want to achieve 1-2 Mbps through BLE.
I am working on project in which i want to read data from sd card and send it to mobile through BLE , I am using ble_nus_send to send data but when i decrease the delay then its giving me error 19 and when i increase delay then it is running smoothly .
Can i achieve something between 1-2 Mbps through ble_nus_Send or have to do with some other approach .
  • Mohsin khan said:
    This is link in which its says you can send packet after 150 micro seconds .
    Aha, thank you for clarifying where you have read this. You might have misunderstood this part of the guide. The 150 µs mentioned here is the Inter-Frame space, which is the delay between each packet in a connection connection event. This part of the guide is also primarily a discussion on the theoretical speeds of BLE 5.0, not an actual implementation. The SoftDevice takes care of these timings for you, as its part of the BLE specification.
    Are you familiar with the nRF sniffer tool? It is a powerful tool to wield when developing for BLE since it lets you see the on-air traffic.
    It would be useful for you to familiarize with this tool in order to see what is actually being transferred between your devices.
    Mohsin khan said:
    Now i am not using delay i have set min and max interval 50 ms both
    and i have changed values according to 1327 kbps but still getting error no 19 .
    Please tell me exactly which parameters you have changed, and how you have changed them.
    With the main code you have provided below you will attempt to queue 100 notifications for sending immediately. This will in turn immediately exceed your HVN queue of 10 or 50.
    Furthermore, the main of the code you have provided is incredibly cluttered with commented out code. This drastically decreases readability and makes it hard to understand coherently. I recommend that you remove all commented out code from your active development. If there is code you might like to 'keep for later' I highly recommend that you remove this to a separate file for safe keeping and future access.
    Mohsin khan said:
    I have increased and set the one , There is no difference in both programs .
    What have you tried to change this to? Be as specific as possible. The more information your provide, the easier it will be for us to help you resolve your issue.
    Karl
  • Hello karl,
    i have resolved the issue in this code but issue is data rate is not good as i want 130kBps but its just 30kBps , I want to send this data to app and when i try to send , App get hanged in mobile but it gives me data , I am pasting code here
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
     * @brief BLE Heart Rate Collector application main file.
     * This file contains the source code for a sample heart rate collector.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "bsp.h"
    #include "diskio_blkdev.h"
    #include "ff.h"
    #include "nrf.h"
    #include "nrf_block_dev_sdc.h"
    #include "nrf_delay.h"
    #include "nrf_drv_gpiote.h"
    #include "nrf_drv_timer.h"
    #include "app_uart.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "ble_nus.h"
    #include "nrf_ble_qwr.h"
    #include "ble_gatts.h"
    #include "app_error.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "ble.h"
    #include "ble_bas_c.h"
    #include "ble_conn_state.h"
    #include "ble_db_discovery.h"
    #include "ble_hci.h"
    #include "ble_hrs_c.h"
    #include "ble_srv_common.h"
    #include "bsp_btn_ble.h"
    #include "fds.h"
    #include "nordic_common.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_lesc.h"
    #include "nrf_ble_scan.h"
    #include "nrf_fstorage.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdm.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #if defined(UART_PRESENT)
    #include "nrf_uart.h"
    #if defined(UARTE_PRESENT)
    #include "nrf_uarte.h"
    #define FILE_NAME "hr.CSV"
    #define TEST_STRING "SD card example."
    #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN
    #ifdef BSP_BUTTON_0
    #define PIN_IN BSP_BUTTON_0
    #ifndef PIN_IN
    #error "Please indicate input pin"
    #ifdef BSP_LED_1
    #define PIN_OUT BSP_LED_1
    #ifndef PIN_OUT
    #error "Please indicate output pin"
    #endif /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);
    BLE_NUS_DEF(m_nus, 6);
    NRF_BLE_QWRS_DEF(m_qwr, 6);
    static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
            {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};
    #define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION 18000
    volatile uint8_t button_pressed = 0;
    volatile int timer_call = 0;
    FRESULT ff_result;
    static FIL file;
    uint16_t heart_rate;
    char s_heartrate[4];
    volatile uint8_t c;
    uint32_t bytes_written;
    const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(1);
    #define SDC_SCK_PIN ARDUINO_13_PIN  ///< SDC serial clock (SCK) pin.
    #define SDC_MOSI_PIN ARDUINO_11_PIN ///< SDC serial data in (DI) pin.
    #define SDC_MISO_PIN ARDUINO_12_PIN ///< SDC serial data out (DO) pin.
    #define SDC_CS_PIN ARDUINO_10_PIN   ///< SDC chip select (CS) pin.
