I am currently following the steps as detailed in the following documentation (SDK 11) specifically the graph in the "Transfer of an image to the DFU target"
I am currently able to do the first 2 steps without issue: Enable notification for DFU Control Point CCCD and Write (0x0104) to DFU Control Point
However, when I go to write the image size to the DFU Packet characteristic, the target device returns "10-01-03" to the DFU Control Point. According to this documentation this means that the device is returning a "Not Supported" error.
I've conducted the update using the nRF Connect Mobile app which resulted in the following (successful) output:
Connected to Modified_Device Discovering services... peripheral.discoverServices(nil) Services discovered Starting Legacy DFU... Connected to Modified_Device Services discovered Legacy DFU Service found Discovering characteristics in DFU Service... peripheral.discoverCharacteristics(nil, for: 00001530-1212-EFDE-1523-785FEABCD123) DFU characteristics discovered Reading DFU Version number... peripheral.readValue(00001534-1212-EFDE-1523-785FEABCD123) Read Response received from 00001534-1212-EFDE-1523-785FEABCD123, value (0x): 0100 Version number read: 0.1 Enabling notifications for 00001531-1212-EFDE-1523-785FEABCD123... peripheral.setNotifyValue(true, for: 00001531-1212-EFDE-1523-785FEABCD123) Notifications enabled for 00001531-1212-EFDE-1523-785FEABCD123 DFU Control Point notifications enabled Application with buttonless update found Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x0104, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse) Data written to 00001531-1212-EFDE-1523-785FEABCD123 Jump to bootloader (Op Code = 1, Upload Mode = 4) request sent [Callback] Central Manager did disconnect peripheral Disconnected by the remote device Connecting to Modified_Device... centralManager.connect(peripheral, options: nil) [Callback] Central Manager did connect peripheral Connected to Modified_Device Discovering services... peripheral.discoverServices([00001530-1212-EFDE-1523-785FEABCD123]) Services discovered Legacy DFU Service found Discovering characteristics in DFU Service... peripheral.discoverCharacteristics(nil, for: 00001530-1212-EFDE-1523-785FEABCD123) DFU characteristics discovered Reading DFU Version number... peripheral.readValue(00001534-1212-EFDE-1523-785FEABCD123) Read Response received from 00001534-1212-EFDE-1523-785FEABCD123, value (0x): 0800 Version number read: 0.8 Enabling notifications for 00001531-1212-EFDE-1523-785FEABCD123... peripheral.setNotifyValue(true, for: 00001531-1212-EFDE-1523-785FEABCD123) Notifications enabled for 00001531-1212-EFDE-1523-785FEABCD123 DFU Control Point notifications enabled Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x0104, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse) Writing image sizes (0b, 0b, 23540b) to characteristic 00001532-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x0000000000000000f45b0000, for: 00001532-1212-EFDE-1523-785FEABCD123, type: .withoutResponse) Data written to 00001531-1212-EFDE-1523-785FEABCD123 Start DFU (Op Code = 1, Upload Mode = 4) request sent Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100101 Response (Op Code = 1, Status = 1) received Writing Initialize DFU Parameters... Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x0200, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse) Writing to characteristic 00001532-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0xffffffffffffffff0100feff0a06, for: 00001532-1212-EFDE-1523-785FEABCD123, type: .withoutResponse) Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x0201, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse) Data written to 00001531-1212-EFDE-1523-785FEABCD123 Data written to 00001531-1212-EFDE-1523-785FEABCD123 Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100201 Response (Op Code = 2, Status = 1) received Initialize DFU Parameters completed Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x080c00, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse) Data written to 00001531-1212-EFDE-1523-785FEABCD123 Packet Receipt Notif Req (Op Code = 8, Value = 12) request sent Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x03, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse) Data written to 00001531-1212-EFDE-1523-785FEABCD123 Uploading firmware... Sending firmware to DFU Packet characteristic... Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100301 Response (Op Code = 3, Status = 1) received Upload completed in 10.44 seconds Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x04, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse) Data written to 00001531-1212-EFDE-1523-785FEABCD123 Validate Firmware (Op Code = 4) request sent Notification received from 00001531-1212-EFDE-1523-785FEABCD123, value (0x): 100401 Response (Op Code = 4, Status = 1) received Writing to characteristic 00001531-1212-EFDE-1523-785FEABCD123... peripheral.writeValue(0x05, for: 00001531-1212-EFDE-1523-785FEABCD123, type: .withResponse) Data written to 00001531-1212-EFDE-1523-785FEABCD123 Activate and Reset (Op Code = 5) request sent [Callback] Central Manager did disconnect peripheral Disconnected by the remote device
In this output, it's obvious to see that writing the image size results in the value "10-01-01". However, when I try to replicate these steps manually on the nRF Connect app using the exact same inputs and actions, I receive a "10-01-03" return value upon entering the image size (0x0000000000000000f45b0000).
I just can't seem to understand why the steps work during the automated process, but not during the manual process.
I have also created my own script using the blatann library. Here is the code for it:
def handler(gattc, event):
print("EVENT: ", event)
def main(serial_port):
# Create and open the device
ble_device = BleDevice(serial_port)
ble_device.open()
target_device = "Succ_Hack"
# Scan and connect to the target device.
ble_device.scanner.set_default_scan_params(timeout_seconds=4)
print("Scanning...")
target_address = example_utils.find_target_device(ble_device, target_device)
if not target_address:
print("Device not found...")
ble_device.close()
quit()
peer = ble_device.connect(target_address).wait()
if not peer:
print("Connection to Target Device timed out...")
# Wait up to 10 seconds for service discovery to complete
_, event_args = peer.discover_services().wait(10, exception_on_timeout=False)
print("Service discovery complete!")
## SECURITY PARAMS SETUP. SKIPPING TO CONSERVE SPACE ##
# Get the necessary service characteristics
DFU_Control_Point = Uuid128("00001531-1212-efde-1523-785feabcd123")
DFU_Control_Point = peer.database.find_characteristic(DFU_Control_Point)
DFU_Packet = Uuid128("00001532-1212-efde-1523-785feabcd123")
DFU_Packet = peer.database.find_characteristic(DFU_Packet)
DFU_Version = Uuid128("00001534-1212-efde-1523-785feabcd123")
DFU_Version = peer.database.find_characteristic(DFU_Version)
_, event_args = DFU_Version.read().wait(10, exception_on_timeout=True)
print(event_args.value)
DFU_Control_Point.subscribe(handler, False)
sleep(3)
DFU_Control_Point.write(0x0104)
sleep(3)
DFU_Packet.write_without_response("f45b0000")
sleep(3)
ble_device.close()
if __name__ == '__main__':
main("COM7")
The above code is able to subscribe to and write to DFU Control Point, however when doing a write without response of the image size to the DFU Packet characteristic, 10-01-03 is always returned. This is the case even if the value written is a hex value, string value, or byte value.
My current setup:
1) nRF52 DK. Central device is used as a connector / sniffer
2) nRF52 DK. Peripheral device. Flashed with a legacy compatible DFU service.
Please let me know if there is anymore information I need to provide in order to fix this issue. Any help would be greatly appreciated.
