Onboard LED blinks and nrf52840 does not advertise
I'm trying to open an L2CAP connection and send some test data to the nrf52840 dev board from my computer. But my connections were timing out with 'Page Timeout' (0x04). From this thread, I realized I need to configure the l2cap configuration to accept l2cap connections. However, once I added that code, the device fails to advertise & the onboard LED blinks (even though there is no code to make it blink that I have explicitly invoked).
#define APP_BLE_CONN_CFG_TAG 1
#define APP_BLE_OBSERVER_PRIO 3
#define L2CAP_TX_MPS 30
#define L2CAP_RX_MPS 30
    ret_code_t err_code;
    ble_cfg_t ble_cfg;
    uint32_t ram_start = 0;
    memset(&ble_cfg, 0x00, sizeof(ble_cfg));
    // Set l2cap channel configuration
    ble_cfg.conn_cfg.conn_cfg_tag                        = APP_BLE_CONN_CFG_TAG;
    ble_cfg.conn_cfg.params.l2cap_conn_cfg.rx_mps        = L2CAP_RX_MPS;
    ble_cfg.conn_cfg.params.l2cap_conn_cfg.rx_queue_size = 1;
    ble_cfg.conn_cfg.params.l2cap_conn_cfg.tx_mps        = L2CAP_TX_MPS;
    ble_cfg.conn_cfg.params.l2cap_conn_cfg.tx_queue_size = 1;
    ble_cfg.conn_cfg.params.l2cap_conn_cfg.ch_count      = 1;
    err_code = sd_ble_cfg_set(BLE_CONN_CFG_L2CAP, &ble_cfg, ram_start);
    // Enable BLE stack.
I'm checking to see if the LED blinking is a functionality provided by the app_error code.
Would be amazing if someone could point me in the right direction.
Thanks
  • Hi
    What LED exactly is it that's blinking on the board? LED5 for instance is controlled by the onboard debugger MCU, and just indicates that the debugger is "alive and well".
    Can you also upload the main() loop of your application so I can take a look at what the application starts out by doing? I would suggest referring to the Object Transfer Service example project in the SDK which supports establishing an L2CAP channel reserved for a specific service. Seems pretty close to what you're looking to do.
    Simon
  • It's the only programmable on board LED. I'm using the Sparkfun Pro nRF52840 Mini. Here's the whole code.
     * Copyright (c) 2015 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief Blinky Sample Application main file.
     * This file contains the source code for a sample server application using the LED Button service.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "app_error.h"
    #include "ble.h"
    #include "ble_l2cap.h"
    #include "ble_types.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_conn_params.h"
    #include "nrf_delay.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "boards.h"
    #include "app_timer.h"
    #include "app_button.h"
    #include "ble_lbs.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define MY_GPIO_PIN_1  NRF_GPIO_PIN_MAP(0, 3)
    #define MY_GPIO_PIN_2  NRF_GPIO_PIN_MAP(0, 4)
    #define MY_GPIO_PIN_3 NRF_GPIO_PIN_MAP(0, 5)
    #define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
    #define CONNECTED_LED                   MY_GPIO_PIN_1                         /**< Is on when device has connected. */
    #define LEDBUTTON_LED                   MY_GPIO_PIN_2                         /**< LED to be toggled with the help of the LED Button Service. */
    #define CHANNEL_DATA_LED                MY_GPIO_PIN_3 // To be on when data is recvd on l2cap channel
    #define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
    #define DEVICE_NAME                     "Super_Blinky"                         /**< Name of device. Will be included in the advertising data. */
    #define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
    #define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(100, UNIT_1_25_MS)        /**< Minimum acceptable connection interval (0.5 seconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(200, UNIT_1_25_MS)        /**< Maximum acceptable connection interval (1 second). */
    #define SLAVE_LATENCY                   0                                       /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)                   /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
    #define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define L2CAP_SDU_BUF_SIZE 1024
    #define L2CAP_RX_MPS                         200                                /**< Size of L2CAP Rx MPS (must be at least BLE_L2CAP_MPS_MIN).*/
    #define L2CAP_TX_MPS                         200                                /**< Size of L2CAP Tx MPS (must be at least BLE_L2CAP_MPS_MIN).*/
    BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                         /**< Context for the Queued Write module.*/
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
    static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
    static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
    static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
    static uint8_t m_l2cap_sdu_buf[L2CAP_SDU_BUF_SIZE];         /**< Buffer for storing an encoded scan data. */
    static ble_data_t const sdu_buf = {
      .len = L2CAP_SDU_BUF_SIZE,
      .p_data = m_l2cap_sdu_buf
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = m_enc_scan_response_data,
    static void led_on(uint8_t led)
        nrf_gpio_pin_write(led, 1);
    static void led_off(uint8_t led)
        nrf_gpio_pin_write(led, 0);
    /**@brief Function for assert macro callback.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for the LEDs initialization.