    #define MIN_CONN_INTERVAL                    (uint16_t)(MSEC_TO_UNITS(50, UNIT_1_25_MS))
    #define MAX_CONN_INTERVAL                    (uint16_t)(MSEC_TO_UNITS(50, UNIT_1_25_MS))    /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY 0                                      /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3
    #define DEVICE_NAME "nRF Relay"
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT ;
    #define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_SOC_OBSERVER_PRIO 1 /**< Applications' SoC observer priority. You shouldn't need to modify this value. */
    #define LESC_DEBUG_MODE 0 /**< Set to 1 to use LESC debug keys, allows you to use a sniffer to inspect traffic. */
    #define SEC_PARAM_BOND 1                               /**< Perform bonding. */
    #define SEC_PARAM_MITM 0                               /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC 1                               /**< LE Secure Connections enabled. */
    #define SEC_PARAM_KEYPRESS 0                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
    #define SEC_PARAM_OOB 0                                /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE 7                       /**< Minimum encryption key size in octets. */
    #define SEC_PARAM_MAX_KEY_SIZE 16                      /**< Maximum encryption key size in octets. */
    #define SCAN_DURATION_WITELIST 3000 /**< Duration of the scanning in units of 10 milliseconds. */
    #define HART_RATE_SERVICE_UUID_IDX 0
    #define TARGET_UUID BLE_UUID_HEART_RATE_SERVICE                /**< Target device uuid that application is looking for. */
    static uint16_t m_conn_handle_hrs_c = BLE_CONN_HANDLE_INVALID; /**< Connection handle for the HRS central application */
    static uint16_t m_conn_handle_rscs_c = BLE_CONN_HANDLE_INVALID;
    char init[] = "Long,Lat,Alt,Accelx,Accely,Accelz,GYROx,GYROy,GYROz,Magx,Magy,Magz,Heartrate,Bat %  ";
    char data[] = "2221";
    /**@brief Macro to unpack 16bit unsigned UUID from octet stream. */
    #define UUID16_EXTRACT(DST, SRC) \
      do {                           \
        (*(DST)) = (SRC)[1];         \
        (*(DST)) <<= 8;              \
        (*(DST)) |= (SRC)[0];        \
      } while (0)
    NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
        NRF_SDH_BLE_CENTRAL_LINK_COUNT,
        NRF_BLE_GQ_QUEUE_SIZE);
    BLE_HRS_C_DEF(m_hrs_c);                   /**< Structure used to identify the heart rate client module. */
    BLE_BAS_C_DEF(m_bas_c);                   /**< Structure used to identify the Battery Service client module. */
    NRF_BLE_GATT_DEF(m_gatt);                 /**< GATT module instance. */
    BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, 2); /**< Database discovery module instances. */
    NRF_BLE_SCAN_DEF(m_scan);                 /**< DB discovery module instance. */
                                              /**< Scanning module instance. */
    static uint16_t m_conn_handle;           /**< Current connection handle. */
    static bool m_whitelist_disabled;        /**< True if whitelist has been temporarily disabled. */
    static bool m_memory_access_in_progress; /**< Flag to keep track of ongoing operations on persistent memory. */
    void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action) {
      c = 1;
    NRF_BLOCK_DEV_SDC_DEFINE(
        m_block_dev_sdc,
        NRF_BLOCK_DEV_SDC_CONFIG(
            SDC_SECTOR_SIZE,
            APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)),
        NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00"));
    void timer_led_event_handler(nrf_timer_event_t event_type, void *p_context) {
      switch (event_type) {
      case NRF_TIMER_EVENT_COMPARE0:
      timer_call = 1;
        //Do nothing.
    static void fatfs_example() {
      static FATFS fs;
      static DIR dir;
      static FILINFO fno;
      DSTATUS disk_state = STA_NOINIT;
      // Initialize FATFS disk I/O interface by providing the block device.
