I am unable to build basic blinky project outside the NRF Connect sdk.
Board - Thingy 91 - nRF9160
SDK version - 1.7.0
builiding through command line tools - CMake and Ninja (windows)
I have provided build variables in the Cmakelists.txt as below.
cmake_minimum_required(VERSION 3.20.0)
set(ZEPHYR_TOOLCHAIN_VARIANT gnuarmemb)
set(GNUARMEMB_TOOLCHAIN_PATH C:/coresensing/toolchain/gnuarmemb)
set(ZEPHYR_BASE C:/coresensing/toolchain/ncs/zephyr)
set(BOARD_ROOT C:/coresensing/toolchain/ncs/nrf)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(blinky)
target_sources(app PRIVATE src/main.c)
My application directory is as follows,
- Workspace
- Blinky
- src
- main.c
-CMakelists.txt
-prj.conf
This is the Cmake error I am getting
PS C:\Users\Suhas\eclipse-workspace\blinky> cmake -B build -GNinja -DBOARD=thingy91_nRF9160_ns
Including boilerplate (Zephyr base (cached)): C:/coresensing/toolchain/ncs/zephyr/cmake/app/boilerplate.cmake
CMake Deprecation Warning at C:/coresensing/toolchain/ncs/zephyr/cmake/app/boilerplate.cmake:37 (cmake_policy):
The OLD behavior for policy CMP0079 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
C:/coresensing/toolchain/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
C:/coresensing/toolchain/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
CMakeLists.txt:25 (find_package)
-- Application: C:/Users/Suhas/eclipse-workspace/blinky
-- Zephyr version: 2.6.99 (C:/coresensing/toolchain/ncs/zephyr), build: v2.6.99-ncs1
-- Found Python3: C:/coresensing/toolchain/python/python.exe (found suitable exact version "3.9.7") found components: Interpreter
-- Found west (found suitable version "0.11.1", minimum required is "0.7.1")
-- Board: thingy91_nRF9160_ns
-- Cache files will be written to: C:/coresensing/toolchain/ncs/zephyr/.cache
-- Found toolchain: gnuarmemb (C:/coresensing/toolchain/gnuarmemb)
-- Found BOARD.dts: C:/coresensing/toolchain/ncs/nrf/boards/arm/thingy91_nrf9160/thingy91_nRF9160_ns.dts
-- Generated zephyr.dts: C:/Users/Suhas/eclipse-workspace/blinky/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Suhas/eclipse-workspace/blinky/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Suhas/eclipse-workspace/blinky/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Suhas/eclipse-workspace/blinky/build/zephyr/dts.cmake
Parsing C:/coresensing/toolchain/ncs/zephyr/Kconfig
Loaded configuration 'C:/coresensing/toolchain/ncs/nrf/boards/arm/thingy91_nrf9160/thingy91_nRF9160_ns_defconfig'
Merged configuration 'C:/Users/Suhas/eclipse-workspace/blinky/prj.conf'
Configuration saved to 'C:/Users/Suhas/eclipse-workspace/blinky/build/zephyr/.config'
Kconfig header saved to 'C:/Users/Suhas/eclipse-workspace/blinky/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.1
-- The CXX compiler identification is GNU 10.3.1
-- Found assembler: C:/coresensing/toolchain/gnuarmemb/bin/arm-none-eabi-gcc.exe
Changed board to secure thingy91_nRF9160 (NOT NS)
=== child image spm - begin ===
Including boilerplate (Zephyr workspace): C:/coresensing/toolchain/ncs/zephyr/cmake/app/boilerplate.cmake
of CMake.
C:/coresensing/toolchain/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:91 (include_boilerplate)
CMakeLists.txt:8 (find_package)
-- Application: C:/coresensing/toolchain/ncs/nrf/samples/spm
-- Found BOARD.dts: C:/coresensing/toolchain/ncs/nrf/boards/arm/thingy91_nrf9160/thingy91_nRF9160.dts
-- Found devicetree overlay: C:/coresensing/toolchain/ncs/nrf/samples/spm/boards/thingy91_nRF9160.overlay
-- Generated zephyr.dts: C:/Users/Suhas/eclipse-workspace/blinky/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Users/Suhas/eclipse-workspace/blinky/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Users/Suhas/eclipse-workspace/blinky/build/spm/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: C:/Users/Suhas/eclipse-workspace/blinky/build/spm/zephyr/dts.cmake
Loaded configuration 'C:/coresensing/toolchain/ncs/nrf/boards/arm/thingy91_nrf9160/thingy91_nRF9160_defconfig'
Merged configuration 'C:/coresensing/toolchain/ncs/nrf/samples/spm/prj.conf'
Merged configuration 'C:/coresensing/toolchain/ncs/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Users/Suhas/eclipse-workspace/blinky/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Users/Suhas/eclipse-workspace/blinky/build/spm/zephyr/.config'
Kconfig header saved to 'C:/Users/Suhas/eclipse-workspace/blinky/build/spm/zephyr/include/generated/autoconf.h'
File "<string>", line 1, in <module>
File "C:\coresensing\toolchain\python\lib\site-packages\west\manifest.py", line 1103, in from_file
topdir = util.west_topdir()
File "C:\coresensing\toolchain\python\lib\site-packages\west\util.py", line 82, in west_topdir
raise WestNotFound('Could not find a West workspace '
west.util.WestNotFound: Could not find a West workspace in this or any parent directory
CMake Error at C:/coresensing/toolchain/ncs/nrfxlib/common.cmake:58 (message):
Failed to find mbedtls, cannot build security libraries
C:/coresensing/toolchain/ncs/nrfxlib/nrf_security/CMakeLists.txt:173 (get_mbedtls_dir)
See also "C:/Users/Suhas/eclipse-workspace/blinky/build/spm/CMakeFiles/CMakeOutput.log".
See also "C:/Users/Suhas/eclipse-workspace/blinky/build/spm/CMakeFiles/CMakeError.log".
CMake Error at C:/coresensing/toolchain/ncs/nrf/cmake/multi_image.cmake:301 (message):
CMake generation for spm failed, aborting. Command: 1
C:/coresensing/toolchain/ncs/nrf/cmake/multi_image.cmake:68 (add_child_image_from_source)
C:/coresensing/toolchain/ncs/nrf/samples/CMakeLists.txt:58 (add_child_image)
See also "C:/Users/Suhas/eclipse-workspace/blinky/build/CMakeFiles/CMakeOutput.log".
See also "C:/Users/Suhas/eclipse-workspace/blinky/build/CMakeFiles/CMakeError.log".
Please let me know what I can do to fix this error.
Thank you.
- Suhas
