fds_init() Fault
The fault was caught by the weak handler, which I think means it was totally not expected.
 The trace starts from peer_manager_init() which is part of the Buttonless DFU Template Application.
 Log message: “peer_manager_pds: Could not initialize Flash. FD0002FF1”
 This comes from peer_data_storage.c, after returning from fds_init() (fds.c) but the log message in the source code has more text. Odd.
 Fault information: id=0x4001, pc=0x2FFF1, info=0x2003ffb8.
 After the fault I ran several times using breakpoints to track it down to the return from fds_init().
QUESTIONS:
Prior to  adding the Buttonless DFU code (over 300 lines), I was already using fstorage for direct read and write of the Config data flash (8Kbytes just below the B/L start address.) Is that the problem? Is fstorage incompatible with FDS?
    It sounds like your fstorage data might be overlaping with the FDS area. FDS may fail to initialize in that case (it won't claim flash pages that don't have a valid Page tag)
    Please try the following:
    1. Allocate 2 flash pages for the fstorage data below the bootloader by setting the FDS_VIRTUAL_PAGES_RESERVED to '2' in sdk_config.h
    2. Make sure both fstorage and fds data is preserved by the bootloader. This is done by increasing the NRF_DFU_APP_DATA_AREA_SIZE configuration in the bootloader project.
    Vidar
  • Setting  FDS_VIRTUAL_PAGES_RESERVED is set to 2.
     Since FDS need 3 pages, and I need 2 pages for fstorage, is 5 pages (5*4096) what i need for the DATA_AREA_SIZE?
     where is my flash area? – I’m assuming that it still is 8Kbytes immediately below the start of the bootloader, because of comments in the sdk_config.h file for FDS_VIRTUAL_PAGES_RESERVED. Is that correct?
    FDS does its thing in three pages, right? (per the example code), and I do my thing with nrf_fstorage_sd calls in two pages. They must be totally independent because I have my own structure and format for my config data that includes a crc. That’s why I think I need 5 pages total, not 3.  So the reserved data size (just below the bootloader) is 5*4096?
  • Correct, you will need to reserve 5 pages (FDS_VIRTUAL_PAGES_RESERVED + FDS_VIRTUAL_PAGES_RESERVED).
    Yes.
    Yes, it selects 3 pages by default.