      static diskio_blkdev_t drives[] =
              DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)};
      diskio_blockdev_register(drives, ARRAY_SIZE(drives));
      NRF_LOG_INFO("Initializing disk 0 (SDC)...");
      for (uint32_t retries = 3; retries && disk_state; --retries) {
        disk_state = disk_initialize(0);
      if (disk_state) {
        NRF_LOG_INFO("Disk initialization failed.");
        return;
      uint32_t blocks_per_mb = (1024uL * 1024uL) / m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_size;
      uint32_t capacity = m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_count / blocks_per_mb;
      NRF_LOG_INFO("Capacity: %d MB", capacity);
      NRF_LOG_INFO("Mounting volume...");
      ff_result = f_mount(&fs, "", 1);
      if (ff_result) {
        NRF_LOG_INFO("Mount failed.");
        return;
      NRF_LOG_INFO("\r\n Listing directory: /");
      ff_result = f_opendir(&dir, "/");
      if (ff_result) {
        NRF_LOG_INFO("Directory listing failed!");
        return;
      do {
        ff_result = f_readdir(&dir, &fno);
        if (ff_result != FR_OK) {
          NRF_LOG_INFO("Directory read failed.");
          return;
        if (fno.fname[0]) {
          if (fno.fattrib & AM_DIR) {
            NRF_LOG_RAW_INFO("   <DIR>   %s", (uint32_t)fno.fname);
          } else {
            NRF_LOG_RAW_INFO("%9lu  %s", fno.fsize, (uint32_t)fno.fname);
      } while (fno.fname[0]);
      NRF_LOG_RAW_INFO("");
      uint8_t string[15];
      NRF_LOG_INFO(string);
      NRF_LOG_INFO("Writing to file " FILE_NAME "...");
      ff_result = f_open(&file, FILE_NAME, FA_READ);
        NRF_LOG_INFO("Unable to open or create file: " FILE_NAME ".");
        return;
      uint16_t size;
      size = f_size(&file);
      char *data = NULL;
      data = malloc(size); /* allocate memory to store image data */
      NRF_LOG_INFO("File size: %d bytes", size);
      int b = 86;
      for (int a = 85; a < size; a = a + 85) {
        //NRF_LOG_INFO("%d \n",a);
        //NRF_LOG_INFO("%d \n",b);
        f_lseek(&file, b);
        ff_result = f_read(&file, string, 85, (UINT *)&bytes_written);
          NRF_LOG_INFO("read failed\r\n.");
        } else {
          // NRF_LOG_INFO("%d bytes read.", bytes_written);
        //for(int i=0;i<bytes_written;i++)
        // NRF_LOG_INFO("%d  ->  %c",i,string[i]);
        //nrf_delay_ms(20);
        b = b + 85;
      NRF_LOG_INFO("done");
      (void)f_close(&file);
      //ff_result = f_write(&file, string, sizeof(string), (UINT *) &bytes_written);
      //if (ff_result != FR_OK)
      //    NRF_LOG_INFO("Write failed\r\n.");
      //else
      //    NRF_LOG_INFO("%d bytes written.", bytes_written);
      //ff_result = f_write(&file, "\n",1,&bytes_written);
      //(void) f_close(&file);
      //for(int a=1 ; a<=600 ; a++)
      //for (int b=1 ;b<=14;b++)
      //ff_result = f_write(&file, data, sizeof(data), (UINT *) &bytes_written);
      //else
      //ff_result = f_write(&file, ",",1,&bytes_written);
      //nrf_delay_ms(60);
    /**< Scan parameters requested for scanning and connection. */
    static ble_gap_scan_params_t const m_scan_param =
            .active = 0x01,
    #if (NRF_SD_BLE_API_VERSION > 7)
            .interval_us = NRF_BLE_SCAN_SCAN_INTERVAL * UNIT_0_625_MS,
            .window_us = NRF_BLE_SCAN_SCAN_WINDOW * UNIT_0_625_MS,
    #else
            .interval = NRF_BLE_SCAN_SCAN_INTERVAL,
            .window = NRF_BLE_SCAN_SCAN_WINDOW,
            .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
            .timeout = SCAN_DURATION_WITELIST,
            .scan_phys = BLE_GAP_PHY_1MBPS,
            .extended = true,
    /**@brief Names which the central applications will scan for, and which will be advertised by the peripherals.
     *  if these are set to empty strings, the UUIDs defined below will be used
    static char const m_target_periph_name[] = ""; /**< If you want to connect to a peripheral using a given advertising name, type its name here. */
    static bool is_connect_per_addr = true;        /**< If you want to connect to a peripheral with a given address, set this to true and put the correct address in the variable below. */
    static ble_gap_addr_t const m_target_periph_addr =
            /* Possible values for addr_type:
           BLE_GAP_ADDR_TYPE_PUBLIC,
           BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
           BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_RESOLVABLE,
           BLE_GAP_ADDR_TYPE_RANDOM_PRIVATE_NON_RESOLVABLE. */
            .addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC,
            .addr = {0x8D, 0xFE, 0x23, 0x86, 0x77, 0xD9}};
    static void scan_start(void);
    /**@brief Function for asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
    void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name) {
      app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for handling the Heart Rate Service Client and Battery Service Client errors.
    static void service_error_handler(uint32_t nrf_error) {
      APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t *p_evt) {
      ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
      ble_bas_on_db_disc_evt(&m_bas_c, p_evt);
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void adv_scan_start(void) {
      ret_code_t err_code;
      //check if there are no flash operations in progress
      if (!nrf_fstorage_is_busy(NULL)) {
        // Start scanning for peripherals and initiate connection to devices which
        // advertise Heart Rate or Running speed and cadence UUIDs.
        scan_start();
        // Turn on the LED to signal scanning.
        bsp_board_led_on(BSP_BOARD_LED_0);
        // Start advertising.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    static void pm_evt_handler(pm_evt_t const *p_evt) {
      pm_handler_on_pm_evt(p_evt);
      pm_handler_disconnect_on_sec_failure(p_evt);
      pm_handler_flash_clean(p_evt);
      switch (p_evt->evt_id) {
        // Bonds are deleted. Start scanning.
