TWIS (I2C slave) no IRQ
Hi
I'm trying to use the nrfx TWI Slave function with IRQ (No Poll), but there is no clean code available I found.
I'm using the following code:
const nrfx_twis_t m_twis_1_slave = NRFX_TWIS_INSTANCE(1);    /**< TWIS slave 1 instance */
#define STEINEL_SENSORS_MY_ADDRESS		0x08
const nrfx_twis_config_t twis_config_1 =
	.addr = { (STEINEL_SENSORS_MY_ADDRESS >> 1), 0 },
    .scl = RJ11_I2C_SCL,
    .sda = RJ11_I2C_SDA,
    .scl_pull = NRF_GPIO_PIN_NOPULL,
    .sda_pull = NRF_GPIO_PIN_NOPULL,
    .interrupt_priority = APP_IRQ_PRIORITY_HIGH
NVIC_ClearPendingIRQ(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn);
NVIC_SetPriority(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn, 6);
NVIC_EnableIRQ(SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQn);
ret = nrfx_twis_init(&m_twis_1_slave, &twis_config_1, twis_event_handler);
if (NRF_SUCCESS == ret)
		printf("twi slave init success\r\n");
		nrfx_twis_enable(&m_twis_1_slave);
But even if I can see the data on the oscilloscoipe with the address 0x08, the function
static void twis_event_handler(nrfx_twis_evt_t const* const p_event)
never gets triggered. Whats the provblem here? It's not normal to spend hours and days for a I2C slave feature, but without examples its try and error...
Any inputs from Nordic side? Or a example code with IRQ?
  • In the debug Log I got the output:
    <warning> PRS: Function: nrfx_prs_acquire, error code: NRF_ERROR_BUSY.
    I use the same TWI port as master before, then I call twi_master_uninit and after this nrfx_twis_init which is causing the error, but why?
    I tried with nrfx_prs_release(&m_twi_1_master);, but this is not solving the problem.
  • I just recognized, that the NRF_ERROR_BUSY is in realtion with the TWI instance 0.
    const nrfx_twi_t m_twi_0_master = NRFX_TWI_INSTANCE(0);     /**< TWI master 0 instance */
    const nrfx_twi_t m_twi_1_master = NRFX_TWI_INSTANCE(1);     /**< TWI master 1 instance */
    I need the TWI instance 0 and 1 as master in normal oiperation. After this, I need the TWI 0 as master and TWI1 as slave (TWIS). When I call nrfx_twi_disable(&m_twi_0_master) and nrfx_twi_uninit (&m_twi_0_master) before calling the init for the TWIS i have ret = success.
    conclusion: TWIS and TWI (master and slave) at the same time on different peripherals are not possible?!?
    -> please confirm
    ret = nrfx_twis_init(&m_twis_1_slave, &twis_config_1, twi_slave_event_handler);
        /* Init TWIS */
        if (NRFX_SUCCESS == ret)
  • conclusion: TWIS and TWI (master and slave) at the same time on different peripherals are not possible?!?
    correction, when I use he same NRFX instance, its worgking, but still missing the IRQ... Do I have to enable some flags which IRQ is acive or anything else?
    The driver should ensure that interrupts are enabled and that the event handler is called as long as an event handler is provided when you call nrfx_twis_init(), which I see you do here. There may be some complications when you use peripheral resource sharing (PRS), though. Can you share the PRS related configurations from your sdk_config.h?
  • I got it worked now, after days. Maybe it would be a good idea to provide some nrfx examples for the TWI and TWIS on the same port with IRQ, I didn't found some example code and its not really clear how the implementation should be. I think other people will have the same problems.
