Is that possible use the nRF52840 Dongle PCA10059 with CENTRAL_UART to connect theThingy:52 to forwarding data to Edge Impulse studio?
Hey Haraldo!
Just letting you know that I am looking into it, but I will have to get back to you over the weekend.
Elfving
Ok Elfving!
I wating you over the weekend.
Thanks
Hey Haraldo!
Yes, that is very much possible. I assume you have taken a look at the tutorials on the developer page about this.
The main issue with the dongle is that it isn't as easy to work with as a DK, since it doesn't have an onboard debugger. Using a dongle shouldn't be any less feasible than a DK however.
Elfving
Hi Elfving,
I programmed the nRF52840 Dongle with CENTRAL_UART firmware and the board connected to Thingy: 52 (the red led flashes fast), but I can't forward the data to Edge Impulse Studio.
In the command window:C:\Users\harol>edge-impulse-data-forwarder
Edge Impulse data forwarder v1.13.15
Endpoints:
Websocket: wss://remote-mgmt.edgeimpulse.com
API: https://studio.edgeimpulse.com/v1
Ingestion: https://ingestion.edgeimpulse.com
[SER] Could not find any devices connected over serial port
[SER] Retrying in 5 seconds
Dongle does not connect to serial UART.
I don't know what I'm doing wrong.
Hey again Haraldo!
Ah right, I forgot that the data forwarding example uses the COM port. It is sadly true that for that to work right out of the box you would need a DK. Sorry about that.
It is possible to get it to work on the dongle by using the USB connection as a COM port, but that would require a bit of work, which is yet another reason to get a DK (as the DK has an external debugger, and easier to work with).
Elfving