        adv_scan_start();
     * @brief Function for shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event) {
      switch (event) {
      case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
        // Prepare wakeup buttons.
      return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    static void multi_qwr_conn_handle_assign(uint16_t conn_handle) {
      for (uint32_t i = 0; i < NRF_SDH_BLE_TOTAL_LINK_COUNT; i++) {
        if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID) {
          ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], conn_handle);
    volatile uint8_t peristat=0;
    static void on_ble_peripheral_evt(ble_evt_t const *p_ble_evt) {
      uint32_t err_code;
      switch (p_ble_evt->header.evt_id) {
      case BLE_GAP_EVT_CONNECTED:
        NRF_LOG_INFO("peripheral Connected");
        peristat=1;
        multi_qwr_conn_handle_assign(p_ble_evt->evt.gap_evt.conn_handle);
        NRF_LOG_INFO("Disconnected");
        peristat=0;
      case BLE_GAP_EVT_PHY_UPDATE_REQUEST: {
        ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
                .tx_phys = BLE_GAP_PHY_2MBPS | BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
      } break;
        // Pairing not supported
      case BLE_GATTC_EVT_TIMEOUT:
      case BLE_GATTS_EVT_TIMEOUT:
        // No implementation needed.
    static void on_ble_central_evt(ble_evt_t const *p_ble_evt) {
      ble_gap_evt_t const *p_gap_evt = &p_ble_evt->evt.gap_evt;
      // Upon connection, check which peripheral is connected (HR or RSC), initiate DB
      // discovery, update LEDs status, and resume scanning, if necessary.
      case BLE_GAP_EVT_CONNECTED: {
        NRF_LOG_INFO("Central connected");
        // If no Heart Rate sensor or RSC sensor is currently connected, try to find them on this peripheral.
        if ((m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID) || (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)) {
          NRF_LOG_INFO("Attempt to find HRS or RSC on conn_handle 0x%x", p_gap_evt->conn_handle);
          err_code = ble_db_discovery_start(&m_db_disc[0], p_gap_evt->conn_handle);
          if (err_code == NRF_ERROR_BUSY) {
            err_code = ble_db_discovery_start(&m_db_disc[1], p_gap_evt->conn_handle);
          } else {
        // Assign connection handle to the QWR module.
        multi_qwr_conn_handle_assign(p_gap_evt->conn_handle);
        // Update LEDs status, and check whether to look for more peripherals to connect to.
        bsp_board_led_on(BSP_BOARD_LED_1);
        if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT) {
          bsp_board_led_off(BSP_BOARD_LED_0);
        } else {
          // Resume scanning.
          scan_start();
      } break; // BLE_GAP_EVT_CONNECTED
      // Upon disconnection, reset the connection handle of the peer that disconnected,
      // update the LEDs status and start scanning again.
      case BLE_GAP_EVT_DISCONNECTED: {
        if (p_gap_evt->conn_handle == m_conn_handle_hrs_c) {
          NRF_LOG_INFO("HRS central disconnected (reason: %d)",
              p_gap_evt->params.disconnected.reason);
          err_code = nrf_ble_scan_filter_set(&m_scan,
              SCAN_UUID_FILTER,
              &m_adv_uuids[HART_RATE_SERVICE_UUID_IDX]);
        if ((m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID) || (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID)) {
          // Start scanning.
          scan_start();
          // Update LEDs status.
        if (ble_conn_state_central_conn_count() == 0) {
          bsp_board_led_off(BSP_BOARD_LED_1);
      } break; // BLE_GAP_EVT_DISCONNECTED
      case BLE_GAP_EVT_TIMEOUT: {
        // No timeout for scanning is specified, so only connection attemps can timeout.
        if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN) {
          NRF_LOG_INFO("Connection Request timed out.");
      } break;
      case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST: {
        // Accept parameters requested by peer.
        err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
            &p_gap_evt->params.conn_param_update_request.conn_params);
      } break;
      } break;
    /**@brief   Function for handling BLE events from peripheral applications.
     * @details Updates the status LEDs used to report the activity of the peripheral applications.
    static bool ble_evt_is_advertising_timeout(ble_evt_t const *p_ble_evt) {
      return (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_SET_TERMINATED);
    static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context) {
      uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
      uint16_t role = ble_conn_state_role(conn_handle);
      // Based on the role this device plays in the connection, dispatch to the right handler.
      if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt)) {
        //ble_hrs_on_ble_evt(p_ble_evt, &m_hrs);
        ble_nus_on_ble_evt(p_ble_evt, &m_nus);
        on_ble_peripheral_evt(p_ble_evt);
      } else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT)) {
        ble_hrs_c_on_ble_evt(p_ble_evt, &m_hrs_c);
        //ble_nus_on_ble_evt(p_ble_evt,&m_nus);
        on_ble_central_evt(p_ble_evt);
    /**@brief SoftDevice SoC event handler.
