void main(void)
//Gpio_Initialise();
I2C_Driver_Init();
I2C_Scan_Address();
struct inv_icm20948_serif icm20948_serif;
icm20948_serif.context = 0; /* no need */
icm20948_serif.read_reg = idd_io_hal_read_reg;
icm20948_serif.write_reg = idd_io_hal_write_reg;
icm20948_serif.max_read = 1024 * 16; /* maximum number of bytes allowed per serial read */
icm20948_serif.max_write = 1024 * 16; /* maximum number of bytes allowed per serial write */
icm20948_serif.is_spi = interface_is_SPI();
icm20948_init(idd_io_hal_read_reg, idd_io_hal_write_reg, inv_icm20948_sleep, inv_icm20948_sleep);
icm_device.base_state.serial_interface = SERIAL_INTERFACE_I2C;
inv_icm20948_reset_states(&icm_device, &icm20948_serif);
inv_icm20948_register_aux_compass(&icm_device, INV_ICM20948_COMPASS_ID_AK09916, AK0991x_DEFAULT_I2C_ADDR);
rc = icm20948_sensor_setup();
if (icm_device.selftest_done && !icm_device.offset_done)
// If we've run selftes and not already set the offset.
inv_icm20948_set_offset(&icm_device, unscaled_bias);
icm_device.offset_done = 1;
//enable sensors
rc |= inv_icm20948_enable_sensor(&icm_device, idd_sensortype_conversion(INV_SENSOR_TYPE_RAW_GYROSCOPE), 1);
//rc |= inv_icm20948_enable_sensor(&icm_device, idd_sensortype_conversion(INV_SENSOR_TYPE_RAW_ACCELEROMETER), 1);
// rc |= inv_icm20948_enable_sensor(&icm_device, idd_sensortype_conversion(INV_SENSOR_TYPE_STEP_COUNTER), 1);
//rc |= inv_icm20948_enable_sensor(&icm_device, idd_sensortype_conversion(INV_SENSOR_TYPE_MAGNETOMETER), 1);
// rc |= inv_icm20948_enable_sensor(&icm_device, idd_sensortype_conversion(INV_SENSOR_TYPE_RAW_MAGNETOMETER), 1);
//rc |= inv_icm20948_enable_sensor(&icm_device, idd_sensortype_conversion(INV_SENSOR_TYPE_GAME_ROTATION_VECTOR), 1);
if(rc)
printk("\r\nerror detected %d\r\n",rc );
while(1);
while(1)
int rv = inv_icm20948_poll_sensor(&icm_device, (void *)0, build_sensor_event_data);
I am using nrf5340 and icm20948 for our development. i had initialized things as shown in code attached.
this work fine for me. but when i am uncommenting rc |= inv_icm20948_enable_sensor(&icm_device, idd_sensortype_conversion(INV_SENSOR_TYPE_MAGNETOMETER), 1); system is giving error * buffer overflow detected * .
i tried to increase HARDWARE_FIFO_SIZE to 4096 from 1024 but still issue is available. then i tried to increase stack size
#define CONFIG_MAIN_STACK_SIZE 1024
#define CONFIG_PRIVILEGED_STACK_SIZE 1024
to 2048 and 4096
with all combination.
but still issue is present kindly help me
