I would like to sign a firmware image with a custom private key. This is intended for OTA firmware update. The key type is ecdsa-p256 and the file containing the key is named ecdsa-dev.pem. The SDK is nRF Connect SDK 1.6.0.
To illustrate the issue, I took the hello_world example and modified it like described below.
In CMakeLists.txt, I set a value for mcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE as follows:
cmake_minimum_required(VERSION 3.13.1)
set(mcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE "\"${CMAKE_CURRENT_LIST_DIR}/ecdsa-dev.pem\"")
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
(got idea from https://devzone.nordicsemi.com/f/nordic-q-a/67510/ncs-recommended-mcuboot-enabled-apps-build-and-flash-methods/324792#324792 )
In prj.conf, I enabled mcuboot as follows:
# Bootloader CONFIG_BOOTLOADER_MCUBOOT=y
In the root of the project (beside CMakeLists.txt), I copied the private key file ecdsa-dev.pem.
Then, when I want to compile with the command west build -b nrf52833dk_nrf52833, I have errors related to undefined reference to `rsa_pub_key' and `rsa_pub_key_len' :
[5/158] Performing build step for 'mcuboot_subimage' [243/250] Linking C executable zephyr\zephyr_prebuilt.elf FAILED: zephyr/zephyr_prebuilt.elf zephyr/zephyr_prebuilt.map C:/Users/dev/ncs/v1.6.0/zephyr/samples/hello_world-mcuboot/build/mcuboot/zephyr/zephyr_prebuilt.map cmd.exe /C "cd . && C:\gnuarmemb\bin\arm-none-eabi-gcc.exe zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -o zephyr\zephyr_prebuilt.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -Wl,-T zephyr/linker_zephyr_prebuilt.cmd -Wl,-Map=C:/Users/dev/ncs/v1.6.0/zephyr/samples/hello_world-mcuboot/build/mcuboot/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/serial/libdrivers__serial.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/mbedtls/libmodules__mbedtls.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/10.2.1/thumb/v7e-m/nofp" -LC:/Users/dev/ncs/v1.6.0/zephyr/samples/hello_world-mcuboot/build/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a -mcpu=cortex-m4 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn && cmd.exe /C "cd /D C:\Users\dev\ncs\v1.6.0\zephyr\samples\hello_world-mcuboot\build\mcuboot\zephyr && "C:\Program Files\CMake\bin\cmake.exe" -E echo "" c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(keys.c.obj):C:/Users/dev/ncs/v1.6.0/bootloader/mcuboot/boot/zephyr/keys.c:52: undefined reference to `rsa_pub_key' c:/gnuarmemb/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(keys.c.obj):(.rodata.bootutil_keys+0x4): undefined reference to `rsa_pub_key_len' collect2.exe: error: ld returned 1 exit status ninja: build stopped: subcommand failed.
Instead of setting mcuboot_CONFIG_BOOT_SIGNATURE_KEY_FILE in the app's CMakeLists.txt, i tried to set it directly in the prj.conf file of mcuboot in bootloader\mcuboot\boot\zephyr (by adding CONFIG_BOOT_SIGNATURE_KEY_FILE="C:\\ota\\ecdsa-dev.pem" for example), but exactly the same error occurs at compile time.
The fact that the error itself is related to a RSA key is a first issue since the custom private key is for ECDSA.
The compilation succeeds in the following cases:
- Either use a custom .pem file containing a rsa-2048 key instead of a ecdsa-p256 key.
- Or compile for the target the nRF52840 DK, using the command
west build -b nrf52840dk_nrf52840
As a consequence, I think that this compilation error might be related to the fact that the nRF52833 embeds less cryptographic hardware compared to the nRF52840, such as the Cryptocell.
Is there a way to use the ecdsa-p256 algorithm with the nRF52833 nevertheless ?