     * @param[in]   evt_id      SoC event.
     * @param[in]   p_context   Context.
    static void soc_evt_handler(uint32_t evt_id, void *p_context) {
      switch (evt_id) {
      case NRF_EVT_FLASH_OPERATION_SUCCESS:
        /* fall through */
      case NRF_EVT_FLASH_OPERATION_ERROR:
        if (m_memory_access_in_progress) {
          m_memory_access_in_progress = false;
          scan_start();
    static void ble_stack_init(void) {
      uint32_t ram_start = 0;
      // Enable BLE stack.
      NRF_LOG_INFO("%d", err_code);
      // Register handlers for BLE and SoC events.
      NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void) {
      err_code = pm_init();
      sec_param.bond = SEC_PARAM_BOND;
      sec_param.mitm = SEC_PARAM_MITM;
      sec_param.lesc = SEC_PARAM_LESC;
      sec_param.keypress = SEC_PARAM_KEYPRESS;
      sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
      sec_param.oob = SEC_PARAM_OOB;
      sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
      sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
      sec_param.kdist_own.enc = 1;
      sec_param.kdist_own.id = 1;
      sec_param.kdist_peer.enc = 1;
      sec_param.kdist_peer.id = 1;
    /** @brief Clear bonding information from persistent storage
    static void delete_bonds(void) {
      NRF_LOG_INFO("Erase bonds!");
      err_code = pm_peers_delete();
    /**@brief Function for disabling the use of whitelist for scanning.
    static void whitelist_disable(void) {
      if (!m_whitelist_disabled) {
        NRF_LOG_INFO("Whitelist temporarily disabled.");
        m_whitelist_disabled = true;
        nrf_ble_scan_stop();
        scan_start();
     * @param[in]   event   Event generated by button press.
    void bsp_event_handler(bsp_event_t event) {
      switch (event) {
      case BSP_EVENT_SLEEP:
        nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
      case BSP_EVENT_DISCONNECT:
        err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        if (err_code != NRF_ERROR_INVALID_STATE) {
      case BSP_EVENT_WHITELIST_OFF:
        whitelist_disable();
    /**@brief Heart Rate Collector Handler.
    static void hrs_c_evt_handler(ble_hrs_c_t *p_hrs_c, ble_hrs_c_evt_t *p_hrs_c_evt) {
      NRF_LOG_INFO("hrs_c_evt_handler");
      switch (p_hrs_c_evt->evt_type) {
      case BLE_HRS_C_EVT_DISCOVERY_COMPLETE: {
        NRF_LOG_DEBUG("Heart rate service discovered.");
        err_code = ble_hrs_c_handles_assign(p_hrs_c,
            p_hrs_c_evt->conn_handle,
            &p_hrs_c_evt->params.peer_db);
        // Initiate bonding.
        err_code = pm_conn_secure(p_hrs_c_evt->conn_handle, false);
        if (err_code != NRF_ERROR_BUSY) {
        // Heart rate service discovered. Enable notification of Heart Rate Measurement.
        err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
      } break;
      case BLE_HRS_C_EVT_HRM_NOTIFICATION: {
        NRF_LOG_INFO("Heart Rate = %d.", p_hrs_c_evt->params.hrm.hr_value);
        heart_rate = p_hrs_c_evt->params.hrm.hr_value;
        if (p_hrs_c_evt->params.hrm.rr_intervals_cnt != 0) {
          uint32_t rr_avg = 0;
          for (uint32_t i = 0; i < p_hrs_c_evt->params.hrm.rr_intervals_cnt; i++) {
            rr_avg += p_hrs_c_evt->params.hrm.rr_intervals[i];
          rr_avg = rr_avg / p_hrs_c_evt->params.hrm.rr_intervals_cnt;
          NRF_LOG_DEBUG("rr_interval (avg) = %d.", rr_avg);
      } break;
    /**@brief Battery level Collector Handler.
    static void bas_c_evt_handler(ble_bas_c_t *p_bas_c, ble_bas_c_evt_t *p_bas_c_evt) {
      NRF_LOG_INFO("bas_c_evt_handler");
      switch (p_bas_c_evt->evt_type) {
      case BLE_BAS_C_EVT_DISCOVERY_COMPLETE: {
        err_code = ble_bas_c_handles_assign(p_bas_c,
            p_bas_c_evt->conn_handle,
            &p_bas_c_evt->params.bas_db);
        // Battery service discovered. Enable notification of Battery Level.
