saadc oversampling
HI,
I'm developing it using NRF52832.
I'm updating the remaining battery capacity using saadc. However, the battery value is not stable because the value obtained from saadc is not constant.
Can I stabilize the saadc value using oversampling?
Is there anything I missed when setting up the code for oversampling?
I'll attach the code.
<nrfx_saadc.h>
#define NRFX_SAADC_DEFAULT_CHANNEL_CONFIG_SE(PIN_P) \
    .resistor_p = NRF_SAADC_RESISTOR_DISABLED,      \
    .resistor_n = NRF_SAADC_RESISTOR_DISABLED,      \
    .gain       = NRF_SAADC_GAIN1_6,                \
    .reference  = NRF_SAADC_REFERENCE_INTERNAL,     \
    .acq_time   = NRF_SAADC_ACQTIME_10US,           \
    .mode       = NRF_SAADC_MODE_SINGLE_ENDED,      \
    .burst      = NRF_SAADC_BURST_ENABLED,         \
    .pin_p      = NRF_SAADC_INPUT_AIN0,             \
    .pin_n      = NRF_SAADC_INPUT_DISABLED          \
<sdk_config.h>
// <o> NRFX_SAADC_CONFIG_OVERSAMPLE  - Sample period
// <0=> Disabled
// <1=> 2x
// <2=> 4x
// <3=> 8x
// <4=> 16x
// <5=> 32x
// <6=> 64x
// <7=> 128x
// <8=> 256x
#ifndef NRFX_SAADC_CONFIG_OVERSAMPLE
#define NRFX_SAADC_CONFIG_OVERSAMPLE 8
<main.c>
void saadc_init(void)
    ret_code_t err_code;
    nrf_saadc_channel_config_t channel_config =
      //NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_DIFFERENTIAL(NRF_SAADC_INPUT_VDD, NRF_SAADC_INPUT_AIN0);
      NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
    err_code = nrf_drv_saadc_init(NULL,saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    /*err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
    APP_ERROR_CHECK(err_code);*/
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 500);
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
static void battery_level_percent(void)
    if (mvolts >= 3000)
        battery_level = 100;
    else if (mvolts > 2900)
        battery_level = 100 - ((3000 - mvolts) * 58) / 100;
    else if (mvolts > 2740)
        battery_level = 42 - ((2900 - mvolts) * 24) / 160;
    else if (mvolts > 2440)
        battery_level = 18 - ((2740 - mvolts) * 12) / 300;
    else if (mvolts > 2100)
        battery_level = 6 - ((2440 - mvolts) * 6) / 340;
        battery_level = 0;
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        int i;
        NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        avg_mvolts=0;
        for (i = 0; i < SAMPLES_IN_BUFFER; i++)
            /* get adc value */
            NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
            adc_value= p_event->data.done.p_buffer[i];
            mmvolts=adc_value*(3.6)/1024;
            mvolts=mmvolts*1000;
            m_adc_evt_counter++;
        avg_mvolts+=mvolts;
         /* Update the battery every minute. */
        if (m_adc_evt_counter>240)
          battery_level=avg_mvolts/m_adc_evt_counter;
          /* battery level in percent to coin cell */
          battery_level_percent();
          NRF_LOG_INFO("battery_level: %d", battery_level);
          /* update battery percent */
         battery_level_update();
         m_adc_evt_counter=0;
    /*Initialize variables.*/
    mvolts=0;
    avg_mvolts=0;
    How much does the values fluctuate ?
    Maybe consider adding in some signal processing in addition.
    Oversampling is good at reducing white noise, but there are other factors that contribute to fluctuations. Like for example if the radio is used while the SAADC is taking samples, it will lower the voltage a bit.
    We do have some older cases here on Devzone that you can look at also:
    nRF52832 SAADC sampling - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
    SAADC oversampling sampling interval? - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
    Jonathan
  • Values fluctuate within a single digit range.BUT There are times when the value fluctuates significantly.
    I also tried to derive the remaining battery capacity through the average value by setting the buffer to 1.However, the remaining battery capacity is not constant due to the large splashing values.
    Should we process additional signals?
    measured in mV this is a good result.
    how much is significantly ?
    If the value fluctuation that is significant occurs as the same time that the CPU, Radio or some peripheral is doing something then there will be peaks and valleys on the VDD. So you will have to figure out if something else is going on during those significant fluctuations periods.
    In addition you will also have to use the discharge curve of the battery that you are using. We only have it for CR2032.
    You can also average with oversampling, by having buffer size 1 and oversampling 16, then only one value will be written to the buffer anyways.
    Jonathan
