Error: L6218E: Undefined symbol app_uart_init (referred from main.o). try to use external TTL usb for debugging
Hi, i'm using STLink V2 for compiling the code, the weaknes of this compiler is you can't see the result debuging or serial print output.
so i'm using USB TTL to see output of the code, first i'm create some project to comunicate Serial UART so i can show the result on Serial Debugar (Arduino IDE serial Monitor or PUTTY)
and it's done,
my next problem is i want to colaborate this code with Gazell code in sdk12.3 using nrf51822, but i got this error
.\_build\nrf51422_xxac.axf: Error: L6218E: Undefined symbol app_uart_init (referred from main.o).
please help me, my code is
GAZELL HOST CODE
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include "nrf_gzll.h"
#include "nrf_gzp.h"
#include "nrf_ecb.h"
#include "bsp.h"
#include "app_error.h"
#include "app_timer.h"
#include "nrf_gzll_error.h"
#include "app_uart.h"
#include "nrf_delay.h"
#include "nrf.h"
#define NRF_LOG_MODULE_NAME "APP"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/** @Serial Configuration */
#define MAX_TEST_DATA_BYTES     (15U)
#define UART_TX_BUF_SIZE 256
#define UART_RX_BUF_SIZE 1
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
static void uart_init(void)
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          APP_UART_FLOW_CONTROL_DISABLED,
          false,
          UART_BAUDRATE_BAUDRATE_Baud115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_error_handle,
                         APP_IRQ_PRIORITY_LOWEST,
                         err_code);
/** @name Configuration */
#define UNENCRYPTED_DATA_PIPE     2   ///< Pipes 0 and 1 are reserved for GZP pairing and data. See nrf_gzp.h.
#define NRF_GZLLDE_RXPERIOD_DIV_2 504 ///< RXPERIOD/2 on LU1 = timeslot period on nRF5x.
#define APP_TIMER_PRESCALER       0   ///< Value of the RTC PRESCALER register.
#define APP_TIMER_OP_QUEUE_SIZE   8u  ///< Size of timer operation queues.
 * @brief Initialize the BSP modules.
static void ui_init(void)
    // Initialize application timer.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
    uint32_t err_code = bsp_init(BSP_INIT_LED,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 NULL);
    // Set up logger
    err_code = NRF_LOG_INIT(NULL);
    NRF_LOG_INFO("Gazell dynamic pairing example. Host mode.\r\n");
    NRF_LOG_FLUSH();
    bsp_board_leds_init();
 * @brief Function to control LED outputs.
 * @param[in] val Desirable state of the LEDs.
static void output_present(uint8_t val)
    uint32_t i;
    for (i = 0; i < LEDS_NUMBER; i++)
        if (val & (1 << i))
            bsp_board_led_on(i);
            bsp_board_led_off(i);
 * @brief Main function.
 * @return ANSI required int return type.
        uart_init();
    // Debug helper variables
    uint32_t length;
    // Data and acknowledgement payloads
    uint8_t payload[NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH];
    // Set up the user interface (buttons and LEDs)
    ui_init();
    // Initialize the Gazell Link Layer
    bool result_value = nrf_gzll_init(NRF_GZLL_MODE_HOST);
    GAZELLE_ERROR_CODE_CHECK(result_value);
    result_value = nrf_gzll_set_timeslot_period(NRF_GZLLDE_RXPERIOD_DIV_2); // Half RX period on an nRF24Lxx device
    // Initialize the Gazell Pairing Library
    gzp_init();
    result_value = nrf_gzll_set_rx_pipes_enabled(nrf_gzll_get_rx_pipes_enabled() |
                                                 (1 << UNENCRYPTED_DATA_PIPE));
    gzp_pairing_enable(true);
    result_value = nrf_gzll_enable();
    for (;;)
        gzp_host_execute();
        // If a Host ID request received
        if (gzp_id_req_received())
            // Always grant a request
            gzp_id_req_grant();
        length = NRF_GZLL_CONST_MAX_PAYLOAD_LENGTH;
        if (nrf_gzll_get_rx_fifo_packet_count(UNENCRYPTED_DATA_PIPE))
            if (nrf_gzll_fetch_packet_from_rx_fifo(UNENCRYPTED_DATA_PIPE, payload, &length))
                output_present(payload[0]);
        else if (gzp_crypt_user_data_received())
            if (gzp_crypt_user_data_read(payload, (uint8_t *)&length))
