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if(data_array[0] == 0x02 && data_array[1] == 0x01 && data_array[2] == 0x04 && data_array[3] == 0x03)
                  int dataLength = data_array[8] + data_array[9] * 256;
                    if (data_array[8 + dataLength] && data_array[9 + dataLength] && data_array[10 + dataLength] && data_array[11 + dataLength] == 0xff )
                        if (index > 1)
                            NRF_LOG_INFO("Send_data");
                            do
                            } while (err_code == NRF_ERROR_RESOURCES);
                        index = 0;
                    else if((data_array[index - 1] && data_array[index - 2] && data_array[index - 3] && data_array[index - 4] == 0xff) ||
                            (index >= m_ble_nus_max_data_len))
                        if (index > 1)
                            do
                        index = 0;
               // else
                   // if ((data_array[index - 1] && data_array[index - 2] && data_array[index - 3] && data_array[index - 4] == 0xff) ||
                   if ((data_array[index - 1] == '\n') ||
                       (data_array[index - 1] == '\r') ||
                       (index >= (m_ble_nus_max_data_len)))
                        if (index > 1)
                            do
                        index = 0;
            case APP_UART_FIFO_ERROR:
    Yes, exactly this, thank you.
    PC at: 0x0003230B
    The error report states that the APP_ERROR_CHECK was triggered on line 617 of main.c
    Could you also confirm that the APP_ERROR_CHECK following the call to ble_nus_data_send in the code snippet that you have sent is in fact line 617 of your main.c?
    It seems strange to me that this could return an unknown error code such as 13313 - this is usually the case when a non-error code is passed to an APP_ERROR_CHECK, or in the case that an uninitialized error code is passed to an APP_ERROR_CHECK.
    Karl
  • On a general note I also notice that you have quite a long path to your SDK location.
    Please be aware of Window's 260 character path limit - anything exceeding 260 characters will be truncated.
    This can cause quite a headache if not aware of it.
    I recommend that you move you SDK location to be on top of your hierarchy, like C:\nordic\ or similar.
    Karl
