Deep sleep system off mode
I have nrf52832 dk and soft dveice s132 am using ble app template code.
I need help in this code that as:
1. as i flash the code on dk, the device should be initally in System off without any button press , giving nearly 0.5-0.7 micro amp current.
2. then The application will stop advertising after 3 minutes and then go to system-off mode.
3. To wake it up, press Button 1, and it will start advertising again. i am able to fullfill point 2 and 3. pls help how can i do the point 1 in same code
As suggested by you : The Template Application is an application that you can use as a starting point for developing your own application, using the hardware delivered in the nRF5 Development Kit. The application will stop advertising after 3 minutes and then go to system-off mode. To wake it up, press Button 1, and it will start advertising again. I have followed this. I am able to find the device goes to system oFF mode.
  • In start of main() check if button is pressed?
    If pressed, start advertisement.
    If not pressed, go to sleep.
    * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
    * All rights reserved.
    * list of conditions and the following disclaimer.
    * Semiconductor ASA integrated circuit in a product or a software update for
    * such product, must reproduce the above copyright notice, this list of
    * conditions and the following disclaimer in the documentation and/or other
    * materials provided with the distribution.
    * contributors may be used to endorse or promote products derived from this
    * software without specific prior written permission.
    * Nordic Semiconductor ASA integrated circuit.
    * engineered, decompiled, modified and/or disassembled.
    /** @file
    * @defgroup ble_sdk_uart_over_ble_main main.c
    * @ingroup ble_sdk_app_nus_eval
    * @brief UART over BLE application main file.
    * This file contains the source code for a sample application that uses the Nordic UART service.
    * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #include "app_button.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY 0 /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
    static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
    * @warning This handler is an example only and does not fit a final product. You need to analyse
    * how your product is supposed to react in case of Assert.
    * @param[in] line_num Line number of the failing ASSERT call.
    * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
    * the device. It also sets the permissions and appearance.
    uint32_t err_code;
    ble_gap_conn_params_t gap_conn_params;
    strlen(DEVICE_NAME));
    gap_conn_params.slave_latency = SLAVE_LATENCY;
    gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    * application about an error.
    * @param[in] nrf_error Error code containing information about what went wrong.
    APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
    * @details This function will process the data received from the Nordic UART BLE Service and send
    * it to the UART module.
    * @param[in] p_evt Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
    uint32_t err_code;
    for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
    do
    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
    } while (err_code == NRF_ERROR_BUSY);
    if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
    while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t err_code;
    ble_nus_init_t nus_init;
    // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
    * @details This function will be called for all events in the Connection Parameters Module
    * which are passed to the application.
    * @note All this function does is to disconnect. This could have been done by simply setting
    * the disconnect_on_fail config parameter, but instead we use the event handler
    * mechanism to demonstrate its use.
    * @param[in] p_evt Event received from the Connection Parameters Module.
    uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
    uint32_t err_code;
    cp_init.p_conn_params = NULL;
    cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
    cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
    cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
    cp_init.disconnect_on_fail = false;
    cp_init.evt_handler = on_conn_params_evt;
    cp_init.error_handler = conn_params_error_handler;
    // Prepare wakeup buttons.
    * @param[in] ble_adv_evt Advertising event.
    uint32_t err_code;
    switch (ble_adv_evt)
    case BLE_ADV_EVT_FAST:
    case BLE_ADV_EVT_IDLE:
    sleep_mode_enter();
    * @param[in] p_ble_evt Bluetooth stack event.
    * @param[in] p_context Unused.
    uint32_t err_code;
    case BLE_GAP_EVT_CONNECTED:
    NRF_LOG_INFO("Connected");
    NRF_LOG_INFO("Disconnected");
    ble_gap_phys_t const phys =
    .rx_phys = BLE_GAP_PHY_AUTO,
    .tx_phys = BLE_GAP_PHY_AUTO,
    } break;
    // Pairing not supported
    case BLE_GATTC_EVT_TIMEOUT:
    case BLE_GATTS_EVT_TIMEOUT:
    // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
    * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
    m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
    NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
    p_gatt->att_mtu_desired_central,
    p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    /**@snippet [UART Initialization] */
    uint32_t err_code;
    ble_advertising_init_t init;
    init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids = m_adv_uuids;
    init.config.ble_adv_fast_enabled = true;
    init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
    //#define BT0_SHORT_PUSH BSP_EVENT_KEY_0
    #define BT0_LONG_PUSH BSP_EVENT_KEY_1
    * @param[in] event Event generated by button press.