        NRF_LOG_DEBUG("Battery Service discovered. Reading battery level.");
        err_code = ble_bas_c_bl_read(p_bas_c);
        NRF_LOG_DEBUG("Enabling Battery Level Notification.");
        err_code = ble_bas_c_bl_notif_enable(p_bas_c);
      } break;
      case BLE_BAS_C_EVT_BATT_NOTIFICATION:
        NRF_LOG_INFO("Battery Level received %d %%.", p_bas_c_evt->params.battery_level);
      case BLE_BAS_C_EVT_BATT_READ_RESP:
        NRF_LOG_INFO("Battery Level Read as %d %%.", p_bas_c_evt->params.battery_level);
     * @brief Heart rate collector initialization.
    static void hrs_c_init(void) {
      NRF_LOG_INFO("HRS_C_INIT");
      ble_hrs_c_init_t hrs_c_init_obj;
      hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
      hrs_c_init_obj.error_handler = service_error_handler;
      hrs_c_init_obj.p_gatt_queue = &m_ble_gatt_queue;
      ret_code_t err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
     * @brief Battery level collector initialization.
    static void bas_c_init(void) {
      NRF_LOG_INFO("BAS_C_INIT");
      ble_bas_c_init_t bas_c_init_obj;
      bas_c_init_obj.evt_handler = bas_c_evt_handler;
      bas_c_init_obj.error_handler = service_error_handler;
      bas_c_init_obj.p_gatt_queue = &m_ble_gatt_queue;
      ret_code_t err_code = ble_bas_c_init(&m_bas_c, &bas_c_init_obj);
     * @brief Database discovery collector initialization.
    static void db_discovery_init(void) {
      ble_db_discovery_init_t db_init;
      memset(&db_init, 0, sizeof(db_init));
      db_init.evt_handler = db_disc_handler;
      db_init.p_gatt_queue = &m_ble_gatt_queue;
      ret_code_t err_code = ble_db_discovery_init(&db_init);
    /**@brief Retrieve a list of peer manager peer IDs.
     * @param[inout] p_peers   The buffer where to store the list of peer IDs.
     * @param[inout] p_size    In: The size of the @p p_peers buffer.
     *                         Out: The number of peers copied in the buffer.
    static void peer_list_get(pm_peer_id_t *p_peers, uint32_t *p_size) {
      pm_peer_id_t peer_id;
      uint32_t peers_to_copy;
      peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ? *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
      peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
      *p_size = 0;
      while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--)) {
        p_peers[(*p_size)++] = peer_id;
        peer_id = pm_next_peer_id_get(peer_id);
    /**@brief Function to start scanning.
    static void scan_start(void) {
      if (nrf_fstorage_is_busy(NULL)) {
        m_memory_access_in_progress = true;
        return;
      NRF_LOG_INFO("Starting scan.");
      err_code = nrf_ble_scan_start(&m_scan);
      err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
    static void buttons_leds_init(bool *p_erase_bonds) {
      bsp_event_t startup_event;
      err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void) {
    /**@brief Function for initializing the power management module. */
    static void power_management_init(void) {
    /**@brief GATT module event handler.
    static void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt) {
      if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)) {
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
      NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
          p_gatt->att_mtu_desired_central,
          p_gatt->att_mtu_desired_periph);
      case NRF_BLE_GATT_EVT_ATT_MTU_UPDATED: {
        NRF_LOG_INFO("GATT ATT MTU on connection 0x%x changed to %d.",
            p_evt->conn_handle,
            p_evt->params.att_mtu_effective);
      } break;
      case NRF_BLE_GATT_EVT_DATA_LENGTH_UPDATED: {
        NRF_LOG_INFO("Data length for connection 0x%x updated to %d.",
            p_evt->conn_handle,
            p_evt->params.data_length);
      } break;
    static void whitelist_load()
        ret_code_t   ret;
        pm_peer_id_t peers[8];
        uint32_t     peer_cnt;
        memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
        peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
        // Load all peers from flash and whitelist them.
        peer_list_get(peers, &peer_cnt);
        ret = pm_whitelist_set(peers, peer_cnt);
        APP_ERROR_CHECK(ret);
        // Setup the device identies list.
        // Some SoftDevices do not support this feature.
        ret = pm_device_identities_list_set(peers, peer_cnt);
        if (ret != NRF_ERROR_NOT_SUPPORTED)
    static void on_whitelist_req(void)
        // Whitelist buffers.
        ble_gap_addr_t whitelist_addrs[8];
        ble_gap_irk_t  whitelist_irks[8];
        memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
        memset(whitelist_irks,  0x00, sizeof(whitelist_irks));
        uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
        uint32_t irk_cnt  = (sizeof(whitelist_irks)  / sizeof(ble_gap_irk_t));
        // Reload the whitelist and whitelist all peers.
        whitelist_load();
        // Get the whitelist previously set using pm_whitelist_set().
        err_code = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                                    whitelist_irks,  &irk_cnt);
        if (((addr_cnt == 0) && (irk_cnt == 0)) ||
            (m_whitelist_disabled))
            // Don't use whitelist.
