nPM1100 Maximum Battery Capacity 500mAh?
Hi there,
In the video that was just posted about the nPM1100 EK it is stated (at 1:18) that the battery charger of the nPM1100 must be used with batteries of a size less than 500mAh:
The closest I can find to this statement in the infocenter is that the nPM1100 "supports charging batteries at up to 500 mA through USB". I cannot find any mention in the specifications of a maximum compatible battery capacity for the nPM1100. Are you able to clarify?
Many thanks,
Richard
  • Hi Richard,
    The nPM11000 has an adjustable charge current from 20mA to 400mA. There is no maximum battery size but more a recommendation due to the charging rate and user experience.
    Usually you want to charge a battery with 1C or a bit lower, it means the charge current in mA match the capacity in mAh, and you use approx 1 hour to go from empty to full battery. Smaller batteries are commonly rated at 1C rating. You will generally find the C rate of your battery on it's label and on the battery datasheet.
    You are of course free to use the nPM1100 with as big as a battery as you want, but since the charger current is limited to 400mA, a 800mAh battery willl for instance take 2 hours to charge from 0-100%, a 1200mA battery will use approx. 3 hours, and so on...
    Marjeris