    uint32_t err_code;
    switch (event)
    case BSP_EVENT_SLEEP:
    sleep_mode_enter();
    break; // BSP_EVENT_SLEEP
    //case BT0_SHORT_PUSH:
    // NRF_LOG_INFO("Short button press");
    // break;
    case BT0_LONG_PUSH:
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    advertising_start();
    NRF_LOG_INFO("Long button press");
    /**@brief Function for handling app_uart events.
    * a string. The string will be be sent over BLE when the last character received was a
    * 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t err_code;
    switch (p_event->evt_type)
    case APP_UART_DATA_READY:
    index++;
    if ((data_array[index - 1] == '\n') ||
    (data_array[index - 1] == '\r') ||
    (index >= m_ble_nus_max_data_len))
    if (index > 1)
    do
    } while (err_code == NRF_ERROR_RESOURCES);
    index = 0;
    case APP_UART_FIFO_ERROR:
    /**@brief Function for initializing the UART module.
    static void uart_init(void)
    uint32_t err_code;
    .rx_pin_no = RX_PIN_NUMBER,
    .tx_pin_no = TX_PIN_NUMBER,
    .rts_pin_no = RTS_PIN_NUMBER,
    .cts_pin_no = CTS_PIN_NUMBER,
    .use_parity = false,
    .baud_rate = NRF_UART_BAUDRATE_115200
    #else
    .baud_rate = NRF_UARTE_BAUDRATE_115200
    UART_RX_BUF_SIZE,
    UART_TX_BUF_SIZE,
    uart_event_handle,
    APP_IRQ_PRIORITY_LOWEST,
    err_code);
    * @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    // err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_PUSH, BT0_SHORT_PUSH);
    // APP_ERROR_CHECK(err_code);
    err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_LONG_PUSH, BT0_LONG_PUSH);
    /*err_code = bsp_btn_ble_init(NULL, &startup_event);
    *p_erase_bonds = (startup_event == BSP_EVENT_CLEAR_BONDING_DATA);*/
    static void log_init(void)
    UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
    nrf_pwr_mgmt_run();
    /**@brief Application main function.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    // gap_params_init();
    // gatt_init();
    // services_init();
    // advertising_init();
    //conn_params_init();
    // Start execution.
    //advertising_start();
    // Enter main loop.
    for (;;)
    idle_state_handle();
    pls tell where and what to do
  • somewhere in end of main():
    if(bsp_button_is_pressed() == true)
    sleep_mode_enter();
    advertising_start()
    for(;;)
    idle_state_handler();
    /** @file
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    uint32_t err_code;
    uint32_t err_code;
    do
    uint32_t err_code;
    // Initialize NUS.
    uint32_t err_code;
    uint32_t err_code;
    uint32_t err_code;
    sleep_mode_enter();
    uint32_t err_code;
    } break;
    uint32_t err_code;
    uint32_t err_code;
    switch (event)
    sleep_mode_enter();
    // break;
    case BT0_LONG_PUSH:
    gap_params_init();
    gatt_init();
    services_init();
    conn_params_init();
    // advertising_start();
    uint32_t err_code;
    index++;
    if (index > 1)
    do
    index = 0;
    uint32_t err_code;
    #else
    UART_RX_BUF_SIZE,
    UART_TX_BUF_SIZE,
    uart_event_handle,
    err_code);
    nrf_pwr_mgmt_run();
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    if(bsp_button_is_pressed(BSP_BOARD_BUTTON_0)==true)
    sleep_mode_enter();
    advertising_init();
    ble_stack_init();
    // gatt_init();
    // services_init();
    // Start execution.
    // Enter main loop.
    for (;;)
    i did this but on button pressing my device is not advertising