            err_code = nrf_ble_scan_params_set(&m_scan, NULL);
    static void scan_evt_handler(scan_evt_t const *p_scan_evt) {
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:
                on_whitelist_req();
                m_whitelist_disabled = false;
            } break;
            case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                err_code = p_scan_evt->params.connecting_err.err_code;
            } break;
            case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                NRF_LOG_INFO("Scan timed out.");
                scan_start();
            } break;
            case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
    /**@brief Function for initializing the timer.
    static void timer_init(void) {
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void) {
      ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
      err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    /**@brief Function for initialization scanning and setting filters.
    static void scan_init(void) {
      nrf_ble_scan_init_t init_scan;
      memset(&init_scan, 0, sizeof(init_scan));
      init_scan.p_scan_param = &m_scan_param;
      init_scan.connect_if_match = true;
      init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
      err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
      ble_uuid_t uuid =
              .uuid = TARGET_UUID,
              .type = BLE_UUID_TYPE_BLE,
          SCAN_UUID_FILTER,
          &uuid);
      if (strlen(m_target_periph_name) != 0) {
            SCAN_NAME_FILTER,
            m_target_periph_name);
      if (is_connect_per_addr) {
            SCAN_ADDR_FILTER,
            m_target_periph_addr.addr);
      err_code = nrf_ble_scan_filters_enable(&m_scan,
          NRF_BLE_SCAN_ALL_FILTER,
          false);
     * @details Handle any pending log operation(s), then sleep until the next event occurs.
    static void idle_state_handle(void) {
      err_code = nrf_ble_lesc_request_handler();
      NRF_LOG_FLUSH();
      nrf_pwr_mgmt_run();
    /**@brief Function for starting a scan, or instead trigger it from peer manager (after
     *        deleting bonds).
     * @param[in] p_erase_bonds Pointer to a bool to determine if bonds will be deleted before scanning.
    void scanning_start(bool *p_erase_bonds) {
      // with devices that advertise GATT Service UUID.
      if (*p_erase_bonds == true) {
        // Scan is started by the PM_EVT_PEERS_DELETE_SUCCEEDED event.
        delete_bonds();
      } else {
        scan_start();
    static void gpio_init(void) {
      NRF_LOG_INFO("INIT gpio");
      nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
      err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
      nrf_drv_gpiote_in_event_enable(PIN_IN, true);
    static void gap_params_init(void) {
      ble_gap_conn_params_t gap_conn_params;
          (const uint8_t *)DEVICE_NAME,
          strlen(DEVICE_NAME));
      gap_conn_params.slave_latency = SLAVE_LATENCY;
      gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
    static void on_conn_params_evt(ble_conn_params_evt_t *p_evt) {
      uint32_t err_code;
      if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) {
    static void conn_params_error_handler(uint32_t nrf_error) {
    static void conn_params_init(void) {
      uint32_t err_code;
      cp_init.p_conn_params = NULL;
      cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
      cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
      cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
      cp_init.disconnect_on_fail = false;
      cp_init.evt_handler = on_conn_params_evt;
      cp_init.error_handler = conn_params_error_handler;
    void uart_event_handle(app_uart_evt_t *p_event) {
      static uint8_t index = 0;
      uint32_t err_code;
      switch (p_event->evt_type) {
      case APP_UART_DATA_READY:
        NRF_LOG_INFO("uart event handle");
        index++;
        if ((data_array[index - 1] == '\n') ||
            (data_array[index - 1] == '\r') ||
            (index >= m_ble_nus_max_data_len)) {
          if (index > 1) {
            NRF_LOG_INFO("uart send handle");
            do {
                  (err_code != NRF_ERROR_NOT_FOUND)) {
            } while (err_code == NRF_ERROR_RESOURCES);
          index = 0;
      case APP_UART_FIFO_ERROR:
    /**@snippet [Handling the data received over UART] */
    #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void) {
      uint32_t err_code;
        .rx_pin_no = RX_PIN_NUMBER,
        .tx_pin_no = TX_PIN_NUMBER,
        .rts_pin_no = RTS_PIN_NUMBER,
        .cts_pin_no = CTS_PIN_NUMBER,
        .use_parity = false,
        .baud_rate = NRF_UART_BAUDRATE_115200
    #else
        .baud_rate = NRF_UARTE_BAUDRATE_115200
          UART_RX_BUF_SIZE,
          UART_TX_BUF_SIZE,
          uart_event_handle,
          APP_IRQ_PRIORITY_LOWEST,
          err_code);
    static void nrf_qwr_error_handler(uint32_t nrf_error) {
    static void nus_data_handler(ble_nus_evt_t *p_evt) {
      if (p_evt->type == BLE_NUS_EVT_RX_DATA) {
        uint32_t err_code;
        nrf_delay_ms(10);
        NRF_LOG_INFO("rom BLE NUS. ");
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++) {
          NRF_LOG_INFO("1 ");
          do {
            err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
            if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY)) {
              NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
          } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r') {
          while (app_uart_put('\n') == NRF_ERROR_BUSY)
    static void sleep_mode_enter(void) {
    static void services_init(void) {
      uint32_t err_code;
      ble_nus_init_t nus_init;
        err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init);
      // Initialize NUS.
