The scan observer stops getting called after a failed attempt to connect to a peripheral using whitelist.
Hello All,
I have the following issue
- a peripheral and a central using nrf52832 with SDK 15.3 and S132
- on the peripheral I advertise with a whitelist
- the central scans with UUID filter activated for a specific UUID
Now when the central sees the peripheral, it tries to connect to it but since it is not in the centrals whitelist the connection is not established.
The problem on the central side is that the observer function nrf_ble_scan_on_ble_evt() stops getting called after the failed attempt to connect.
I reproduced this behavior using the ble_app_multirole_lesc example with some minor changes.
On the central I commented out the call to ble_advertising_start() so that it only scans.
On the peripheral I removed the scan_start() call so it only advertises and I activated the whitelist which has one entry.
I did put logging in nrf_ble_scan_on_adv_report() so that I can see whenever it gets called. When I run the central code, there is continuous log showing advertising packets from different devices. After a failed attempt to connect, I turn off the peripheral and there is no log output from nrf_ble_scan_on_adv_report() any more on the central.
This is how the log looks like on the central:
<info> ble_scan: B460775CF63C
<info> ble_scan: 775F1B8AEA41
<info> ble_scan: EE8BD6D1ABF4
<info> app: CENTRAL: Connected, handle: 0.
<info> app: CENTRAL: Searching for HRS on conn_handle 0x0
<info> peer_manager_handler: Connection security failed: role: Central, conn_handle: 0x0, procedure: Bonding, error: 4352
<warning> peer_manager_handler: Disconnecting conn_handle 0.
<info> app: CENTRAL: Disconnected, handle: 0, reason: 0x3E
<info> app: Scanning
<info> ble_scan: 44237CE1653F
Obviously this leads to a problem state where the central can not find any other devices to connect to. Stopping and starting the scan does not help. Only if the same peripheral appears again, the central starts calling nrf_ble_scan_on_adv_report again.
Do you know what could be causing this issue and how to resolve it? Does the SoftDevice get stuck somewhere?
Skara