     * @details Initializes all LEDs used by the application.
    static void leds_init(void)
        nrf_gpio_cfg_output(MY_GPIO_PIN_1);
        nrf_gpio_cfg_output(MY_GPIO_PIN_2);
        nrf_gpio_cfg_output(MY_GPIO_PIN_3);
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module.
    static void timers_init(void)
        // Initialize timer module, making it use the scheduler
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        ble_gap_adv_params_t adv_params;
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling write events to the LED characteristic.
     * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
     * @param[in] led_state Written/desired state of the LED.
    static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
        if (led_state)
            led_on(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED ON!");
            led_off(LEDBUTTON_LED);
            NRF_LOG_INFO("Received LED OFF!");
        ble_lbs_init_t     init     = {0};
        // Initialize LBS.
        init.led_write_handler = led_write_handler;
        err_code = ble_lbs_init(&m_lbs, &init);
    /**@brief Function for handling the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module that
     *          are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply
     *       setting the disconnect_on_fail config parameter, but instead we use the event
     *       handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        bsp_board_led_on(ADVERTISING_LED);
    // From the experimental ble peripheral OTS example
    static void on_l2cap_ch_rx(ble_evt_t const * const p_ble_evt)
        nrf_gpio_pin_write(CHANNEL_DATA_LED, 1);
        NRF_LOG_DEBUG("Bytes received: %i", p_ble_evt->evt.l2cap_evt.params.rx.sdu_len);
        NRF_LOG_HEXDUMP_DEBUG(p_ble_evt->evt.l2cap_evt.params.rx.sdu_buf.p_data,
        uint16_t local_cid;
        ble_l2cap_ch_setup_params_t setup_params;
           case BLE_L2CAP_EVT_CH_SETUP_REQUEST:
                local_cid = p_ble_evt->evt.l2cap_evt.local_cid;
                setup_params = (ble_l2cap_ch_setup_params_t) {
                  .le_psm = p_ble_evt->evt.l2cap_evt.params.ch_setup_request.le_psm,
                  .status = BLE_L2CAP_CH_STATUS_CODE_SUCCESS,
                  .rx_params = {
                    .rx_mtu = p_ble_evt->evt.l2cap_evt.params.ch_setup_request.tx_params.tx_mtu,
                    .rx_mps = p_ble_evt->evt.l2cap_evt.params.ch_setup_request.tx_params.tx_mps,
                    .sdu_buf = sdu_buf
                if (NRF_SUCCESS != sd_ble_l2cap_ch_setup(p_ble_evt->evt.l2cap_evt.conn_handle, &local_cid, &setup_params))
            case BLE_L2CAP_EVT_CH_RX:
                NRF_LOG_DEBUG("BLE_L2CAP_EVT_CH_RX");
                on_l2cap_ch_rx(p_ble_evt);
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                led_on(CONNECTED_LED);
                bsp_board_led_off(ADVERTISING_LED);
                err_code = app_button_enable();
                NRF_LOG_INFO("Disconnected");
                led_off(CONNECTED_LED);
                err_code = app_button_disable();
                advertising_start();
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                       BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                       NULL,
                                                       NULL);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
        ble_cfg_t ble_cfg;
        if (false) {
    /**@brief Function for handling events from the button handler module.
     * @param[in] pin_no        The pin that the event applies to.
     * @param[in] button_action The button action (press/release).
    static void button_event_handler(uint8_t pin_no, uint8_t button_action)
        switch (pin_no)
            case LEDBUTTON_BUTTON:
                NRF_LOG_INFO("Send button state change.");
                err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
                if (err_code != NRF_SUCCESS &&
                    err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                    err_code != NRF_ERROR_INVALID_STATE &&
                    err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(pin_no);
    /**@brief Function for initializing the button handler module.
    static void buttons_init(void)
        //The array must be static because a pointer to it will be saved in the button handler module.
        static app_button_cfg_t buttons[] =
            {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
        err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                                   BUTTON_DETECTION_DELAY);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Function for application main entry.
        // Initialize.
        log_init();
        leds_init();
        timers_init();
        buttons_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("Blinky example started.");
        // Enter main loop.
        for (;;)
            idle_state_handle();
    The section of code in 'ble_stack_init' wrapped in an 'if (false)' is causing the device to stop advertising. I have been following the ots example as a guideline, but I'm starting from the ble_app_blinky example to keep things simple since I just need to accept arbitrary data on the l2cap channel.
  • I just checked, and it seems to restart after the call to nrf_sdh_ble_enable when I'm configuring the l2cap connections.
    UPDATE: It looks like it's failing with NRF_ERROR_NO_MEM.
    UPDATE: The call to nrf_sdh_ble_enable doesn't fail when I set the ch_count on l2cap_conn_cfg to 0 instead of 1.
  • Hi
    Okay, I just assumed you were working on an nRF52840 DK. A less comprehensive L2CAP example is the IPSP acceptor example I think, which just demonstrates the usage of an L2CAP connection oriented channel. Do you know what pin on the nRF52840 the LED is connected to?
    Simon
  • I have LEDs connected to pins 3, 4 & 5.
    Not sure if you've noticed my message updates, but it seems like the nrf_sdh_ble_enable call only fails when l2cap_conn_cfg.ch_count is non-zero.
    I will build the ipsp acceptor and see how that works out.