    static void on_adv_evt(ble_adv_evt_t ble_adv_evt) {
      uint32_t err_code;
      switch (ble_adv_evt) {
      case BLE_ADV_EVT_FAST:
      case BLE_ADV_EVT_IDLE:
        sleep_mode_enter();
    static void advertising_init(void) {
      uint32_t err_code;
      ble_advertising_init_t init;
      init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
      init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
      init.srdata.uuids_complete.p_uuids = m_adv_uuids;
      init.config.ble_adv_fast_enabled = true;
      init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
    static void advertising_start(void) {
    int main(void) {
      bool erase_bonds;
      uint32_t time_ms = 1; //Time(in miliseconds) between consecutive compare events.
      uint32_t time_ticks;
      uint8_t gyrox=0;
      uint8_t gyroy=1;
      uint8_t gyroz=2;
      uint8_t accelx=3,accely=4,accelz=5;
      uint8_t magx=2,magy=2,magz=2;
      uint16_t counter=0;
      uint8_t lat=6,lon=7,alt=8;
      static uint8_t data_array2[135];
      uint32_t err_code = NRF_SUCCESS;
      uart_init();
      log_init();
      timer_init();
      power_management_init();
      ble_stack_init();
      gatt_init();
      peer_manager_init();
      db_discovery_init();
      hrs_c_init();
      bas_c_init();
      scan_init();
      gap_params_init();
      services_init();
      advertising_init();
      conn_params_init();
      err_code = nrf_drv_timer_init(&TIMER_LED, &timer_cfg, timer_led_event_handler);
      time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_LED, time_ms);
      nrf_drv_timer_extended_compare(&TIMER_LED, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
      nrf_drv_timer_enable(&TIMER_LED);
      gpio_init();
      NRF_LOG_INFO("Heart Rate collector example started.");
      // fatfs_example();
      int first_row = 1;
      if (erase_bonds == true) {
        // Scanning and advertising is done upon PM_EVT_PEERS_DELETE_SUCCEEDED event.
        delete_bonds();
      } else {
        adv_scan_start();
      nrf_delay_ms(5000);
      // Enter main loop.
      for (;;) {
        idle_state_handle();
        if(peristat==1)
         if(counter<2000)
                       if(BLE_GATTS_EVT_SYS_ATTR_MISSING)
                       err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0,0);
                        NRF_LOG_INFO("%d",counter);
                        sprintf(data_array2,"{\"g_x\":%d,\"g_y\":%d,\"g_z\":%d,\"a_x\":%d,\"a_y\":%d,\"a_z\":%d,\"m_x\":%d,\"m_y\":%d,\"m_z\":%d,\"lat\":%d,\"lon\":%d,\"alt\":%d,\"hb\":%d}",gyrox,gyroy,gyroz,accelx,accely,accelz,magx,magy,magz,lat,lon,alt,heart_rate);
                        NRF_LOG_HEXDUMP_DEBUG(data_array2, 0);
                        do
                            uint16_t length = (uint16_t)135;
                            err_code = ble_nus_data_send(&m_nus, data_array2, &length, m_conn_handle);
                          gyrox++;
                          gyroy++;
                          gyroz++;
                          accelx++;
                          accely++;
                          accelz++;
                          magx++;
                          magy++;
                          magz++;
                          counter++;
                          lon++;
                          lat++;
                          alt++;
    In this code i have changed do while loop as i have change nrf_error_busy with nrf_error_resourses so code is working fine i have removed all delays and still it works work without giving error but the main issue is data rate  .
    I have changed
    and #define BLE_GATTS_HVN_TX_QUEUE_SIZE_DEFAULT  50 in ble_gatts.h file .
    Please check and respond .
    Thanks
    Mohsin khan
    I'm glad to hear that you found a suitable solution to this issue for your application. Please note that if you were to change the data between two calls to ble_nus_data_send where the first returns with NRF_ERROR_RESOURCES, you would loose the previous data. This is a likely implementation if the data is to be generated by some sensor that queues a notification for sending when it has concluded a measurement. I am sure you are aware of this, but I thought I should mention it just in case.
    Mohsin khan said:
    I have changed
    Please also tell me what you have changed your connection event length to.
    It should be set equal to your connection interval. Could you also tell me what you MTU size is?
    Please also see my previous question about the nRF Sniffer. It would be really helpful to see a trace of the communication to determine why you are not achieving the desired data rates.
    Karl
  • ble_nus_data_send where the first returns with NRF_ERROR_RESOURCES
    Yes my data is changing time to time and data is not lost , Is this a function issue or any thing else .
    I don't know where to change connection event length , I have changed Att_mtu to 247 but no idea about event length .
    I don't know about nrf sniffer please guide me about that .
