ble app uart
Hi:
I use nrf52832 to connect to the sensor module through uart. When the sensor device is turned off, I can repeat the pairing and unpairing of the Ble module through the nRF Connect app. But after the Ble module pairing is completed and the sensor is turned on, when I cancel the Ble pairing and want to re-pair, I cannot scan the Ble device and cannot pair. How can I solve it
  • Yes, line 617 in main.c is the APP_ERROR_CHECK following the call to ble_nus_data_send.
    What should I do?
  • Hi Karl:
    After doing some experiments, I found that the problem of not being able to re-pair seems to occur when the Uart RX listen is not stopped and the device is unpaired. When I stop Uart RX listen first, and then unpair the device, this problem will not occur.
    Is there a solution to this?
    Thank you for confirming this.
    The 13313 error returned from ble_nus_data_send propagates from sd_ble_gatts_hvx, and as I've understood it usually means that you've tried to queue a notification for sending for a connection handle that the SoftDevice has not been provided any system attributes for. This should then generate a BLE_GATTS_EVT_SYS_ATTR_MISSING event, if it is the case. Are you seeing this 13313 error frequently, or only at a given time in your program? Other user's I've seen experience this reported that this error was only returned as a result of a call to queue a notification interrupted by a disconnected event or connected event - could this also be the case here?
    If you retry the call to ble_nus_data_send once immediately after having received the 13313 error, does it still return 13313 on the second try?
    When not using pairing / bonding this can be handled by adding the following into the ble_evt_handler:
        err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0);
    When using pairing / bonding this should then instead be handled by the peer manager.
    Could you check whether you are receiving this event in your PM event handler or not?
    This points in the direction of the aforementioned - that CCCD (notify) is enabled on the peripheral, and when the connection is broken the device may still be trying to send a notification, and/or upon the next reconnection it may generate the BLE_GATTS_EVT_SYS_ATTR_MISSING event to see if it has stored any information about this peer and its attributes (like the CCCD already being enabled from the previous connection).
    Does the applications UART RX callback include a call to queue a notification with the received data? Could it be that the function attempts to queue data for a recently disconnected / unpaired device?
    If so, you may handle this error by stopping the UART RX and storing the data you attempted to queue for transfer later, or discard the data entirely if it is not relevant later. How does this work with your application's constraints and requirements?
    Karl
  • Hi Karl:
    1.Are you seeing this 13313 error frequently, or only at a given time in your program?
       Ans : Currently the 13313 error only appears when I want to re-pair the device.
    2.Could you check whether you are receiving this event in your PM event handler or not?
      Ans : I have added the following LOG_INFO in the PM event, but it seems not to be executed.
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Allow or reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = true};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
                NRF_LOG_INFO("device re-pair/n")
    3.Does the applications UART RX callback include a call to queue a notification with the received data? Could it be that the function attempts to queue data for a recently disconnected / unpaired device?
     Ans : I hope it can run correctly without stopping Uart RX, but I still can't achieve it at the moment.
    Thank you for your patience with this.
    To elaborate a little on what I said earlier; error  13313=0x3401 corresponds to BLE_ERROR_GATTS_SYS_ATTR_MISSING and is likely returned by  ble_nus_data_send() because it's called before the system attribute table has been updated in the Softdevice, similar to the NRF_ERROR_INVALID_STATE error you get if you try to send notifications before notifications has been enabled by the GATT client .
    The attribute table (contain CCCD configurations) is restored on connection if you use the Peer manager module. Maybe ble_nus_data_send() is called before the Peer manager has had time to restore the attributes, or similar.
    If it is important not to stop the UART RX then perhaps we should redirect the messages received on the UART to RAM or Flash storage (depending on the amount of data received in the time that a connection is broken), as a fix to this.
    Could this be an option?
    If this issue only is present when re-pairing, then you could add a specific error handling for this error, which is to store the data for later transfer, and then try again sometimes later. This error should disappear as soon as the Peer Manager has had enough time to update the attribute table, as mentioned above.
    Could you try this, and see if it resolves your issue? I.e implement specific error handling for the 13313 error that stores the data you attempted to queue for later transfer, so that the peer manager has enough time to populate the attribute table.
    Karl
