Azure FOTA Update File Access from Blob Storage
Hello, I'm trying to run the Azure_FOTA sample application from NCS 1.4.2 on a Thingy:91 before adding the functionality to another application. I'm able to connect to IoT Hub just fine via DPS, but I'm not able to download the update file from my Azure Blob Storage account. I had initially set it to private, assuming that I could upload the same root CA cert to the storage account as I have used for both DPS and IoT Hub because of the following lines in the provided prj.conf: However, I can't find a place to do that. I already have CONFIG_AZURE_IOT_HUB_SEC_TAG set to the value used while provisioning device certs, so I'm not sure what the purpose of CONFIG_AZURE_FOTA_SEC_TAG is. Regardless, I don't think a secure connection is my problem yet. After enabling CONFIG_DOWNLOAD_CLIENT_LOG_LEVEL_DBG and CONFIG_DOWNLOAD_CLIENT_LOG_HEADERS, I see that the error I'm getting is now "404 the specified resource does not exist". I have formatted the firmware entry the same as the example in the documentation. 1. Are there detailed instructions on how to setup a Blob storage for FOTA purposes? 2. What is the purpose of CONFIG_AZURE_FOTA_SEC_TAG? The documentation is far from helpful. 3. Why might I be getting a 404 on a file that is now public when using an URL that I copied (and triple-checked) directly from Azure? Thanks, Nick
  • I'm sorry, I don't know what happened to my formatting. This website has not been cooperating for a couple of days. The lines of code I was referring to are:
    # Change the security tag to the tag where the certificates are provisioned
    # for the server where the FOTA image is hosted
    CONFIG_AZURE_FOTA_SEC_TAG=10
  • Hi Nick
    The security tags are so that you are able to save multiple different certificates in your modem. They are not used by the cloud, but by the modem. See here for more information.
    If you used the same certificates for as for azure in general, use the same tag as "CONFIG_AZURE_IOT_HUB_SEC_TAG".
    If you provisioned new certificates for FOTA using another tag, use the tag number you chose when provisioning.
    Regarding question 1 and question 2, I understand that both these are related to your issue with not being able to do a FOTA update?
    Here are the steps I took to create a blob storage:
    1. Create a Azure Storage Account. I just put in a name and used standard settings. This might change for you.
    2. Chose your new Storage account, and go to the containers menu. Press "Create container" and choose a name.
    3. Change something in your code (I added printk("After FOTA\n")) and build the project. Do not flash.
    3. Select the new container. Then press "upload", and upload the file <your_project>/build/zephyr/app_update.bin.
    4. Then just proceed as described in the Azure FOTA sample documentation, Go to your hub, find "device twin", copy and paste the JSON to "desired" and press save.
        Remember to change the "jobID" every time you want it to perform a FOTA again.
        Also remember to change the "host" and "path" variables to what you use on Azure.
        I had to add my container name to "path", as such:
    "path": "fota-container/app-update.bin
    Is this the same method you used to upload the firmware image?
    (PS: You should be able to edit your posts, to fix formatting after you have posted)
    Sigurd Hellesvik
  • Thank you Sigurd. My process was the same but I must have changed a setting somewhere during the creation of the Storage Account or Container as the process looked different today than it did yesterday. It appears to be working now, though I'm concerned that everything is set to public access. How do you suggest we modify this setup so that only administrators and our IoT leaf devices have access to these update files?
    And thank you, I am aware of the edit feature but a problem with our firewall was causing this website to be excessively slow and exhibit odd behavior so I wasn't going to depend on something that didn't work the first time anyway.
  • Hi Nick
    Good to hear that it is working now!
    For the private access:
    I asked the developers, and they say that it does not look like Azure blob storage allow for the use of a custom certificate chain.
    You will have to setup their own endpoints, for example using: Configure TLS mutual authentication for Azure App Service
    Sigurd Hellesvik
